Can I pull a trailer with my 04 TL
#43
One on the right for me
Are you going to have to remove the black underbody plate for the hitch to be installed? I guess thats a premature question though..please keep us (at least me) updated. Thanks in advance.
#47
#48
rarely registered user
Originally Posted by MrBadGUy
Thanks!
#49
Ive heard of that company...thats about it. I am going to put my car up in the air on weds to see if those install instructions are application specific for the 04 TL.
#50
Did this hitch issue ever get solved?
Introduction: Long time lurker, first time writer. I am waiting to hear back from the dealer whether or not he will be able to get the car I want or just grab one off the lot. Okay, enough about me - back to the hitches.
#51
Originally Posted by USCGMoose
Anbody have some luck with the U-Haul hitch? Looking for an update.
#53
i would imagine that some work would need to be done to the rear of the car because of the way the hitch would need to be mounted. on a good number of sedans you need to trip away parts of the bumper to get the receiver to hang down.
#54
I got the u-haul hitch.
It was so ugly. It does not fit well at all. I mounts to the towing hook and then requires two holes drilled into the spare tire area. Then the plastic gas tank cover has to be discarded or cut up somehow. Also the mounts to not fit flush with the compartment. It needs to be bend out of shape. I will not install this. Apparently, this hitch fits Accord and 2 gen Tl, they try to force it onto new TL. Anyway, I will return it tommorrow.
#55
yeah thats how a lot of the crv hitches mount also.
#56
Are you going to try one of the hitches from hitch-web.com?
#57
Originally Posted by cigarlvr
I am looking to pull a trailer with my 2 motorcycles in it. It would be a maximum on 1000 lbs. Is this something the car can handle and if so what would i need to order and any idea what it would cost and how many hours for labor?
#58
Originally Posted by RacialSlurs
hmmm, MIG + steel = hitch
any good hitch shop can build in whatever is needed.
#59
Hi all,
Here is a link to a couple Draw-Tite hitches for the TL: http://search.cartserver.com/search/....2+TL&GO=GO%21. One tows up to 2,000 lbs and the other up to 2,500. I don't have any personal experience with them though, and I did notice that they are for "1999-2004". I wonder if they meant 1999-2003?
#61
2007 TL Type-S NBP
Does anyone have any first hand experience with premature engine/trans/clutch failure as a result of towing with their 3G TL? I've towed for years with my '99 Maxima 5 speed and had no problems. Original engine, trans, and even clutch at 212,000 miles. I just bought a '07 TL-S 6mt and assume that an Acura should be as durable as my old Nissan. I don't buy the old "owners manual says don't" argument. They have all sorts of lawyer warnings in there.
