A/c
Old Sep 10, 2004 | 12:41 AM
donkeykang's Avatar
A/c
I have read of people's A/Cs smelling nasty with lots of mileage but mine doesn't smell too great and I only have 500 miles. Not mold...just doesn't smell too great...
not a big deal...i'm just wondering
Old Sep 10, 2004 | 01:01 AM
xristos's Avatar
.:HALCÓN DE LA NOCHE:.
Do we have a in-cabin filter?
Old Sep 10, 2004 | 05:59 AM
qali's Avatar
i dont think it has anything to do with the mileage, perse.. i thought it had to do with hard acceleration... did you notice this right after a hard acceleration?
Old Sep 10, 2004 | 08:36 AM
Ron A's Avatar
Administrator
Yes. It's called a dust and pollen filter and is located behind the glove box. Under normal conditions it probably won't require replacement until 20,000 miles or more. When the number "2" shows up on the maintenance minder, it is time to change it.
Old Sep 10, 2004 | 08:39 AM
argoldst's Avatar
I think this happens with all cars. I have tried changing filters and over time, it just happens to all cars.
But if it not the filter, then what can it be?
Old Sep 10, 2004 | 08:53 AM
donkeykang's Avatar
I have never accelerated hard yet, hopefully going for a long drive and hitting 600 by Saturday. I went for a 60 mile drive last night just to add mileage and relax
Old Sep 10, 2004 | 06:03 PM
SouthernBoy's Avatar
Registered Member
Mine's fine.
Oh thing might be the source of your concern. When you use the AUTO setting the A/C comes on in recirculate mode until the interior temperature is lowered to a range acceptable to the system based upon your settings, then it reverts to outside air. In reciculate mode, there is going to be a build up of humity and increased moisture in the A coil housing. When it reverts to outside air, you will notice a somewhat damp smell for a few minutes until the A coil housing has a chance to dry out a bit. This is perfectly normal.
A hint. A mile or so before you get to where you're going, shut off the A/C and bump the fan up on a high setting to help dry out the housing and the A coil. This will virtually eliminate that nasty, moldy odor that's historically common with Hondas.
Old Sep 10, 2004 | 08:18 PM
xristos's Avatar
Thanks for the info, Ron A.
Old Sep 10, 2004 | 11:47 PM
techguy's Avatar
My old Honda Accord had this problem. The TL is not as bad.
Old Sep 11, 2004 | 08:46 AM
carcar's Avatar
Team Anthracite Member
Nice tip, southerboy! Thanks...
carcar
Biggie_B
May 27, 2025 05:51 PM
jdm_94-07TypeS
Oct 7, 2015 11:14 PM
hashbrown
Sep 29, 2015 12:13 PM
lovic87
Sep 15, 2015 06:07 PM
dlknight
Sep 3, 2015 07:54 PM
