bzzzzzz... where is it coming from
Old Apr 15, 2005 | 09:26 PM
Pro Stock John's Avatar
Car Addict
We have developed a bzzzzzz somewhere, might be near the rearview mirror, might be the dash. Is there a spot on the car that is buzz-prone? I plan to have the dealer check it out at some point.
Old Apr 15, 2005 | 09:36 PM
TerminaderTL's Avatar
Team Anthracite Member
Sounds familiar
Could it be your Moonroof Wind Deflector?
Here's a thread with the TSB: https://acurazine.com/forums/showthr...ight=deflector
Old Apr 15, 2005 | 09:37 PM
rets's Avatar
Moderator Alumnus
dash, panel, door frame, sun visors, roof, etc...
Maybe. It's call vibration or resonance... I guess... in low RPM or idle, some items may vibrate...
Old Apr 15, 2005 | 10:45 PM
RacialSlurs's Avatar
just use your fist to hit around until the noise goes away, when it's gone then you'll know where it was coming from
Old Apr 15, 2005 | 10:54 PM
AcidHorse's Avatar
You might want to check the driver's side door lock, where the alarm led is located. This buzzing sound recently appeared two days ago.
Old Apr 15, 2005 | 11:01 PM
do you have the 2 doors located below the nav center closed or open? i'll bet ya they are closed with nothing inside??
Old Apr 15, 2005 | 11:45 PM
Car Addict
Sometimes we have them both open, sometimes the top one open. We usually have an Altoids can in the upper one... It's a vibration/resonance issue, I have not spent any time yet to narrow it down.
Old Apr 15, 2005 | 11:53 PM
i think the whole 3G platform is a "vibration/resonance issue".
ok, leave those doors open and stuff the pockets with some small clean towels so that they have some slight pressure up against the doors. then see if that "bzzzzzzz" has gone away.
Old Apr 16, 2005 | 12:37 AM
Car Addict
Okay I will try that!
Old Apr 16, 2005 | 08:09 AM
do you also still have those snap-in pen/map holders in the front door pockets? if so take them out to see if they are causing it.
cycdaniel
Dec 17, 2019 10:58 AM
CheeseyPoofs McNut
Oct 11, 2015 11:25 AM
acuraST
Sep 17, 2015 02:31 AM
IndycarFaster
Sep 11, 2015 02:52 PM
