Damn Those Silver Center Consul Trims! (Can Anyone Help Me Remove Them?)
Location: On the banks of a filthy river in east TX ruled by crooked cops, brazen women and pansexual cowboys.
Evening all.
Title says it all. I've used a butter knife to pop off most of the clips holding the silver trim lining the center consul off. However, the last bit towards the top of the piece (the part of the piece that's next to the navigation system) I can't seem to pull out. I do not want to use too much force and break it, but at the same time I need it off to access the center consul.
Can anyone post advice on how to do this?
I do have the service manual scans (thanks for the link datmrman) but still feel unsure about just how much force to use.
It's always the hardest the first time..... Use force, just be careful to apply it evenly in that area, you don't want to crack the piece.
I'd take your butter knife, wrap it in a decent thickness towel, and try to pry it out from the non-navigation side. Just be careful not to bend the dash piece.
If you happen to bend it, a VERY light heat gun can help form it back out.
Again, just be careful.
Tom
Tom
Originally Posted by Kracker
Why are you removing them?
I was able to get the drivers side off without any incident but the passenger side one, that's the one that's giving me a nightmare!. Perhaps if I can find a wider surface on which to apply pressure I can exert more force but do so over a larger surface area.
i actually removed them today. When you get towards the top, i used the butter knife and used it to pry the silver trim up just a lil bit, then just grabbed from the curved area (right next to the accesory part) and the area closest to the top clips, and pulled out w/o TOO much force...just do it slowly...
Also, when you removed it, did you hear metal pieces falling off? One of the metal clips actually came off of mine, and i can't find it.
I would still look at running it on the side...
Worst case... I think I read somewhere that replacements are like $95 bux. (not for sure)
Best of luck to you.
Dealership quoted me $65 for the replacement part but I'm going to see if I can A) remove the blemishes -and if that fails- B) find it online.
But I guess it's a mute point as I (and Mr. Hammer) finally managed to negotiate the removal of that @#%# piece (without any bending).
Originally Posted by Laxplaya11385
...Also, when you removed it, did you hear metal pieces falling off? One of the metal clips actually came off of mine, and i can't find it.
The trim still holds strong and I won't have to worry about the same clips falling again.
Oakes
Wash & Wax
10-12-2015 11:17 AM
