Navi/Dash Clock Sync MEGATHREAD (UPDATE: all should be fixed now)
Old Dec 5, 2007 | 09:35 AM
Slvr04TL's Avatar
I searched the forum and noticed people encountered similar problems but the resolution was not posted.
I've gone through the Navi menu and tried to adjust the clock. The Navi clock changes, but the clock on the dash doesn't.
The problem started when I changed my battery. I did notice when I started the car with the new battery the Navi was installing new software. Any body run into this issue?
Popular Reply
Jan 21, 2022, 05:33 AM
DogP's Avatar
DogP
I ended up getting slightly sidetracked last night. Since I already had the GPS receiver accessible, and figured out enough about the message format... it looked really easy to just throw in an MCU to intercept/modify the data. So I gave it a try, and it works!
Of course the goal is to apply a fix to the native navigation unit software, but since I can confirm that this works, I'm confident that it'll work if I can get the navigation unit to simply modify that data when it arrives.
Not that I expect anyone else to do this (nor do I even recommend it), but I'll throw the code up on Github in case anyone's interested in checking it out. It's running on a PIC16 MCU... the code just BARELY fit (including the <time.h> functions ate up ~90% of the flash, but it made converting the date only a few lines of code! :-) ). It uses a signed 32-bit time_t though, so you're on your own in 2038. ;-) These MCUs do come in really small packages, so it'd be easy to make a small PCB that sits between the GPS receiver and navigation unit motherboard... but that's just a backup plan if I can't figure out how to do it in the navigation unit software.
Few pics below for those interested.
DogP
Old Dec 5, 2007 | 10:18 AM
Ter Molen's Avatar
5th Gear
I have the exact same problem and have not found the answer either. Any help would be appreciated! Thanks all.
David
Old Dec 5, 2007 | 04:38 PM
timmahh's Avatar
it's me, Alan Rickman.
ehh.. where do you see the time on the navi?
i changed mine for DST and the smaller display updated...
Old Dec 5, 2007 | 05:12 PM
Ter Molen's Avatar
5th Gear
Hi there. When you set the time on the Navi the time is indicated on the navigation screen. Presumably, after that is modified the time on the display above that navi would also be updated. After all, the manual says these times will sync. But after changing the time on the navi screen the primary time display remains unchanged.
Old Dec 5, 2007 | 05:29 PM
timmahh's Avatar
I don't remember seeing a clock on my nav screen; maybe because there's the one on the mini-display above it i never pay attention..
Old Dec 5, 2007 | 05:37 PM
Slvr04TL's Avatar
The clock on the Navi only displays if you press the Setup button, choose option 4, and adjust clock
Old Dec 5, 2007 | 05:44 PM
timmahh's Avatar
ah.. i shall try, that's the same screen where you have the + / - 1 hour adjustments ?
Old Dec 5, 2007 | 07:31 PM
Bearcat94's Avatar
AZ Community Team
Yeah, that's the place.
Not much use a "clock". I mean who is going to keep their Navi screen on *that* screen?
BTW - I checked mine today and both clocks are the same/synchronized.
Old Dec 5, 2007 | 08:22 PM
gynuine69's Avatar
when you start your car, do you have a honda or acura splash? if you have a honda splash, you are going to have to reset your navi DVD.
Old Dec 5, 2007 | 08:37 PM
TL_S_Driver's Avatar
i posted on the same problem several months ago when i first got the car and i took it to the dealer who told me that i needed to upgrade my version disc because an 04 version was installed, which may very well be the case since the dealer i brought it from (non-acura) had several in his lot. in either case, the problem still exists but that seems to be the only problem with the disc not being the correct version so i've been trying to stick it out instead of shelling out the cash for the newer version, which might just have been an excuse to get me to buy the disk. o well.
Old Dec 6, 2007 | 12:54 AM
csmeance's Avatar
Which version is it? I run 3.30G and have no problem, and my TL has never had the navi upgraded, just hacked. This is kinda odd, I think the navi drive may just need to be reset. Also as well, make sure that the correct version is loaded on the car. To reload eject the DVD and re-insert.
