Big oil leak help
Old Oct 23, 2018 | 07:09 PM
06.UA6SD's Avatar
Big oil leak help
Do you guys know where it’s coming from? Looks like transmission and the bottom of engine top of oil pan maybe ?
Old Oct 23, 2018 | 08:23 PM
oil pump and rear main seal are two common areas.when was the last time your PCV valve was replaced?
Old Oct 23, 2018 | 08:50 PM
06.UA6SD's Avatar
never replaced, I was actually looking at stores around here for a new one but they all had an elbow for hoses it looked like, none looked like the actual valve so imma have to order one online. Imma take it to a mechanic on Thursday but I wanted to see suggestions of where it’s coming from so the mechanic doesn’t try to tell me something totally unrelated
Old Oct 29, 2018 | 07:56 PM
nick04tl's Avatar
Looks like your rear main seal and oil pump are leaking. Both are pretty common. I just did my rear main seal in my 2006.
Old Oct 29, 2018 | 08:05 PM
06.UA6SD's Avatar
how much did you pay?
Old Oct 29, 2018 | 08:07 PM
nick04tl's Avatar
Sorry I can't help you with a price. I did it myself.
Old Oct 29, 2018 | 08:12 PM
06.UA6SD's Avatar
if this wasn’t my daily I’d try to do it on my own also lol but I replaced the pcv valve and the car actually hasn’t leaked since. I cleaned under the car and i check the oil before I drive and the level has stayed the same
Old Oct 30, 2018 | 10:59 AM
Yup.. That's why I mentioned it.. PCV valve clogging has caused many people to believe their engines' rear main seal are leaking due to the built up pressure. Car just finds the easiest place to relieve it and it seems to be the rear main seal..
Old Oct 30, 2018 | 11:03 AM
06.UA6SD's Avatar
thanks man, it did help. But I’m still paranoid and check oil level constantly lol
Old Oct 30, 2018 | 11:06 AM
Well, have you done your timing belt job yet? If not, make sure you add the oil pump re-seal as part of the job when that happens as you'll kill two birds with one stone. If you just did the TB then I'd honestly just let it go and monitor level constantly until the next job.
Old Oct 30, 2018 | 11:08 AM
Jackass's Avatar
This thread reminded me that I have not yet replaced my PCV valve in my '05....and the dealer mentioned my rear main is leaking now. Guest what I ordered today?
Old Oct 30, 2018 | 11:09 AM
A REAR MAIN SEAL?!
Old Oct 30, 2018 | 12:01 PM
06.UA6SD's Avatar
a pcv valve I hope lol
Old Oct 30, 2018 | 12:05 PM
06.UA6SD's Avatar
yes i already did the tb job about a month ago actually, but the oil pump didn’t even cross my mind
Old Oct 30, 2018 | 01:56 PM
horseshoez's Avatar
Latent car nut
When I had my clutch done last may I had my guy put in a new rear main seal; didn't want to have to pull the tranny twice.
Old Oct 30, 2018 | 01:59 PM
06.UA6SD's Avatar
ill remember that when It’s time for a new clutch
GOOSEej
Nov 1, 2018 11:17 PM
fabrizzio71
1G CL Problems & Fixes
Dec 16, 2012 04:50 PM
