dose anybody got this problem with 04 tl?
Anybody got the problem with the ignition?
sometimes i cannot startup the car very well.... (i have to start twice or three times...)
Any advice???
Any advice???
Refer to this thread, or the TL Garage for more info.
http://www.acura-tl.com/forums/showt...light=starting
Originally Posted by AcuraVic
it happened twice in the first 2000 miles. After that, never again. I believe others have stated this problem when the car was under 1500 miles. How many miles do you have ?
"it will be fine in summer ~ that is totally different feeling in summer... "
but i didn't see any difference...
Originally Posted by mio
i got 14000km ... it happens offten... i asked the dealer in this June... they just said..
...Automata:
I aim to please...
This is mentioned in the quick-start guide (which I don't have with me at the moment). It says something to the affect "Sometimes it may take longer to start because of the emissions system". Is it starting and then stalling?
My car has done this once -- it cranked much longer than I expected, and I'm betting if I had stopped cranking it wouldn't have started.
Not sure if it says it in the garage section, but if you turn the key to the ON position (when all electric is on and gauges go up) and wait till the beeping stops, you should have no problem starting it. It almost has to charge up it seems. It has to do with emissions and the high standards Acura has met with this car. If you have ever seen the exhaust when a truck starts up, you understand.
if someone's chasing me and trying to kill me, i m gonna die because i cannot start the car in time... lol
For those too lazy to read the other thread or their manual:
Automobile engines produce the most pollutants when they are started. In order to minimize this, Honda did some stuff I'm too stupid to understand. But the end result is that sometimes the car won't start right away.
It is just a result of trying to keep emissions low - ULEV II.
Originally Posted by achonda2_4
My advice is to get some good ground wires.
http://www.acura-tl.com/forums/showp...87&postcount=5
Another possibility could be what everyone else has claimed - that this is part of the ULEV-2 design. As the outside temperature gets colder, cars normally produce more pollution until the engine has warmed up to it's normal operating temperature. Honda's modifications to reach ULEV-2 may have the occasional side effect of having the car miss on starting. Well, worth the small inconvenience, IMHO.
I personally have only had it occur once in 13,000 miles. I also live in a warm climate throughout the year.
My advice would be: If you are seeing this occur once a month, don't worry about it. If you are seeing this occur multiple times a week, you should bug the dealer and have them connect up the car diagnostic system to see if any error codes are being registered.
SidhuSaaB
May 30, 2020 12:40 AM
Fool
Mar 10, 2016 08:42 PM
