This Car Has ONly 14 g tank?
I was paying attention when i was filling the car with gas and i was on e. I only had 11 miles left till completly empty. When it was done it was only 14 gallons and on the website it says 17. Did anybody have this problem or does my car have a defect. Need Help
That's common for everyone. A lot has been written about it here if you do a search. The skinny is that everything is programmed to tell you the car is empty when you have 3 gallons in reserve to help you not run out of gas. I think most hate it, but just adjust what you now know and be sure you don't end up stranded.
3rd Gear
same thing
i have noticed the same thing. i actually like this feature, you should never let ur car run down to where you could only go 11 more miles. debris builds up in your tank over time and its not a good idea to let it run that low, or it will get sucked into your engine.
The reserve makes sure that you don't run out of gas, and that the fuel pump is properly cooled by the fuel in which it's immersed. Large amounts of debris building in the tank will not get sucked into the engine, but they can clog a fuel filter. I don't think today's plastic tanks have the old "empty tank" debris (mostly rust) problem.
Mike
Mike
Moderator Alumnus
This topic has been beaten up millions times...
Moderator Alumnus
Per Ron A said...
b. When the low fuel warning light comes on, you still have about 3.71 gallons left in the tank
c. When miles to empty reads zero, that is time to fill up, but you still have about 2 gallons left in the tank
And again I must post, why does anyone think that if you let the tank get low, that it will suck up debris that has piled up in the tank. Do you think there is a floating pump that sucks gas off the top ??
The pump is in the bottom and always sucks off the bottom, so there is no buildup of stuff, it's always being sucked up if it settles. And yes, that's what the fuel filter is for.
This one always kills me.
BigTurkey (01-23-2015)
I have also added to your rep points.
Originally Posted by Aquineas
When the car says "0 miles" to empty, I've found it has about 2 gallons left. It probably has more, but I don't wanna find that out :-)
Moderator Alumnus
I have no points to give now...
Are we going to replace this filter sometimes?
Team Anthracite Member
I didn't want to be the one to say it -
thanks!
thanks!
The service manual says to replace the fuel filter if the fuel pressure drops below the specified value, after making sure that the fuel pump and the fuel pressure regulator are OK.
From this, I would say that you would only have to replace the fuel filter if you were having problems with fuel supply and the tests indicated it was the fuel filter which was causing the problem.
What have you done with all your points... Is there a limit? Are they rationed? lol
Moderator Alumnus
Originally Posted by Ron A
The maintenance minder makes no mention of ever changing the fuel filter during scheduled maintenance.
Thanks, Ron A. I bet you could type the owner manual words by words without checking on it... Pages # is only thing you have to check.
P.S. I'm sure you know this... (You must spread some Reputation around before giving it to users again.) There is no limit at all...
never stops!
You do not have to worry about such things in the car manufactured in today's world (at least US market).
BTW, Sherlock, what if the debri floats at the top? j/k
From what I have read, there really is no need to replace your fuel filter nowadays especially if you guys buy gas from a popular station. The underground tanks get replenished enough that there should be little if any contaminants being thrown in "free of cost" into your gas tank. Most gas stations in my area has been updated recently and have had their rusty underground tanks replaced. On top of that, I believe there is a filter in the gas pump itself at the filling station that pre-filters the gas as it goes through the nozzle.
dsc888
dsc888
Not running out the tank
The issue with running the tank to empty isn't picking up crud from the bottom of the fuel tank.
An electric fuel pump relies on the fuel passing through it for cooling and lubrication. Run the tank out and you cavitate (get air into) the fuel pump. No cooling and no lubrication from the fuel and it doesn't take long to overheat the pump and do some damage. That's really the reason you don't want to run the tank out too often.
Not a Blowhole
The real risk is that when cornering at higher speeds and you have less than 1/4 tank or so, the pump can suck air - you might not notice it, because the fuelk systems is buffered to provide a continuous flow - but it could hiccup.
No, the real danger is necause of a fact that known to many people: the gasoline actually helps cool and lubricate the fuel pump! A pump running on "air" in the open would not last long - every time you let it suck air, heat rises fast, and wear as well. I never let my car get that low, and I have never had a fuel pump failure. Coincidence? Good luck? Or good thinking?
Thanks for the tip, RR. I tend to let my car run down to "E" (e.g. 3 gallons left), then refill. Maybe I shouldn't.
RR:
Good info, except for one thing.
Water does not "rise to the top" in a fuel tank, it settles to the bottom, being heavier than most petroleum distillates. When checking fuel storage tanks, you measure the depth of the water and sediment in the bottom of the tank.
Just a small point.
TR
Just a small point.
TR
Not a Blowhole
Originally Posted by rapera
RR:
Just a small point.
TR
Just a small point.
TR
