Fog Lights
Old Jun 26, 2005 | 10:51 AM
Yakuza70's Avatar
Fog Lights
I noticed that the fog lights are pretty yellow, especially when they're on with the HIDs. Has anyone changed them out for more white bulbs like PIAAs?
Old Jun 26, 2005 | 07:45 PM
crazymjb's Avatar
It is possible, and I do believe some people have changed them out. As for putting in lighter bulbs, that MAY decrease their functionality(sp?). There is currently debate over weather the yellow light actually does make a difference(no doubt yellow wavelengths are best able to penetrate fog, but these may just be filtered yellow(does that only allow yellow wavelengths through?). My biggest fret with the fog lamps is there location, the current space should be used for DRLs, IMO.
Old Jun 26, 2005 | 08:11 PM
JOES05tl's Avatar
I put in some piaa 'super plasma spark' bulbs. They look cool at night and also right when you turn them on(press unlock on the keyfob). At night, its just so much brightness that you CANNOT notice the mismatched colortemps, but in the daytime after the h.i.d.s' warm up and turn white, the piaa foglights are hella blue. Doesnt match. I don't care though, cuz' i dont drive with headlights on in the daytime.
Old Jun 27, 2005 | 06:47 AM
Russdaddy's Avatar
Boondocks fanatic.....
From: Half-assed Aggie trapped in Longhorn territory....
The stock foglights are useless for me. I kept getting frustrated because one part of the lighting was white but the other part was yellow whenever I tried to use the foglights.
So about a week and minus 40 bucks later I threw in some Sylvania foglights from the local Autozone. Way better if you ask me because I see that much easier now when I have the fogs on. All of my lighting is a combined clear white light after the HID's heat up. Downside is that some drivers think that I actually have my brights on.
Old Jul 2, 2005 | 10:54 PM
ediddy's Avatar
ediddy
__________________
97' B16 Civic (POS) Hatchback
2005 Acura TL
Hey Russ were the foglights hard to pop out? I want to get the foglights replaced also.....do you have a picture?
ed
Old Jul 2, 2005 | 10:59 PM
crazymjb's Avatar
So you dont have to take the front of the car off to get to the fogs, just to get to the heads for clearing, although they are in the same housing.
Old Jul 2, 2005 | 11:02 PM
Mike_McCready's Avatar
I don't know about your 3G guys, but the 2G is an easy 20 minute job to replace both fog bulbs. Also I recommend the mod, it is an ill look
Old Jul 3, 2005 | 12:18 AM
Ga_Tech_TL's Avatar
Antracitebony TL
but did u know that yellow beam is better than white beam in term of visibility? ITs all about appearnces really
Old Jul 3, 2005 | 04:56 PM
TCBaby's Avatar
Yes, but Foglights are spposed to be lower on the vehicle not placed where the headlights are.
Old Jul 3, 2005 | 06:12 PM
Lokius's Avatar
Silky Smooth
search search search for foglights and you'll see it all
Old Jul 3, 2005 | 06:21 PM
Yakuza70's Avatar
O.K. I changed out my O.E.M. foglights with PIAA Extreme White Plus bulbs. I had a 2002 Maxima and changed them out with the same bulbs to match my HIDs in the Maxima. They were close but not an exact match.
I figured they should come close to the HIDs in my new TL. Unfortunately, while they are noticeably better than the O.E.M. bulbs, they're still relatively yellow next to the TL's HIDs. Maybe the TL's HIDs are bluer than my Maxima's HIDs? I don't know. I'm also thinking that the bulbs sit in a reflective enclosure that bounces the light into the headlight area then out forward. Perhaps the reflective material is yellow tinted?
The installation was pretty simple actually because the instructions are in the manual. The driver side bulb was harder to take out since I had a hard time getting my hand at a good angle to get enough leverage to rotate the bulb and remove it. The engine compartment is really packed tight!
Unless you can find a whiter bulb than the Extreme white plus bulbs, I wouldn't bother to change the O.E.M. foglights.
Old Jul 3, 2005 | 09:05 PM
crazymjb's Avatar
When you change em to be white you no longer have FOG lights, you just have more headlights, and unless you get more xenons, the projectors can't be matched.
Old Jul 26, 2005 | 02:35 PM
nibalm3's Avatar
go to
http://www.hoen-usa.com/fog2.htm
get the 9006 model.. they nice
Old Jul 27, 2005 | 02:43 AM
special-ed's Avatar
Iro Ridg .308
Originally Posted by nibalm3
go to
That's tits baby. I was just looking at my yellow fogs tonight and telling myself how nice it would be to have either a dual HID setup with fogs mounted underneath (later mod) but after seeing these bulbs, consider this mod being done. Thanks for sharing!
Will the 9006 models be a drop in replacement in the 3 gens?
Old Aug 1, 2005 | 01:04 PM
Danny04TL's Avatar
has anyone changed their fog lights to hid's ?? how many K's is the stock 4300?
InFaMouSLink
Oct 27, 2015 06:51 PM
sockr1
Oct 1, 2015 01:31 AM
ellisd03tls
Sep 8, 2015 04:17 PM
cruisingnycfl
Sep 2, 2015 12:11 PM
prox
5G TLX Problems & Fixes
Sep 1, 2015 02:03 AM
