DIY: Window visor
Old Apr 27, 2010 | 03:58 PM
ze2o's Avatar
DIY: Window visor
didn't see a diy with actual pic so here it goes. this is oem purchased from acura dealer so installation might be different from ebay's or weathertech. sorry for the crap pic since i don't have a cam anymore. i learned a few dos/donts on the way so flame is unnecessary. the visors can't be mixed and matched since length and direction is exclusive for each window, common sense here.
make sure you do this when it's dry and warm and no water contact within 24 hours after installation to give the adhesive plenty time to cure and settle.
wipe down visible dirt with a soft dry towel around the installation area first. drop down the windows all the way. pull the weather/door guard/stripe/rubber piece out lightly. made a mistake here as you don't nee to pull everything out, just enough so the clips/hooks on the visor can hook on
find the correct visor for the door, peel off the adhesive cover at the ends only, less the better so adjustment can be made once you first attach the visor. fold the cover back slightly so you can reach it once visor is installed temporarily
wipe down the shinny, black, reflective pillar (where the visor tape will attach to) with an small alcohol pad to remove all the little crap.
install the front visors from the mirror to the center of car (mirror clip, 2 over hanging clip, 2 underneath clip)
install the rear visors from the back of the car to the center (1 overhang clips, 2 underneath clips)
always install the overhanging clips first
there is a small protruding plastic tab which need to be inserted behind the mirror assembly first. then clip on the first 2 "overhanging clips". then push in the last 2 "underneath clips". common sense here as well.
you can see the 2 overhanging clips here, clip them on. A mistake here is that i pulled too much of the weather stripe out as you can see. you don't need to remove it from the plastic spinning retainers. now you need to push the remaining 2 underneath clip into the weather stripe track (no pic, too dark). now adjust the visor for perfect fit (make sure it's aligned nicely and it's evenly spaced all around)
once you made the final adjustment, pull the tape cover slowly to expose all the adhesive. there is no going back here as the tapes are very strong. now press the visor with firm and steady force against the door frame to initiate bonding. i rested my forearms across the visor for about a minute. make sure every inch of the tape is stick onto the trim.
now put the weather stripe back, make sure it's completely back into the original groove/track. then do a final wipe down with DRY soft towel
same thing for back but just much easier, make sure you follow the same steps but install from back of car to center of car
the alignment, left is rear, right is front
finished product. to a final DRY wipe down to remove any dirt and fingerprint.
took me about 1 hour since i had no clue, but should take you 30 min max. diff level 2/10. ask if you got ?s
Old Apr 27, 2010 | 06:01 PM
gatoferoz25's Avatar
nice
Old Apr 27, 2010 | 07:52 PM
kazonerx3001x's Avatar
Thank you OP. That's a great writeup. I'll be sure to use your advices once I pull the trigger on the visors.
Old Apr 27, 2010 | 08:23 PM
Sound Murderer's Avatar
New York state of mind
i just installed mine the other day and pretty much guessed haha
good write up though dude, im sure some n00bs will use it
Old Apr 28, 2010 | 06:37 AM
BigJLM1's Avatar
Great write up !!! I called Acura to installed mine, they said $120. I was like no thanks. Then I spoke to one of my friends and he installed it free of charges. Took less less 10 minutes.
Old Apr 28, 2010 | 08:14 AM
dadon's Avatar
looks nice,
Ill be using this
thanks
Old Apr 28, 2010 | 05:39 PM
dwb993's Avatar
Acura's installation instructions are posted in the 3G Garage for more info:
https://acurazine.com/forums/showpos...96&postcount=1
Thanks for the writeup OP!
Old Dec 5, 2011 | 09:24 AM
jmercado23's Avatar
Great write up. Made my life a lot easier
Old Feb 15, 2012 | 09:30 AM
rockstar143's Avatar
Now that I tried out the weathertech ones and liked how visors looked, I pulled the trigger on the oem ones. I will surely use your tips to install mine this weekend. Thanks for the write up!
Old Feb 15, 2012 | 11:06 AM
kane337's Avatar
2007 Acura TL
Awesome. Thanks for this. I will be using this to install mine.
Old Feb 15, 2012 | 11:55 AM
13lank's Avatar
Great write up! Thanks!
Old Feb 15, 2012 | 01:17 PM
sunny201's Avatar
A J35A8 EG civic is in
I should put this write up to use and put them on. They been sitting in my garage for months
Old Feb 15, 2012 | 04:02 PM
El Hefe's Avatar
Looks good. Can't wait to order me a set!
Old Feb 15, 2012 | 07:05 PM
Ha...this thread was dormant for a year! Guess there were a bunch of people waiting to install this!
sunny201, c'mon, you don't want to install these...you wanna sell em to me for 1/2 price! I know it!
J.
Honestly was ALWAYS against visors...but now that I've had them, the car looks naked without em.
Old Feb 15, 2012 | 09:23 PM
ABP_04TL's Avatar
6-SPEED LOVER
Nice DIY OP!!! Def need it for mine, gettin them when i get the wheels
Old Feb 15, 2012 | 09:37 PM
Will1688's Avatar
i picked up a set used, meaning there was no more adhesive.. anyone know which specific type to buy to replace that? 3m? what kind? thanks
Old Feb 15, 2012 | 09:41 PM
dontTL'em'nothing's Avatar
riding low and steady
way to bring it back from the dead rockstar lol. but it was a useful bump.
