Problem Noise
Old Aug 24, 2004 | 11:30 PM
mbredehoft's Avatar
OU Football Fan
Problem Noise
Description of Problem:
1) Only happens once. When the car is cold.
2) Hear and Feel a "THUNKING" sound. Feel it through the gas pedal and under floor board. Drivers side.
Car is 6 weeks old with 2000 miles
What usually happens. Back out of garage. Put car in drive and as I roll forward lets say around 10 feet I hear the THUNK. It will not happen again until the car sits for at least an hour and is basicly cold. I can stop and go no problem until the car sits. Dealer can't really figure out the problem because you can't duplicate the problem over and over.
I thought it might be the cable to the gas pedal. Dealer doen't think so. Thinks it is more suspension. They are e-mailing Honda Engineers and asking them.
Has anyone ever heard of this problem?? HELP
Old Aug 24, 2004 | 11:42 PM
sparkz's Avatar
Surprisingly, this is normal as its the ABS self test. Its covered in this thread http://www.acura-tl.com/forums/showthread.php?t=85426
Old Aug 25, 2004 | 12:04 AM
Scuba629's Avatar
Old Aug 25, 2004 | 07:30 AM
rets's Avatar
Moderator Alumnus
Wish Garage would be your friend...
Old Aug 25, 2004 | 07:40 AM
blktl1's Avatar
I get the Same thing. It is when I first put it in first gear and start to move. The dealer said that it was normal and it is the brakes.
Old Aug 25, 2004 | 08:31 AM
rets's Avatar
Moderator Alumnus
Imho...
Lots of tiny noise comes out of this car. Not bad things, but annoying if you don't know what they are. You have to identify and define the noise level and describe how it sounds like.
Our brakes will also make noise insides and outsides. 5AT tranny will make noise when shifting. ABS will make noise as the ppl said above. More...
Old Aug 25, 2004 | 09:06 AM
Champcar1's Avatar
There is no cable to the gas pedal. This car has a drive-by-wire throttle. I can't believe your dealer didn't mention that.
I agree it could be the ABS self test.
Old Aug 25, 2004 | 09:30 AM
mbredehoft's Avatar
OU Football Fan
Drive by wire
actually they did. But I the truth is there is a wire from the throttle into the engine compartmant to a solenoid and then drive by wire to another solenoid then to the carb.
snorf
Nov 4, 2019 06:44 AM
real_mckoy
4G TL Problems & Fixes
Sep 25, 2015 10:49 PM
njresendez
Sep 21, 2015 11:23 AM
iCrap
Sep 11, 2015 06:21 PM
Mike Bertram
Sep 10, 2015 09:27 AM
