EVAP System is causing the Readiness Codes
Old Oct 19, 2018 | 09:54 PM
VictorTL's Avatar
I have this problem with the 5 blinking CEL when the stay at III position. The OBDII reader is showing that the EVAP SYSTEM is not complete or set and then I look a little deeper into the OBDII data it is showing the EVAP MONITOR has zero voltage. See the screen snapshot. What is EVAP MONITOR? Is it a purge control Valve solenoid ?
Old Oct 21, 2018 | 08:52 AM
VictorTL's Avatar
Is it normal for the EVAP SYSTEM VAPOR PRESSURE to Fluctuate between 65 and 0 inH2O when the engine idle or in drive?
Sam Spear
Dec 22, 2015 01:34 PM
bmxhed
1G CL Problems & Fixes
May 5, 2012 08:04 PM
737 Jock
1G RDX (2007-2012)
May 8, 2011 11:29 PM
KN_TL
May 11, 2007 09:00 PM
khoifl
Jul 28, 2005 02:34 PM
