Clock issue
Old May 21, 2021 | 12:26 PM
Arafel's Avatar
Clock issue
I have a 2005 TL with the navigation unit. The clock is not auto-updating the way it is supposed to. Further, I can't manually adjust it. When I took it to the dealer, they thought it might be the way the aftermarket iSimple and backup camera were wired in by Car Toys. However, Car Toys says that everything is hooked up properly. Further, this is a new issue that I first noticed with the change to DST in March.
Anybody have any ideas how to fix it?
Old May 21, 2021 | 02:36 PM
peter6's Avatar
It's a well known issue.
https://acurazine.com/forums/3g-tl-a...-clock-630065/
https://acurazine.com/forums/3g-tl-a...stment-991736/
https://acurazine.com/forums/3g-tl-a...-issue-991670/
In summary some programmer screw up and now you need to wait for navi update from Acura. I believe '04-06 cars have different system than newer vehicles, so chances of getting update for ~16 year old car is small.
Of course I might be wrong since I don't follow those threads as I don't have nav, but feel free to at least check the last posts to get idea if anything changed.
Old May 22, 2021 | 02:08 AM
Will Y.'s Avatar
Registered but harmless
At 12:59 PM, disconnect and quickly reconnect the negative battery clamp.
That will cause the clock to set to "1:00" and be accurate until DST ends.
Old May 22, 2021 | 02:15 PM
DMZ's Avatar
DMZ
Head a da Family
Yeah, go to a salvage yard, find an '07/8 Screen & DVD drive, and install them. Problem solved! Unfortunately, there's no other alternative because if you're going to wait for Acura to come up with a solution, you'll be in your grave long before that ever happens.
Old May 22, 2021 | 06:45 PM
Slpr04UA6's Avatar
-------Tim-------
^don’t forget to inform them about the harness that you acquired from Martin, to make the swap a lil easier.!
Old May 23, 2021 | 07:59 AM
DMZ's Avatar
DMZ
Head a da Family
Martin's # 201-889-7012
AH007
Jan 13, 2014 09:46 AM
dunk it
Jul 26, 2011 12:01 PM
dwboston
Feb 22, 2010 04:45 PM
dwboston
18
Apr 13, 2008 07:38 AM
