does heat side mirror botton have light or not?
just find that heat side mirror botton do not light up at night, is this normal or this is the light bulb burn out?
Be very careful if trying to modify this switch. Replacing the bulb for the general switch illumination is not that bad--Remove the lower dash section, unplug the connectors (there are 4 total on both sides of the column) and the mirror control unit pops out. The bulbs can be replaced with a small flathead screwdriver.
The LED that lights in the heater button is a whole different animal and requires complete disassembly of the unit to replace. You are better off spending the $45-50 for the replacement unit, if it bothers you that much. Part # 35190-SEP-A11
cycdaniel
12-17-2019 10:58 AM
rockyboy
01-25-2016 06:00 PM
sockr1
10-01-2015 01:31 AM
