door handle pieces
door handle pieces
the door handle piece where the key hole would be........ has anyone else had a problem with these coming off? ive had 3 get real loose in the past month and a half but luckily i saw them and just plastic epoxy'd it.
SSM Sport Shifting
I had one that did the same thing & it was because I took it
off & broke one end of it. Not sure what you did but you can
always order another one.
AZ Community Team
Received 7,770 Likes
So many people have this problem, there is a TSB for it:
TSB 07-043: Outer Door Handle Extension Falls Off
http://www.in.honda.com/Rjanisis/pubs/SB/B07-043.PDF
where can i order one of these on line? my dealership is like 20 miles away
i looked at some other threads and tried looking on the sites they suggested, however i have found nothing.
![ugh](https://acurazine.com/forums/images/smilies/ugh.gif)
AZ Community Team
Rear item 22/33: http://www.acuraautomotiveparts.org/...s=&view=normal
Front item 28/32: http://www.acuraautomotiveparts.org/...s=&view=normal
After fees, shipping, etc, it'll costs as much or more than just getting it fromthe dealer. 20 miles is nothing. Call the parts desk and order, then you just need to worry about picking it up.
AZ Community Team
http://www.acuraautomotiveparts.org/...arch=&ListAll=
Then choose the system:
FRONT DOOR LOCKS-OUTER HANDLE and
REAR DOOR LOCKS-OUTER HANDLE
Part numbers should be the same for all years though.
wow amazing, i was just gonna post this too, my back driver side is loose, but its still hilding in place, hasnt fallen off yet.
is this a DIY? or can i bring it to the dealer to glue on?
i cant get to those links, is it normal?
With the TSB the dealer should do this for free, if you car is under warranty. I did the shaved door handle and it cover was metal. Heavy and very sturdy. The covers just snap in and they have a small release tab. Pull your door handle and you can see it in there. Not sure why they are falling off. I've had no issues.....
AZ Community Team
To replace the base and the cover you have to remove the interior door panel.
SUPRMN84
10-07-2015 09:46 PM
