Check this out
Old Mar 30, 2004 | 02:51 PM
Donte99TL's Avatar
Does anyone read this
Check this out
I pulled my car out of my garage so I could sweep it Saturday morning. Then I notice some oil drops on the floor. I look underneath the car and I see some oil splattered all around the drain plug for the oil and on the oil pan. I though maybe the drain plug is loose or the crush washer on the drain plug is bad and it’s leaking.
I decided to just leave the car alone and I would bring the car to the dealer first thing Monday morning. I figured I would let them figure out where the oil is coming from.
So I drop the car off in the morning and then get a call around noon. The service manager tells me the car isn’t leaking oil but it’s the steering pump that is leaking and needs to be replaced.
Wow my car only has 4,700 miles on it. So has this happened to anyone else? I figured I got one of the few bad pumps. Oh well $hit happens.
I am not too worried about because the dealer I took it to (Hoehn Acura in Carlsbad) are really good. I know they will take good care of me and my car like they always do.
Old Mar 30, 2004 | 02:57 PM
04tlnbppar's Avatar
Interesting to know, better check my TL more often too...
Old Mar 30, 2004 | 03:01 PM
Tripp11's Avatar
Newbie for Life
A few weeks back, someone else on this forum had the same problem...didn't they? Or am I finally losing my mind? It didn't get a whole lot of replies though....
http://www.acura-tl.com/forums/showthread.php?t=75042
This was it.....not quite what I thought but it's something related.
Old Mar 30, 2004 | 03:11 PM
JoganJani's Avatar
never stops!
Sorry to hear that Donte. You've a 4 digit vin right? Can you please give some idea about the build date, number.
Old Mar 30, 2004 | 03:16 PM
Donte99TL's Avatar
When I get the car back I will look up the Vin for you. I should be getting in back tomorrow. So did you MACK yours back to the shop
Old Mar 30, 2004 | 03:23 PM
VTEC=happiness's Avatar
What's a TL?
Donte....any way you can ask the dealer if they have seen a lot of this? Just wondering if I need to take mine in for a check-up. Thanks
Old Mar 30, 2004 | 03:30 PM
Donte99TL's Avatar
Well he said that my car was the first 04 in for this type of problem. I have been taking my Acuras to him for the past 4 years so I know he wouldn't bull$hit me.
Old Mar 30, 2004 | 04:12 PM
bigdomer's Avatar
Donte - did you have an oil change, yet? I get the impression that you have not. I had the same problem after my first oil change and the service manager told me that it is difficult to get the filter clear of the car so that often times the mechanic accidently drops/spills the damn thing creating a big mess.
Old Mar 30, 2004 | 05:14 PM
Donte99TL's Avatar
Nope no oil change yet.
Old Mar 30, 2004 | 05:29 PM
Teh Jatt's Avatar
The Oracle of Acurazine!
ok I didnt have any oil but few days ago, the AC was on and then I parked my car front of the garage and then when I backed up, I saw some wet spots... So I get out and when I touched it, It was water not oil.... whats up with that?
Old Mar 30, 2004 | 06:26 PM
Ted Johnson's Avatar
That is water removed from the atmosphere by the A/C. It is normal...
Regards,
<TED>
Old Mar 31, 2004 | 01:27 AM
Donte99TL's Avatar
My wifes car did that and she came running saying her car is leaking something. I go out and it's the same thing :lol2:
Old Mar 31, 2004 | 01:41 AM
ravi's Avatar
i dont even have my AC on and there is water leaking from the bottom..wats UP WITH THATTT????
Old Mar 31, 2004 | 02:31 AM
jasoboe's Avatar
If you've been in the rain it will drip for a while from the wheel well - take a look in there, they basically use a carpet-type material as sound-proofing.
Annoying, but normal
Old Mar 31, 2004 | 10:43 AM
jbdezine's Avatar
was your steering pump making a winning noise at slow sharp turns? This seems to be my case but I am not noticing any fluid leaks.
Old Mar 31, 2004 | 11:12 AM
Norse396's Avatar
If you had the defogger on it uses the AC to dry the air it's blowing on the windshield, it's normal.
Old Mar 31, 2004 | 01:49 PM
Donte99TL's Avatar
No winning sound, the guy at the dealer said it was a bad seal on the steering pump. Nothing to get worried about for everyone else.
Mike Pilipenko
Mar 26, 2024 09:21 PM
MilanoRedDashR
Oct 2, 2015 10:49 AM
Skirmich
Oct 1, 2015 12:59 PM
hrothgar02
Sep 28, 2015 11:08 AM
mars
Sep 28, 2015 11:03 AM