Old Dec 6, 2007 | 09:49 AM
Slvr04TL's Avatar
I've had the car since 04. The dash clock and Navi clock were synchronized until I changed my battery. Last night I disconnected my battery again with the hopes that somehow it will re-synch itself after resetting. But that didn't work.
Old Dec 6, 2007 | 10:58 AM
HiTEC's Avatar
So you're running same NAV disc since 2004? You've never updated your NAV software? Done any NAV hacks or anything that you've gotten from the forum?
Old Dec 6, 2007 | 02:34 PM
Slvr04TL's Avatar
No. I haven't done any modifications to the Navi
Old Dec 6, 2007 | 03:21 PM
Slvr04TL's Avatar
I have the Acura splash
Old Dec 6, 2007 | 04:55 PM
007TL-S's Avatar
Be kind to us truckers !
press the "Set-up/Menu button and go in about 4 screens , you can adjust it manually!
Old Dec 6, 2007 | 05:52 PM
Slvr04TL's Avatar
I did that but only the clock on the Navi adjusts. The clock on the dash remains the same.
Old Dec 7, 2007 | 02:22 PM
gynuine69's Avatar
Is the colon that separates hours from minutes blinking? Have you tried to eject the disk and reload it yet?
Old Dec 7, 2007 | 05:53 PM
Slvr04TL's Avatar
I didn't notice if the colon is blinking I'll check when I get in my car after work. The dash clock is working because the time changes.
Yes, I tried ejecting the disk and reloading it.
Old Dec 7, 2007 | 09:49 PM
Slvr04TL's Avatar
Yes, the colon is blinking.
Old Sep 13, 2008 | 03:52 PM
overlook2k's Avatar
How do you reset the nav if you have the Honda splash screen?
Old Oct 10, 2008 | 07:48 AM
mtujohn's Avatar
4th Gear
Has anyone come up with a fix for this?
Just to sum up - dash clock is out of sync w/ the GPS clock. Resetting GPS, reloading DVD and disconnecting the battery does not resync. Seems like the GPS is not talking to the dash clock.
Old Oct 10, 2008 | 07:59 AM
csmeance's Avatar
go into the diagnostics screen and force it to load the acura one. I believe its map/menu/cancel for 5 seconds then you go to version, then download.
Old Oct 10, 2008 | 08:00 AM
csmeance's Avatar
when it starts up do you have the honda navi screen or the acura one?
Old Oct 10, 2008 | 09:09 PM
zeppelin77's Avatar
So the dash clock is working, but not synchronized? How far off is the dash clock from the navi clock?
The dash clock is a dumb device ... it just displays what its told from the main display. Is there anything else malfunctioning in your car? Anything at all. If so, you may have blown a fuse and its affecting your dash clock.
Old Oct 12, 2008 | 04:28 PM
Silver Bullet's Avatar
Try these steps to fix your problem...
Go to your system setup (Navigation, Menu, Cancel hold all 3 buttons down simultaneously for 5 seconds)
Select the Functional Setup Button:
Then select the H/U Time Send button:
Then select the Set button:
That should do it.
Oh...and make sure your H/U Time Send is set to ON.
Old Oct 15, 2008 | 10:55 AM
elchapo's Avatar
my 08 navi dvd rom dont have that hu time send option..this what i did last night
https://acurazine.com/forums/3g-tl-audio-bluetooth-electronics-navigation-94/people-oem-navigation-gui-w-clock-sync-problems-i-think-i-fix-691921/
Old Apr 19, 2014 | 09:45 AM
Lenexa64's Avatar
Dash clock problem solved
Silver Bullet - You solved it for me!
I had the same problem. The dash clock wouldn't sync with the GPS/Navi system. I tried the battery disconnect/reconnect trick; didn't work.
So - I tried Silver Bullet's suggestion and it worked!
