Engine Block Heater
Old Jan 23, 2004 | 05:26 PM
greenseed's Avatar
Engine Block Heater
Does anyone know if theres an engine block heater avaliable for the TL?
Old Jan 23, 2004 | 05:32 PM
Nitrotiger's Avatar
yes there is acura has that option from the dealer goto the website you will se it listed
Old Jan 23, 2004 | 06:28 PM
greenseed's Avatar
Looks to be 59.00. Anyone know how much installed? Also is it worth having?
Old Jan 23, 2004 | 08:24 PM
rets's Avatar
Moderator Alumnus
Re: Engine Block Heater
Is that just a piece of stuff we can install/remove anytime?
Old Jan 23, 2004 | 10:10 PM
drw1926's Avatar
I can't speak for it from a TL perspective (don't own one yet), but being from Detroit originally, I have a lot of experience using engine block heaters. I have owned all Fords previously, and they have always offered a factory-installed block heater as an option. All I can say is, that is the best $59 you will ever spend. Just run an extension cord from your garage or wherever, and leave the plug for the block heater accessible in such a way that you don't have to open the hood every night to plug it in during the winter time. You can leave it plugged in all night, it has a thermostat so it won't overheat your engine or anything like that. Go out to start your car in the morning in -20 deg, you can feel the heat on the top of the motor. You will have heat coming out the vents within the first mile! Good stuff.
BTW rets, you can't really remove/install it...well you could...but you wouldn't want to, nor do you need to. In the summer time just cap the plug and stow it (the cord) up out of the way in the engine compartment.
Old Jan 23, 2004 | 11:25 PM
rets's Avatar
Moderator Alumnus
Thanks for explanation. It's kind of hard for ppl not living where below -20 all winter to think of how this block heater stuff works. Originally I thought it's only the "BLOCK" putting in front of the engine or radiator... as you said, $59 seems to be the good deal. :o
Old Jan 24, 2004 | 07:17 AM
greenseed's Avatar
I was just thinking of having it installed if nothing else just for saving the engine a little bit on these single digit mornings we've been having lately. Granted we don’t get -20 below, but for the price I think is a no-brainer...
Thanks DRW1926
Old Jan 24, 2004 | 08:47 AM
One thing to keep in mind, according to the install instructions, they cut a slice out of the grill to pass the plug through. This may be a good one to self-install and find some other way.
Old Jan 24, 2004 | 09:15 AM
greenseed's Avatar
I couldn’t find install directions for the new TL, but i found some for an '03 RSX. Now I'm sure that the install is somewhat similar, but I know for sure that the RSX instructions were not showing any body modifications.
The RSX install was pretty much draining the radiator core, pulling off this "heater plug place holder" in the engine bock. More engine coolant comes out at this point. Installing the Acura engine block heater, attaching OEM plug to the heater and routing the 120v plug to front (in a nutshell).
Old Jan 24, 2004 | 09:24 AM
Check out
http://h-o-n-d-a-c-u-r-a-w-o-r-l-d.h...structions/tl/
(w/o the dashes)
And download the instructions
Old Jan 24, 2004 | 09:34 AM
greenseed's Avatar
Look's like the URL got edited down. Same thing happened to me in another post. It's ashamed that this forum is filtering out competitors in both “forums” and parts.....
Old Jan 24, 2004 | 09:40 AM
Try http://haw.hostasaurus.com/Merchant2/instructions/tl/
Use the dashed thingy above for haw.
Old Jan 24, 2004 | 09:44 AM
greenseed's Avatar
Woodstock.
Thanks. I got a bunch of .pdf's from that first site you listed.
G.
Old Jan 24, 2004 | 09:52 AM
theslik1's Avatar
whut
It's been over 20 years since I lived anywhere a block heater would be necessary, but here's my advice...
"Get it now"
Best $59 you'll ever spend. If you've ever listening to a cold engine block heating up from 0 degrees and below, you'll buy it without hesitation.
Old Jan 24, 2004 | 10:09 AM
Originally posted by greenseed
Woodstock.
G.
Yea, I downloaded them all. I probably won't install many things myself. (ok, maybe the trunk tray), but I like to see how involved the installation is. The small spoiler, for example, I was surprised to see it wasn't just adhesive (similar to body side moulding)
Old Jan 24, 2004 | 10:35 AM
greenseed's Avatar
I probably won’t either, I just want to see what's involved with installing those items. For example on the installation of the block heater. I think I'll tell them to NOT cut out a small piece in the front grille portion. I'd rather reach under the car to plug it in, then to have it prominently on display all year.
Old Jan 24, 2004 | 10:47 AM
vtechbrain's Avatar
For 8 years I have lived in MN and WI as you know it doesnt get much colder than that. I have had 3 cars with block heaters. I have used the device a total of one time, to start my civic in Jan. after sitting out in 0 or less weather for 30 days. If your car is garaged you'll never need it. If it sleeps outdoors for a couple of days you might use it. IMO people that have garages up here have no use for it.
Old Jan 27, 2005 | 12:54 PM
onalake's Avatar
I'm having one installed and total cost is $249 for part and most of that for the labor. It's not the cheap kind that goes in with your dip stick. They put it in a plug in the engine block itself.
Old Jan 27, 2005 | 02:26 PM
fasttl's Avatar
Sorry to tell you but they really ripped you a new one. The part costs about 50 bucks and usually takes less than an hour to install. BTW, all honda heaters go attached to the engine block. I'd go to the installer and demand at least 100 bucks back.
SidhuSaaB
May 30, 2020 12:40 AM
joflewbyu2
Oct 8, 2015 11:16 AM
ROSSARONIE
Oct 2, 2015 11:46 AM
TL14
Sep 24, 2015 04:37 PM
STL TL-S
Sep 23, 2015 08:52 PM
