Flush and fill tranny fluid
Old May 29, 2012 | 07:58 AM
Bmore-Rhino's Avatar
Would you let Valvoline do that type of service for you or would this be something you would have a Transmission expert do for you?
Old May 29, 2012 | 08:11 AM
SharksBreath's Avatar
BANNED
could easily DIY with the right tools. i don't let anyone touch my car unless i absolutely can't perform the work myself. which luckilly hasn't happened yet.
do you know a trusted indy mechanic? i would go to someone you know rather than a big boy shop.
Old May 29, 2012 | 08:26 AM
yeah I don't have tools or the mechanical know how to do much.
Old May 29, 2012 | 08:56 AM
BANNED
alright do you know an indy mechanic? family friend? a buddy with standard tools?
just trying to help you save some money and get it done right the first time. it's an easy job.
Old May 29, 2012 | 09:43 AM
skadoo323's Avatar
There is a great DIY on the forum that may help encourage you to try it yourself. I never changed any vehicle fluids till I got my TL and the DIY surely made me try it. Be patient and don't rush.
As far as costs, since you don't have any tools you would have to invest in some, but if you plan on changing fluids yourself, you will easily recoup your costs.
Old May 29, 2012 | 09:56 AM
jda123's Avatar
Dogmatic Dinosaur
Valvoline could easily handle this, unless you have an oil jet mod blocking the fill plug and hole (2004). This issue is the fluid that they put in. Would they let you bring your own, or use a high quality fluid?
Old May 29, 2012 | 02:02 PM
SSMTL04's Avatar
Team SSM
I believe we're never suppose to do a tranny flush on our cars. You need to do a drain and refill...(3 times with 3 quarts each time). Search the fourm for 3x3 tranny. You'll find a lot of good information on it.
Old May 29, 2012 | 03:02 PM
pohljm's Avatar
If you do DIY which is a very easy task, make sure that you break loose the fill plug before you drain your fluid. You do not want to end up with a vehicle that has had the fluid drained but you cannot get the fill plug off! Emergency fill thru the dipstick is not fun.
Old May 29, 2012 | 04:27 PM
jda123's Avatar
Dogmatic Dinosaur
Good catch... yes, you need to drain and refill, not flush. It is actually easier than changing oil because there is no filter. Drain and refill with 3 quarts. I would see if they have Redline D4, AMSOil ATF or will use Mobil 1 Synthetic Dex/Merc.
Old May 29, 2012 | 06:04 PM
truonghthe's Avatar
just DIY it cheaper and way better because you know the job done right.
Old May 29, 2012 | 10:59 PM
Bruce Banner's Avatar
I drain and refill, supposedly flushing was not a good thing to do.
Old May 30, 2012 | 06:50 AM
myblack04tl's Avatar
I never fill my trans using the fill plug (can't with jet kit) I always use a long funnel and fill it thru the dipstick. It's easy and fast. I have done it at least 9 times
Old May 30, 2012 | 08:34 AM
lusid's Avatar
FTW
Whatever method you pick. You will need some type of breaker bar (make shift or legit), a socket set, flat head screw driver. And you are set. I have a video that I made on youtube from being to end which I can post but if you search under my name + transmission you will find it.
Old Jun 1, 2012 | 02:04 PM
JBONN's Avatar
Vegas Bum
Actually, you can remove the jet oil tube and it is probably easier than having to use a breaker bar to get the fill plug out (I have done both), you just remove 1 bolt securing the tube and pull it up and out of the transmission where the fill plug is typically located.
Old Jun 1, 2012 | 02:39 PM
cacicgt7's Avatar
Military Enforcer
How long does it take to get 3 qts down that?
Old Jun 1, 2012 | 02:47 PM
jda123's Avatar
Dogmatic Dinosaur
Where do you get a long, skinny funnel like that?
Old Jun 2, 2012 | 04:48 PM
pilozm's Avatar
i just had the dealer do it using the 3x3 method. $230.
not only was it expensive, but it was a bitch trying to describe exactly how I wanted it done. I had to show them the owners manual where is states how to do it properly. afterwards i checked and the fluid is very clear now. dealer had the car for about 3.5 hours, but they were very busy. If i had a place to do this, i would do it.
Old Jun 3, 2012 | 11:03 PM
DRS25's Avatar
M3RKED
Never flush. 3x3 redline D4
SidhuSaaB
May 30, 2020 12:40 AM
adrian_s2k
1G RDX (2007-2012)
23
Jan 12, 2016 04:25 PM
lanechanger
Oct 13, 2015 10:56 AM
xsilverhawkx
Oct 5, 2015 11:00 AM
hashbrown
Sep 29, 2015 12:13 PM
