Bulbs for Fog Lights
The search feature isnt working yet and i know i rem reading threads on it..i am looking to change the factory bulb for the fog lights to maybe the yellow ones..what did we at the forum come up with the best fog light replacement to be...and what was purchasing price and place to purchase?
:think:
:think:
:think:
:think:
Originally Posted by EulisCool
we have fog lights? how dou turn them on and where are they?
in between the hids and the center grill...you turn them on by twisting this ringlike thing on the switch where you turn on your lights....sorry if my description is kinda vague..i did the best that i can...hopefully my best was good enough.........
Originally Posted by caball88
9006 is the size
I used a Max Gold 55W 9006 bulb as I found the 9006 Yellow Ion bulbs to look only "off - white" when on with a irredescent effect on the edges of the bulb pattern. This caused more distraction to other drivers and did not give the yellow look I was looking for.
Try searching for posts by me, it is in the old stuff somewhere
the foglights are not HID. Bi-Xenon means that one xenon bulb is used to power both the low and high beams. there is a shutter that reflects the light into the highbeam housing. This is obviously to reduce cost becaues it would not make sense to have 2 xenon bulbs for headlight when the high beams are rarely used.
and is this fog light a HID xenon as well? What does it mean when they say "BI"-xenon headlights?
Bi-Xenon means both the high and low beams are HID. In the TL, they use the same bulb with a shutter to control how much light they give off.
Stand outside your car some day and pull back on the high beam lever, you will hear a loud clunk, that is the solinoid moving the shutter on the headlight.
I found 9006 Polarg brand pure yellow lamps at a few sites. They are made in Japan, package labeling is only in Japanese.
One is http://store.racinglab.com/po90puyesube.html
They appear a strong yellow so others don't think your high beams are on. Yellow is thought by some to be better in fog. I live in a coastal area with fog quite often so thought I give them a try. Happy so far.
One of the pictures on my link shows them on, but they don't photograph well in the daylight. I'll add some night time photos soon.
I am also using the Polarg. I tried turning it on/off in night time to see how effective it is, and it is quite good. It has even wider viewable area than the HID headlight. If you turn on both the fog and the HID, it is very bright on the road, when compare to just the HID only. With HIDs only, there is an sharp edge on the road, everything above that line is dark and not reachable by the HID, the fog can compensate that.
Originally Posted by Jcolbert
I replaced my factory fog bulbs with Piaa Xtreme White Plus Bulbs. I am very happy with the way they look. Much brighter and whiter than the factory bulbs!
Just curious how much brighter and whiter it is compare to factory. Is their any blue tint or just pure white??? Any pics??? Might be interested in buying the same ones as yours but don't know if the $$ is well spent if it is not a drastic change.
ok so we have the lights....9006/hb4..anyone have any suggestions for fog lights ?
http://search.store.yahoo.com/cgi-bi...eel&query=9006
http://www.midnightmoose.com/9006colored.htm
http://www.midnightmoose.com/9006.htm
and would u suggest 55w or 80w?
InFaMouSLink
10-27-2015 06:51 PM
sockr1
10-01-2015 01:31 AM
prox
5G TLX Problems & Fixes
09-01-2015 02:03 AM
