diy aspec???
Old Feb 27, 2009 | 03:57 PM
HaRDbODyTL's Avatar
diy aspec???
idk y but im having a hard time finding this DIY...my kit just came in and i wanna install myself but i cant untill i kno wat im doin so if anyone can help i would apreciate it
Old Feb 27, 2009 | 04:09 PM
luistypes's Avatar
Go into the 3g TL garage. There is a video on how to remove your rear bumper and all the installation instructions for the rest of the kit. I just did mine and it is really easy.
Old Feb 27, 2009 | 04:26 PM
HaRDbODyTL's Avatar
thats not workin for me i cant find ne thing can u try to send me a link
Old Feb 27, 2009 | 04:32 PM
Piotr_W's Avatar
http://estore.honda.com/aii/aii002.a...L&modelname=TL
csmeance's Avatar
from the 3G garage:
Video of rear bumper removal:
https://acurazine.com/forums/3g-tl-2004-2008-93/diy-video-removing-your-rear-bumper-3g-garage-e-095-a-619706/
Honda service manual instructions for removal of rear bumper:
https://acurazine.com/forums/3g-tl-2004-2008-93/how-do-i-remove-rear-bumper-569062/
Front instructions included with kit:
https://hondacuraworld.hostasaurus.c...derspoiler.pdf
sides:
rear:
Old Feb 27, 2009 | 04:42 PM
HaRDbODyTL's Avatar
thanks alot guys
Old Feb 27, 2009 | 04:58 PM
fansy's Avatar
just installed my sideskirts today.. was really easy. but i had to remove the rear wheels to access the inner screws. thats the tiring part.
Old Feb 27, 2009 | 05:16 PM
6spdtl-s's Avatar
Nismo TL yo!
no you dont. youre using the wrong tools.
Old Feb 27, 2009 | 05:43 PM
fansy's Avatar
thats what i thought. somehow i missed the "stubby screwdriver" part. lol. since the front and rear looks harder, i might see if i can get a friend to help.
Old Feb 27, 2009 | 09:45 PM
1fsthatch's Avatar
yea the side skirts are the easiest , the hardest is the rear IMO you have to cut its pretty simple tho
Old Feb 27, 2009 | 09:50 PM
6spdtl-s's Avatar
Nismo TL yo!
What cutting? are you talking about the type-s aspec?
Old Feb 27, 2009 | 11:15 PM
csmeance's Avatar
this is only when installing the Type-S rear on non-type S bumpers. Otherwise its 4 holes that need to be drilled that are pre-marked for clips to help hold the lip on.
Old Feb 28, 2009 | 12:00 AM
fansy's Avatar
btw do you need to rub it with alcohol where you want to tape it? or just regular wash is fine?
Old Feb 28, 2009 | 01:44 AM
csmeance's Avatar
alcohol is the best, remember to use non lint towels (microfibers) and also to clean the whole area well, (2-3 times) to insure everything like wax, tar, etc is off. Your best bet is to first wash the car and remove heavy soil like road tar, grime, dust, etc. Then follow up with alcohol and then apply kit
Old May 27, 2009 | 12:23 AM
ac08odl's Avatar
ON DA LOW CAR CLUB
Do u really need to take the ack bumper off and make holes in it?
Old May 27, 2009 | 03:11 AM
tl_rox's Avatar
X2 That's what i did and i'm happy with the installation. You might wanna add some more 3M tape on front/rear skirts just to make it secure. You don't want your kit looking like this:
https://acurazine.com/forums/showthr...-spec+kit+gaps
I did mine 1 at a time (different days): Sideskirts first, Front second, Rear third (today) ...just take your sweet time and follow instructions to the tee.
What i'd recommend:
1. Change the (or add to) existing OEM tape with 3m tape: https://acurazine.com/forums/3g-tl-2004-2008-93/e-118-how-remove-double-sided-tape-w-ease-714513/
2. Rear skirt - hard part was taking off clips...they had dried dirt in them therefore had a hard time taking them off
3. Using a center punch worked really well for me prior to drilling holes.
4. You can do it by yourself (as i did)...but having an extra hand would be way easier.
5. TAKE YOUR TIME and be patient...it is more rewarding to see your work when you did it properly, and not doing quick shortcuts and messing up, just to finish it up.
Good luck
Old May 27, 2009 | 07:25 AM
jweb12's Avatar
Actually, it's also for installing the Type-S rear on a Type-S. There are 9 holes that you need to drill and you need to remove the exhaust trim as well as cut the opening around the exhaust (see step 4 in the instructions). I test fit the lip with just the exhaust trim peices removed and things weren't lining up correctly. Cut the openings out as directed and things fell into place.
Install Instructions
Mike734
Dec 10, 2021 01:25 PM
tsx_boy
Dec 13, 2019 08:33 PM
RL780
Oct 19, 2015 09:46 AM
Nickb257
ILX
30
Oct 11, 2015 02:43 PM
scionxb3003
Sep 22, 2015 05:28 PM
