Fog Lights!!!!!
Old Jul 21, 2004 | 01:54 PM
timdaley73's Avatar
Fog Lights!!!!!
Just curious if anyone else have problems with them?!? I mean they work and all... But, I just don't like the look of them right next to my HID! I'm so used to seeing fog lights towards the bottom of the front... Anyone use them?! I have been keeping them off since I didn't like they way it looked in combo of the HID... Also, any problems keeping the HID on during the day? Lately, I've been finding myself keeping them on (looks cool!)...
Old Jul 21, 2004 | 02:21 PM
cliff's Avatar
Team NightHawk VP
there isnt a problem, but your HIDs will not last as long, since you are using up the hours during the day too. but they last pretty long in general, so i dont think you should worry about it.
Old Jul 21, 2004 | 03:27 PM
Tripp11's Avatar
Newbie for Life
The fog lights aren't supposed to placed on a car to merely "look cool". They serve a purpose and that's to allow you to see better during inclement weather. The only time I use the fog lights is when they are needed.
Some people on this forum have discussed installing separate fog lights in the front spoiler section but I think the concensus is that they don't want to fuc* with the CAI section of the front spoiler.
Old Jul 21, 2004 | 04:10 PM
rets's Avatar
Moderator Alumnus
I agree with tripp11. I used my "foglight" when they're needed, in rainy day or in country-side roads, etc. The current foglight may not aim right, but it still extends the fair amount of luminosity toward the front in addition to our HID.
If we talking about where to mount the new foglight from the bottom of the front fascia, you will find an inlet of the 04TL CAI has occupied itself with the ideal location.
Click it if no pic...
Except you get some particular models of foglight with smaller size and enough brightness, it's hard to fit under CAI's inlet. Otherwise, you have to relocate that CAI toward the middle of the front and make a fair space for your bulk of foglight.
Or you could put the foglight in the middle of the front, this doesn't look good though.
Someone may say this CAI with the inlet is useless... yes, you may remove them all.
This is what Acura says about... believe or not.
COLD-AIR INDUCTION SYSTEM
Cool air is denser than hot air and allows an engine to make more power by packing more oxygen per given volume. To capitalize on this fact, the TL has a special cold-air induction system as standard equipment. Ambient air is picked up through an inlet in the left front fascia, and fed by a duct to the engine air intake. Depending on vehicle speed, this system supplies the engine with ambient air that is much as 15 degrees F. cooler than typical engine compartment air.
A new low-restriction induction system improves breathing in the new TL. In addition to providing more aggressive sound under acceleration, this new system flows 40 percent more air than the system in the '03 TL, and about four percent more than in the '03 Type-S.
Old Jul 21, 2004 | 04:12 PM
NightRider's Avatar
SOLD
You are right, the fog light serve a purpose. I keep mine on at night as just HID's or just halogens have strengths and weaknesses each. I switched out the stocks for silverstars and they"look cooler" because they are white instead of yellow, they are also provide better light than the stocks and you can still tell the difference between the HID and fogs. At night with the HID's and fogs it provide a basically 180 degree range of light and works and looks great. On the other hand, I do like the setup of the bumper for the TSX to incorporate down low fog lights.
Old Jul 21, 2004 | 04:26 PM
NightRider's Avatar
SOLD
Rets, where did you get the picture of the induction? And do you have the entire picture? I modified my intake and took out the loopty by the battery so the air just goes in, right to the resonator, and up to the filter box. It at least provides beefier sound if nothing else performance wise. As far as the fog lights, I suppose even though it wouldn't look great without some custom bumper fitting, you could put 2 really close between like some trucks do...
Old Jul 21, 2004 | 04:44 PM
rets's Avatar
Moderator Alumnus
Right... it probably requires some additional works to make foglight fit well... I know small ones could fit, but it's useless if they cannot provide sufficient illumination as "foglight".
Check Garage, there are two or three threads having CAI pictures and info, by Aegir and Bitium.
Old Jul 21, 2004 | 04:55 PM
Tripp11's Avatar
Newbie for Life
Nice post, Rets!!
Old Jul 21, 2004 | 08:00 PM
rets's Avatar
Moderator Alumnus
I wonder why no one has put the fog light yet...
Old Jul 21, 2004 | 08:38 PM
Road Rage's Avatar
Not a Blowhole
I hardly ever use the fogs, but went with Silverstars for a beter look. Using fogs when they are not needed (which is 90% of the time), can actually reduce your night vision, as the reflected light off the road causes your pupils to contract, reducing depth perception.
Driving with fogs on in the rain compounds the siituation, and causes more glare to others. Use them for what they were intended - int he fog, or perhaps more likely, for driving on back roads where seeing things int he nearfield (animals, road signs, mailboxes, and people) can be tough.
Nothing worse than someone driving with fogs on all the time just to attract attention or cause they think it is cool. To me, it is not cool, it is retarded. But what do I know? - I could be wrong! (Like Dennis Miller, nod/wink).
Old Jul 21, 2004 | 10:16 PM
rets's Avatar
Moderator Alumnus
Originally Posted by Road Rage
... ...Driving with fogs on in the rain compounds the siituation, and causes more glare to others... ...
I heard u... :sqnteek: Only in foggy rainy days...
Old Jul 22, 2004 | 05:35 PM
NightRider's Avatar
SOLD
2nd road rage, fog light are made for a purpose, and "looking cool" does not count as a purpose...
Old Oct 15, 2004 | 07:27 AM
Whiteowl's Avatar
Zorro
I thought fog lights are suppose to be mount low to the road, and should be able to be used without the normal headlights. Normal headlight shine to high under foggy or snowy conditions and the light reflect the fog/snow which in turn decreases your ability to see. With the fog lights being mounted low (without headlights being on), it illuminates the road surface and not the fog/snow as much. It would be nice to be able to turn the foggers on with just the running lights on!
Old Oct 15, 2004 | 10:47 AM
kosh2258's Avatar
Integrated fog lights...
The design is a cost saving move by Honda.
Integrating the fogs into a single headlight/turn signal/fog lamp module reduces part count and simplifies vehicle assembly which reduces total assembly time and cost. Little things add up.
Old Oct 15, 2004 | 06:24 PM
Road Rage's Avatar
Not a Blowhole
It is illegal in many states to run fog lights with just the parking lamps.
Also, fog lamps in rain can cause more glare to you and others, since that bright light relfected back to your eyes from a short distance can cause the iris to close, reducing depth perception at distance.
I find they are useful mainly in heavy snow, where you want a low cut-off. But the TL headlights are so good, I'll bet they do fine in the snow. They are as good as the projectors in the S2000, but my garage queen has never seen rain, let alone snow. Sissymobile.
InFaMouSLink
Oct 27, 2015 06:51 PM
sockr1
Oct 1, 2015 01:31 AM
ellisd03tls
Sep 8, 2015 04:17 PM
cruisingnycfl
Sep 2, 2015 12:11 PM
prox
5G TLX Problems & Fixes
Sep 1, 2015 02:03 AM
