Bypass rear door sensor?
Old Sep 16, 2021 | 07:53 PM
eastvantrading's Avatar
Hello, I have temporarily removed my rear passenger door panel and my fob won't work and the dash is indicating the door is ajar.
I know it works if I reconnect the wiring and reinstall the door panel. Is there a way to bypass the sensor with the panel removed? Is it as simple as a switch or something i could "tape" over? I couldn't find anything...
Old Sep 16, 2021 | 07:59 PM
Pair of TLs's Avatar
Why is it "temporarily" removed?
Old Sep 16, 2021 | 08:55 PM
peter6's Avatar
Door "sensor" is basically touching body ground to tell the car that door is open. There is small cover on it and I think either 10mm or 8mm head bolt. Disconnect it and car will no longer detect door open.
I would bet problem with window regulator and he's waiting for new parts to arrive.
Old Sep 19, 2021 | 06:27 PM
csmeance's Avatar
tape over the door sensor on the bottom right corner of the frame where the door meets the car. Should be close to where the door latches.
Old Sep 20, 2021 | 10:23 AM
Awesome, thanks. When I first posted I totally missed the sensor on the frame. It was almost too obvious.
Sounds like tape or disconnecting will work!
73standard
Jun 6, 2017 02:26 PM
scottyrocket53
Apr 15, 2017 01:34 PM
peter57
Jan 25, 2017 06:29 PM
pepperish
Mar 5, 2014 02:02 PM
