engine light for several seconds after quick acceleration
Old Jan 26, 2005 | 01:04 PM
the other day i decided to hit the gas, and i was only playing around for like 1 minute when my engine light went on for about 10 seconds. i let go of the gas and it hasn't been on since. has that ever happened to anyone?
Old Jan 26, 2005 | 02:40 PM
rets's Avatar
Moderator Alumnus
Meathead, I remember you got 04TL pretty early, what's the last 5 digit of VIN? 14xxx? I thought you already have the ECU firmware flashed.
Whatever reasons are, you prolly have to check with your dealer. Wish this is the easy fix for them. Good luck.
Old Jan 26, 2005 | 02:50 PM
I had the same problem....just go to the dealer and tell them that your car needs an ECU upgrade...also, have them check the battery...i also had some voltage failure in my battery so they replaced that...so, no need to worry...once they do the ECU upgrade, you can accelerate as hard as you like and you won't see that sign come back (unless you really tear your car up, but that's a different story lol)...
Old Jan 26, 2005 | 02:54 PM
AcuraTL2k4's Avatar
You sure it was the check engine and not the VSA. If you were on it and the light was flashing your tires could of been slipping and your VSA would flash.
Old Jan 26, 2005 | 04:17 PM
yzfrebel's Avatar
I agree with Jinen. You need the ECU upgrade. I had the same problem about 6 months ago. Just make sure the dealer does it right the 1st time. It took them 3 times to get it right in my car.
Old Jan 27, 2005 | 09:28 AM
Chingrin's Avatar
Meathead
take it to your dealer and they will update your ECU...I had this problem and they fixed it pretty quickly.
Also See this thread
https://acurazine.com/forums/showthr...k+engine+light
Old Jan 27, 2005 | 02:29 PM
thanks a lot guys. yeah, it was an early 04, like Jan 04 i think but this is the first time this has happened. i'll be letting the dealer know...
Old Feb 4, 2005 | 11:07 PM
jobes's Avatar
Team Nighthawk-C.M.A.
My light came on today as it has before during hard driving. But today it’s stuck on. Anyone have that happen?
Old Feb 5, 2005 | 12:16 AM
gbriank's Avatar
Does your dealer have Saturday hours? I'd take it by this morning to get it checked out!
Old Feb 25, 2005 | 05:09 AM
omegavi's Avatar
Exclamation Same issue
I've had this light problem for months now. The dealer says they cant even get a code out of it since the lights not on anymore. My dealer assures me that my ECU does have the most recent update. And since they cant get a code they dont know whats wrong. Well after months of flashing and going off, now it stays on. Everytime after hard accelration it flashes but stays on. So i finaly got it to a dealer with the light on and said here dumbass now fix it. So they checked it out and ordered a crank shaft position sensor. They said the code was for a misfire but they have seen this problem before and this should fix it. I go back on Wed next week to have it installed then we'll see. But for all you guys that are just saying have your ECU reflashed, there might just be something more to it!
Old Feb 25, 2005 | 06:44 AM
rbf351's Avatar
Registered User
this used to happen to me in my CL, if i would floor it in 1st gear and the car lost traction for more than a few seconds the check engine light would blink. basically since the wheel hop is so bad the car actually thinks there is a misfire, thats why your light is coming on
Old Feb 25, 2005 | 11:13 AM
TheOne305's Avatar
my check engine light blinked for a few secs when i started to accelerate hard from 35mph last week.First time it did that since i bought the car in May,04.So far it hasnt done it again.
MikeYutkin
Sep 10, 2015 10:13 PM
Bahamanurse1
Sep 10, 2015 10:05 PM
HeloDown
Sep 8, 2015 06:51 PM
bryan zaragoza
Sep 8, 2015 12:28 AM
whitesoxsfan12
Sep 7, 2015 04:07 PM
