DIY: Steering wheel emblem replacement
While doing a steering wheel swap, and given the only documentation on this is Youtube I thought I'd give it a write-up.
While this is a lot more time consuming I think it's better then sawing off the emblem with steering wheel on since the emblem is melted in place.
Materials Needed
Instructions
Bonus Round
Good luck! Follow me on my instagram: https://www.instagram.com/melon_tl/
Materials Needed
- Steering wheel emblem, this fit the 07-08 but fits lot of models according to listing - Ebay Link Here
- A pick or a small flat head
- JB Quik Weld or any epoxy glue that can withstand hot interiors -
- Recommended: Ratchet screw driver
Instructions
- Remove airbag from car using these instructions - Click here
- Remove these philips screw, I recommend a ratchet screw driver because they were on a little tight
- Pry up gently these white caps
- Use a pick or flat head to poke these tabs loose for the bottom white cap here
- Now we need to separate the plastic tabs holding the airbag, shove a flat head on the back and just pry out, theres 3 tabs on each side. Put airbag on something soft so you dont scratch up the front
- Now lift the airbag bottom up, there's hooks up here in red that will just slide out of the plastic cover, no need to pry hard here.
- Now you'll have the airbag and plastic cover separated, and see all the melted plastic tabs the old emblem has
- Use some wire cutter or your weapon of choice to get under these melted tab heads and snip them. I was doing it the hard way but you can fit under these blobs and cut the heads off
- Test fit your emblem, and see which tabs you need to cut. If you are skilled in vinyl, now is a time to wrap this section for a CF look
- For me, I needed to cut the 2 o clock and 7 o clock tabs, but double check by placing new emblem in the holes and see where it's not slotting in first! emblems can be different
- After I had it all fitting nice, I trimmed the tops of the tabs because they were a lot longer then OEM, trim just a little
- Wipe down the entire area with rubbing alcohol
- Mix epoxy and rub it into all the tabs and hold in place till try or clamp
- This is what you should be left with. It'll fit only as good as you holding it place while epoxy dries. Even mine isnt 100% flush but I accept it for what it is
- Reassemble the airbag
- Reinsert the bottom clips back in first
- Clip back in the 6 tabs
- Pinch the spring and try to get it to seat around all 4 of these little retainer tabs
- Make sure these little vertical tabs are sitting outside the spring and NOT under the spring like this.
- Pop the top cap back in and bolt
- Do one last check of everything
- All springs seated
- All top and bottom white plastic caps are in
- All 6 side tabs are in
- Top two hook/tabs are in
- Tighten the side bolts as far as you can snug, bottom one doesnt need to be that tight because if you tighten too much it'll ground the horn and the horn wil be on ALL THE TIME
- Not bad for little work
Bonus Round
- Experimenting dechroming the original emblem, might be useful for someone that doesnt want to buy a new emblem.
- Just pour bleach in a cup and toss the emblem in for 12-24 hours--it should dechrome the emblem. Keep out of reach of children, pets...and put in WELL ventilated area.
- After dechroming--just primer and spray paint black/silver
- You can then reepoxy the emblem back in like how I did above--there should be enough back tabs to reuse the emblem
- I just did this so not sure how well it'd work. I did this a decade ago to some Accord emblems and it stripped it clean but started to eat the plastic underneath so should watch it
The following 9 users liked this post by DesertMistTL:
04WDPSeDaN (01-19-2021),
Acura TL Builder (09-08-2022),
BROlando (09-08-2022),
csmeance (01-20-2021),
Curious3GTL (01-21-2021),
and 4 others liked this post.
The following 2 users liked this post by Midnight Mystery:
DesertMistTL (01-19-2021)
The following 2 users liked this post by wusty23jd:
DesertMistTL (01-19-2021),
Rende_WDP (01-19-2021)
9th Gear
Awesome write up man! Never knew the airbag could come apart like that but it would've made my life a lot easier when I pried mine emblem off from the front lol. Wish AZ was still popular like it was back in the day for the 3g TL. Hopefully it can make a comeback.
The following 2 users liked this post by o4Komodo:
Is there another way to find the link to the emblem. I'm trying to replace one on my 05-08 Acura RL
ryanbtl
01-19-2021 03:36 PM
tkosho24v
3G TL Photograph Gallery
08-13-2019 06:09 PM
