Engine Light?
Old Sep 10, 2004 | 04:57 PM
nirmul's Avatar
Engine Light?
Is it normal for the engine light to flash under hard acceleration?
Old Sep 10, 2004 | 05:19 PM
rets's Avatar
Moderator Alumnus
Welcome to the forum
No. It's abnormal.
But, usually 04TL's MIL (check engine light) could be caused by the minor errors, this is quite common issue by 04TL so far. Check sticky thread Garage for further info. Thanks.
For safety concerns, please check with your dealer soon.
Old Sep 10, 2004 | 05:26 PM
JoganJani's Avatar
never stops!
Also, check your fuel door / cap if it is not properly closed or tighten?
Old Sep 10, 2004 | 05:43 PM
Lore's Avatar
CEO, Team Anthracite
If your car is an early build (say, sometime before 2004) it might need an ECU update from the dealer which fixes the timing of the engine. I remember test driving a car at the dealership, pushing the accelerator hard, and seeing the flashing engine light.
Old Sep 10, 2004 | 05:59 PM
dwcolt's Avatar
Holy Shit! That is the "pre-burst" head gasket warning. The situation is particularly troublesome in the TL because as a result of the engine placement, the drivetrain can pierce the firewall, penetrate the cabin and cause the headliner to fall. You should have this checked out immediately.
Old Sep 10, 2004 | 08:12 PM
pettydw's Avatar
Traction control ! is not unusual during hard accels. Some folks report engine light due to less than 91 octane fuel at high rpm's. Also, the ECU software upgrade is a published SB on older VIN's.
MikeYutkin
Sep 10, 2015 10:13 PM
Bahamanurse1
Sep 10, 2015 10:05 PM
HeloDown
Sep 8, 2015 06:51 PM
bryan zaragoza
Sep 8, 2015 12:28 AM
whitesoxsfan12
Sep 7, 2015 04:07 PM
