Blutooth Problem
Old Mar 5, 2004 | 10:26 AM
sameerqureshi's Avatar
Blutooth Problem
I HAVE A T608 PAIRED WITH THE CAR. SEEMS LIKE EVERYTIME I DIAL NUMBER BY SAYING THEM THE CAR MAKES THE CALL THAN DROPS IT AFTER THE FIRST RING. PHONE IS STILL ON WITH THE CALL CONTINUING THE CAR DROPS THE CALL . IT JUST SOMES OUT OF HAND FREEMODE AND I HAVE TO PICK THE PHONE UP TO LISTEN TO THE CALL. HAS ANYONE ELSE HAD THIS PROBLEM. SAME THING HAPPENS WHEN I CALL USING THE SEND FEATURE FROM THE NAVIGATION SCREEN. I HAVE NOT EXPERIENCED IT IF I AM DIALING FROM THE PHONE BOOK. help!!!!!!
Old Mar 5, 2004 | 10:42 AM
It sounds as though you may be losing the BT connection between the car and the phone. I use a T608 also, and I've had that happen to me once, when the phone battery was low. I put the phone in the upper console, plugged the car charger in and everything worked fine.
Old Mar 5, 2004 | 11:49 AM
i leave my phone plugged in at all times. I have a seperate phone for the car so i dont htink that could be it. I will take a peak at the battery level next time it happens though
Old Mar 5, 2004 | 12:46 PM
MikeRadio's Avatar
Re: Blutooth Problem
Yes, I have had this problem and still do occasionallly...
First... All you have to do to get the call back to the HandsFreeLink in the car is to press the top button and say "TRANSFER".
The problem is not that the call gets dropped.. the problem is in the bluetooth connection.... So the call still is on the phone.. you just have to transfer it back.
I do not get this problem ALL the time, only occasionally. I think it has to do with wither the signal strength on the call OR the battery stregnth.... More or less I think it has to do with the battery stregnth.
Please let me know if this works for you.
Mike
Old Mar 5, 2004 | 02:22 PM
mike thanks for the information. I will give this a shot , hopefuly it works
Old Mar 8, 2004 | 01:19 PM
MikeRadio's Avatar
Did it work? Always works for me.
Old Mar 9, 2004 | 08:57 AM
YUP IT WORKED JUST FINE. THANKS A LOT MAN. ALSO IF YOU WANNA RUN A DIAGNOSTIC ON THE BLUE TOOTH SYSTEM HOLD THE HANDSFREE AND THE CANCEL BUTTON FOR 5 SECONDS IT RUNS A SELF DIAGNOSTIC
Old Mar 9, 2004 | 09:30 AM
Sherlock's Avatar
One thought. I don't have a BT phone yet, but could it be: ?? Nearby 802.11b WiFi networking (uses same 2.4ghz band) or near a home with a strong 2.4ghz cordless phone in use ??
Just an off base thougth to see "where" it happens, maybe it's a WAP doing it.
Old Mar 9, 2004 | 09:42 AM
MikeRadio's Avatar
You just have to hold the CANCEL button for 5 seconds... not both buttons to run the diagnostic.
I do not know what else you can do in this mode besides hear the car tell you it is ok.
Mike
SidhuSaaB
May 30, 2020 12:40 AM
Fool
Mar 10, 2016 08:42 PM
12vancover
Oct 16, 2015 12:04 PM
Matthew Purpura
Sep 25, 2015 06:10 PM
MikeJM310
Sep 24, 2015 07:24 PM
