Fog Lights
Fog Lights
I noticed that the fog lights are pretty yellow, especially when they're on with the HIDs. Has anyone changed them out for more white bulbs like PIAAs?
It is possible, and I do believe some people have changed them out. As for putting in lighter bulbs, that MAY decrease their functionality(sp?). There is currently debate over weather the yellow light actually does make a difference(no doubt yellow wavelengths are best able to penetrate fog, but these may just be filtered yellow(does that only allow yellow wavelengths through?). My biggest fret with the fog lamps is there location, the current space should be used for DRLs, IMO.
I put in some piaa 'super plasma spark' bulbs. They look cool at night and also right when you turn them on(press unlock on the keyfob). At night, its just so much brightness that you CANNOT notice the mismatched colortemps, but in the daytime after the h.i.d.s' warm up and turn white, the piaa foglights are hella blue. Doesnt match. I don't care though, cuz' i dont drive with headlights on in the daytime.
Boondocks fanatic.....
Location: Half-assed Aggie trapped in Longhorn territory....
So about a week and minus 40 bucks later I threw in some Sylvania foglights from the local Autozone. Way better if you ask me because I see that much easier now when I have the fogs on. All of my lighting is a combined clear white light after the HID's heat up. Downside is that some drivers think that I actually have my brights on.
The stock foglights are useless for me. I kept getting frustrated because one part of the lighting was white but the other part was yellow whenever I tried to use the foglights.
__________________
97' B16 Civic (POS) Hatchback
2005 Acura TL
Hey Russ were the foglights hard to pop out? I want to get the foglights replaced also.....do you have a picture?
ed
__________________
2005 Acura TL
ed
O.K. I changed out my O.E.M. foglights with PIAA Extreme White Plus bulbs. I had a 2002 Maxima and changed them out with the same bulbs to match my HIDs in the Maxima. They were close but not an exact match.
I figured they should come close to the HIDs in my new TL. Unfortunately, while they are noticeably better than the O.E.M. bulbs, they're still relatively yellow next to the TL's HIDs. Maybe the TL's HIDs are bluer than my Maxima's HIDs? I don't know. I'm also thinking that the bulbs sit in a reflective enclosure that bounces the light into the headlight area then out forward. Perhaps the reflective material is yellow tinted?
The installation was pretty simple actually because the instructions are in the manual. The driver side bulb was harder to take out since I had a hard time getting my hand at a good angle to get enough leverage to rotate the bulb and remove it. The engine compartment is really packed tight!
Unless you can find a whiter bulb than the Extreme white plus bulbs, I wouldn't bother to change the O.E.M. foglights.
Iro Ridg .308
Originally Posted by nibalm3
Will the 9006 models be a drop in replacement in the 3 gens?
InFaMouSLink
10-27-2015 06:51 PM
sockr1
10-01-2015 01:31 AM
prox
5G TLX Problems & Fixes
09-01-2015 02:03 AM
