Door Sensor Advice
Old Mar 3, 2014 | 09:00 AM
pepperish's Avatar
Question Door Sensor Advice
My passenger door sensor went. I had to disconnect it. My driver door sensor still works, but I have a small rust bubble under the driver door handle. I am having the rust repaired, and they will have to take the door handle off. Should I replace the driver door sensor since the guy will be in there (Sensor cost about $200) or should I just let it be since it works and just replace the passenger sensor (no rust under passenger side)?
Thoughts? I figure I might as well since he is in there, but then it still works, and it may continue to work, so if it is not broke, should I fix it?
Old Mar 3, 2014 | 01:58 PM
oo7spy's Avatar
I don't know if anyone has tracked down the root cause of door handle issues. The sensor isn't necessarily the issue. I would consider replacing both handles completely.
Old Mar 4, 2014 | 02:15 PM
pepperish's Avatar
By the door sensor, I did mean the total handle, part # 72141-SJA-A14ZJ
Old Mar 4, 2014 | 10:33 PM
oo7spy's Avatar
How much is the rust repair? The original handles have a flawed design. This was fixed in later years. You could potentially pay $X for rust repair, and end up with a new handle 6 months later. I would say both handles are damaged and need replacing.
Old Mar 5, 2014 | 07:52 AM
pepperish's Avatar
The rust repair is about $200. So you are saying that the new handles I buy from my local dealer will be the improved design? I assume so, based on information on the site that says it has a new part number. It sounds like it would be best to replace both at the same time.
Old Mar 5, 2014 | 02:02 PM
oo7spy's Avatar
From everything I have read, members who replaced the handles after 2007 have not experienced any more issues.
Dec 7, 2020 05:39 PM
Feb 25, 2020 09:57 AM
heykosal
1G RDX Problems & Fixes
Sep 21, 2015 09:41 AM
Sep 17, 2015 09:01 PM
EE4Life
Sep 11, 2015 10:13 PM