Old Feb 16, 2012 | 09:42 AM
in the 80's, a "useful bump" had a whole other meaning.
will...yes, go to autozone and look for the silver 3m stuff...it's super strong and meant for install for moldings etc...easy to spot, it's got a red backing...
now that I think about it, I bought a 15' roll from amazon for $6 rather than the 5' roll for $9 at the parts store. Look into it.
Old Feb 16, 2012 | 12:23 PM
kane337's Avatar
2007 Acura TL
For those of you with the OEM window visors......do they make extra whistling type sounds at driving speeds compared to not having them?
Old Feb 16, 2012 | 01:00 PM
no way, even my weathertech ones didn't do that.
but these, with the way they are designed and the double sided tape, air isn't going to whistle through...
at least I HIGHLY doubt it
Old Feb 16, 2012 | 01:14 PM
yah yah's Avatar
looks good. i needed this just bought new ones
Old Feb 18, 2012 | 10:10 AM
instructions came in handy, thanks again!
Old Feb 18, 2012 | 11:39 AM
ABP_04TL's Avatar
6-SPEED LOVER
Rockstar ur car is on fuken point!!! Damn that NBP looks clean
Old Feb 18, 2012 | 12:47 PM
ABP, coming from you, that is quite a compliment...I'm SOOO blushing right now.
J.
LOW how the oems look, I really do...the weathertechs were good too, but the rears flow much better and I do like how they are not in the way of the glass here.
Old Mar 12, 2012 | 02:29 PM
elpicu23mj's Avatar
8th Gear
I'm going to pull the trigger and buy the oem visors, they give the car a nicer look. Once I get them, I will surely follow your instructions, thanks for this post!!!
Old Jun 27, 2012 | 07:29 PM
DC2many's Avatar
Is it normal that my upper clips are visible and under clips kinda bulge out the strip on the bottom
Same fate as my hondaaccess for my dc2
Old Jun 27, 2012 | 09:04 PM
Yes sir, totally normal...but it should not be TOO obvious...
update, still lookin good!
although not that obvious in this pic
Old Jun 27, 2012 | 09:17 PM
dwb993's Avatar
Damn, J. That is one pretty shot!
Old Jun 28, 2012 | 03:40 AM
DC2many's Avatar
Thanks for the response but,I seem to end up with the same problem as my integra. Noticed my tint at the upper window edge got mild fuckage possibly due to the friction points and that the bottom clip area has mild bulge
I also noticed with the windows closed up there was some mild rattling, could have already been pre-existing rattle but driver side never had any before but is very minimal.
OEM honda access visors btw
and your car is a rockstar
here is mine but no close up
sometimes i'm not too sure about the visors other times all for it
Old Jun 28, 2012 | 06:23 AM
Dave, thanks man!
DC2...hmmm...funny, if you go back to my first 2 years on the site I am very ANTI visors...i got a killer deal on some weathertech ones....liked them on black on black...then got oem.
I've often thought they'd probably look good painted to match the car! I think they look great on your car...the bulge is definitely there for me...but I must be used to it because it doesn't bother me. Thanks for the compliment too.
Old Jul 17, 2012 | 05:37 PM
Redbirds11's Avatar
great writeup, just used it on my whip. thanks again. I see really light scratches or scuffs in the plastic(only when you get really close up to it), what do you clean these things with so they dont get so scratched over time? is it because its plastic or do i just need to wax the visors or something as well? J your car always looks so clean im so jealous it only has 85k and is 4 years older then my car, i almost have 74K. boo.
Old Jul 17, 2012 | 07:16 PM
LOL...how you know my dang mileage!
Congrats, Cory...post up a picture, man...I do love how the visors look on the car. Honestly, when I wax, I put a coat on them too...you always see the cheap knockoffs getting sunbaked and cracking over time, which I want to avoid.
Old Feb 18, 2013 | 12:25 PM
lowchef's Avatar
Just got my oem visors and will be using this install once it warms up outside a Lil.. Nothing worse than when after its rained and u get in and cracked window then turn and water pours all over instrument panel on door
Old May 7, 2013 | 08:26 PM
alexDC2's Avatar
6th Gear
wow you TL is awesome !! so damn shinny and seriously with the window visors its gives a totally other effect to you car, nice ride man!
AlexDC2 ~
Old May 8, 2013 | 09:38 AM
The more I see the visors, the more I realize I'm only okay with them on a black car since it doesn't add another color to. I actually used to hate all window visors...
So racist of me...
here's a shot of mine, still going strong...
http://www.flickr.com/photos/rockstar143/8715309153/http://www.flickr.com/photos/rockstar143/8715309153/ by http://www.flickr.com/people/rockstar143/, on Flickr
Old May 8, 2013 | 10:36 AM
ertpecs's Avatar
dave
looking good
Old May 8, 2013 | 10:53 AM
Undying Dreams's Avatar
whore
Old May 8, 2013 | 02:16 PM
hmmm...what's a good name for someone that'll be cutting open their own tail lights?
Old May 8, 2013 | 02:17 PM
A professional modder
Old May 8, 2013 | 02:27 PM
Austin: THE Professional Modder.
