Fair estimate for motor mount install?
Old Apr 12, 2011 | 08:40 AM
usmarinedelta's Avatar
I know someone that does side work at Acura and he quoted me $100 for the rear mount or $160 for all the mounts, is this worth it? I still have to pay for the mounts so this will be like a $400-450 job. Is it worth it to save $60 and do the front and side myself? Front looks cramped.
Old Apr 12, 2011 | 09:12 AM
libert69's Avatar
18psi
just remove the driver side radiator fan and the front mount slides out
Old Apr 12, 2011 | 09:23 AM
VQPower37's Avatar
its a reasonable estimate considering its a dealer, have u looked into private shops?
Old Apr 12, 2011 | 10:21 AM
No that's not the dealer price, it's a mechanic that works at the dealer, he does it when the dealer closes. Thanks libert for the advice. As for removing the driver side fan do you have enough room to move it out around the passenger side fan and radiator hoses?
Old Apr 12, 2011 | 11:06 AM
libert69's Avatar
18psi
im not looking under the hood right now but i dont think you can go that route b/c the precat is in the way. just loosen the 2 bolts under the car that hold the fan in place, unplug the connector and pull the fan up and out. remove the radiator hose and bend it out of the way.
Old Apr 12, 2011 | 11:32 AM
Thanks for the offer but my friend at acura is hooking me up with prices and the dealer is right around the corner. As for removing the radiator hose will alot of fluid leak out? So I assume I'll save $60 and do the front and side myself, hell I might even do the rear, have any tips on that?
Old Apr 12, 2011 | 04:30 PM
paperboy42190's Avatar
im pretty sure you dont need to mess with the radiator hose. i've done motor mounts before. just remove the radiator fans for extra room and then use a variety of extensions and sockets to get the front motor mount out.
side one, takes 5 min, self explanatory.
rear....PITA. unless you have some 24" extensions and a lot of patience, i would leave it to a shop.
Old Apr 12, 2011 | 09:27 PM
So you would suggest I spend the $100? I mean I have all day to kill and was going to tackle this for the rear. What's the hardest part about the rear, any tips?
Old Apr 13, 2011 | 12:45 PM
DimwitRj's Avatar
that ONE RED tl
DIY! Especially if you have all day to kill. $160 sounds like a reasonable price to have all 3 done though.
Feb 25, 2020 09:57 AM
wilztlxs
Dec 1, 2015 09:16 AM
BKSleeper
Oct 7, 2015 10:20 AM
mossman77
1/2G MDX (2001-2013)
18
Sep 16, 2015 12:21 PM
DiamondJoeQuimby
Sep 10, 2015 11:40 AM