1. Press Map/Menu/Cancel all at same time for 3-5 seconds (Diagnostic screen should appear on the Navi display)
2. Select the Functional Setup Button
3. Select the H/U Time Send Button
4. I had to toggle the On/Off setting. It was set to 'On'. So I set to 'Off' and pressed 'Set'. Then set it to 'On' and pressed 'Set' again. A few seconds later and the dash clocked synced.
Yes!
Old Dec 28, 2020 | 02:16 PM
cad2335's Avatar
Nav clock & calendar issue
I have a 2006 Acura TL. My clock on the upper dash works perfectly fine but the clock setting in the nav. screen does not work. It shows as 0:00 and the colon symbol is not flashing. I am unable to adjust the time since the "reset" button is grayed out. So when it is time to adjust clock to daylight savings I am assuming the clock will not change even though it was set up for daylight savings
Also my calendar is not working and it is set on Jan. 2002. The "go to" today button is grayed out. I can scroll to different months but goes back to Jan. 2002 when I go back to it.
I am assuming the clock and calendar issues are related since they both did not work at the same time.
Any ideas as to why this is happening?
Thanks!!
Old Dec 28, 2020 | 03:37 PM
DMZ's Avatar
DMZ
Head a da Family
Interesting. My upper dash clock is an hour and 15 minutes fast since reconnecting the battery which was disconnected overnight a couple of days ago. Going into Settings, Screen [4] where you're supposed to be able to set the clock, I can press buttons to my heart's content, but all I see is 00:00 no matter what.
Old Dec 28, 2020 | 04:14 PM
cad2335's Avatar
That's basically the problem except the upper clock in my dash does display the current time. I am going to have a problem when daylight savings come and I am unable to reset the clock.
Does your calendar show the current day and month?
Old Dec 31, 2020 | 03:11 PM
DMZ's Avatar
DMZ
Head a da Family
Nope. It reads JAN 2002.
Old Dec 31, 2020 | 05:32 PM
Pair of TLs's Avatar
I knew you drove a time machine!
Old Jan 1, 2021 | 11:44 AM
James Wright's Avatar
Navigation system doesn't know day, wont allow clock adjustment
I've had my 2005 TL since early 2006 and never ran across this before:
I still use the calendar feature in my car and went to the calendar yesterday to check something. For some reason it showed 2002 instead of 2020. I went into clock adjustment and it does not allow for any adjustments and just says 0:00. The clock in the display above the nav is still correct. It didn't allow for GPS enabled time zone or anything, the whole page of setup appears to be locked out as well. Any ideas how to remedy this and what could have caused it to do this? The disk is an original 2004 orange disk, but the Nav still performs fine.
-James
Old Jan 1, 2021 | 12:40 PM
csmeance's Avatar
I'm guessing the navi DVD calendar only had 15-16 years worth of "calendar" programmed into it. I'd try buying a newer disk from ebay to see if it helps.
Old Jan 1, 2021 | 12:42 PM
No, calendar goes well past 2020. It didn't happen at the end of the year, it happened about a week ago.
Old Jan 2, 2021 | 10:53 AM
04WDPSeDaN's Avatar
iWhine S/C 6MT TL
I'm experiencing the time issue as well. I haven't messed around with anything yet other than the obvious.
Old Jan 3, 2021 | 07:59 AM
DMZ's Avatar
DMZ
Head a da Family
I currently have the exact same problem since the alarm going off issue on Christmas Eve, and I have the latest 2014 Nav DVD. Paul disconnected the hood latch part of the alarm system since that's a known cause of the alarm going off. I'm going to have him reconnect it this week and see if that's it.
Old Jan 3, 2021 | 08:04 AM
What happened with your alarm? One day a couple of weeks before the clock thing happened, my key fob/alarm would not beep but it locked the doors.
-James
Old Jan 4, 2021 | 06:56 AM
DMZ's Avatar
DMZ
Head a da Family
https://acurazine.com/forums/3g-tl-a...-storm-991631/
