Does my Alarm Work?
Old Dec 20, 2006 | 10:55 PM
Dr.Decoy's Avatar
Thumbs down Does my Alarm Work?
When i lock my doors with the remote, the doors just lock, no flashing lights, no honks, no beeps. I set the car to beep by the controls in the keyless settings. Any one have any suggestions? I was wondering if the alarm was cut before i bought it used.
Old Dec 20, 2006 | 11:06 PM
CAB NY's Avatar
Tri State ViP Crew
sit in the car lock the door with the remote wait about 30 sec then open the door with the lock nob see what happens or start the car
Old Dec 20, 2006 | 11:26 PM
Dr.Decoy's Avatar
that did not set off the alarm. something else i noticed was that by the stick lock the security light was not flashing, ever.
Old Dec 20, 2006 | 11:39 PM
dz06tl's Avatar
After the doors lock does the car beep if you press the lock button again? (it's not a loud beep - after the first lock the car beeps on each subsequent push of the lock button that happens within 5 or 10 seconds of the first one)
Try this: open a window, exit the car, close the door, lock the car with the remote, keep the remote away from the car, reach in and manually unlock the door and open it . . . . this should set the alarm off (maybe before there is some sensor that picks up the immobilizer chip in your key) . . . . .
Have you tried pressing the panic button on the remote to see what happens?
Old Dec 21, 2006 | 01:20 PM
LSIII's Avatar
Check the hood....Had a one time issue where the hood was closed, but the switch was acting weird and thought it was open, so it wouldn't arm or anything. Opened the hood and then closed it back and it cleared itself up.
Old Dec 21, 2006 | 02:18 PM
Desert_TL's Avatar
Open and close the hood nice and hard. Also open and close your trunk. Then try it.
Old Dec 21, 2006 | 06:32 PM
mr_clean's Avatar
something is not closed all the way.. like your hood or trunk..
Old Dec 22, 2006 | 01:44 AM
A SiQ TL's Avatar
I knew the trunk made it do that. Didn't know about the hood though
Old Dec 22, 2006 | 03:45 AM
Dr.Decoy's Avatar
The panic button doesn't work, and the window open, and open car from outside doesn't work either. But on another note, when i'm in the car, and its on, it still will detect correctly when the truck or hood is open.
So here is the problem. When the car is off and locked, it doesn't beep even thought the option is set no matter how many times i lock the doors with the remote, and also the stick lock security light doesn't blink, and also panic button doesn't work...
Thank all you for your time and help!!!
Old Dec 22, 2006 | 06:41 AM
trancemission's Avatar
Regions Leader
Hmmmm, I dont know man, sounds like you need to go to the dealer....
I had a similar issue and it ended up being the hood....
Old Sep 9, 2007 | 07:12 PM
pickebicke's Avatar
any one know why the security light by the door lock constantly would stay "ON" no matter if the alarm is armed or disarmed? the led stays on even when the ignition is on. anyone why this would be?
Old Sep 9, 2007 | 09:04 PM
csmeance's Avatar
it should be blinking when armed and should be off when the car is on. you may have a bad door lock assembly on the driver door or a bad alarm unit
Old Sep 9, 2007 | 10:00 PM
godizus's Avatar
Needs wheels
Maybe the light stays on as an indicator, meaning that there IS a problem with the system
Old Sep 9, 2007 | 11:22 PM
LDai1219's Avatar
It actually does work. When i first purchased my vehicle i thought it didnt either. I tried sitting in the car after alarm activated and then open it, nothing happens. But recently for some reason when i sit in the car for a while, and i tried opening the door, my alarm would go off.
Old Sep 10, 2007 | 12:19 AM
pickebicke's Avatar
well, on mine the LED on the door just stay ON no matter what, but everything works like normal. can anyone check the manual to see what might be the problem? i'm selling the car soon and all of a sudden i get this problem. please help. thanks in advance.
Old Sep 10, 2007 | 12:21 AM
csmeance's Avatar
Theres a link in the 3G garage to all the digital files of the car manuals. As well, if the car is under warranty, get the alarm checked out and other issues so the buyer can be more secure and happy that the car has been maintained.
Old Sep 10, 2007 | 12:25 AM
pickebicke's Avatar
do you have a link to the car's manuals? it is an 04, and out of warranty.
Old Sep 10, 2007 | 12:03 PM
Will Y.'s Avatar
Registered but harmless
Welcome to AZ.
The owner's and navigation manuals are linked from the 3G Garage to: https://techinfo.honda.com/rjanisis/...01_OMANUAL.asp
I don't think shop manuals are available, but you might try a search of the threads for the alarm issue and maybe door alarm light swap to see if there are any diagrams or photos. G/L!
Old Sep 10, 2007 | 11:04 PM
pickebicke's Avatar
couldn't find any info on the eom factory alarm. is there a fuse? where are the alarm components located? does the 2 wires that go to the door led have constant voltage or does it only have voltage when the alarm is on?
Old Sep 12, 2007 | 10:14 PM
pickebicke's Avatar
anyone?
Old Sep 12, 2007 | 11:31 PM
6spMike's Avatar
Mike's Silver Bullet
Does the horn work?
Maybe it's not the alarm system per se.
Old Sep 13, 2007 | 12:14 AM
pickebicke's Avatar
yes the horn works. everything works as normal, just the security led on the door is constant on and the 2 wires that connect to that led is 12v constant.
mada51589
Jan 9, 2025 04:40 PM
spidermankb
Mar 5, 2019 11:34 AM
acurajj
Sep 19, 2015 03:47 PM
Luis J. Rodriguez
Sep 12, 2015 10:00 PM
ahsm
Sep 9, 2015 08:35 AM
