Best way to clean window interior?
Old Jul 30, 2005 | 01:27 AM
bluenoise's Avatar
2004 SSM/EB/5AT/Navi/RSB
Question Best way to clean window interior?
My windows are slightly fogged, probably from the out-gassing of the interior in the hot sun. On past cars, I found the best way to get this fog off of them was with a clean, dry cotton towel. It would just rub right off with a little elbow grease. Tonight, I tried this on my TL and found it did not come off easily at all. I then tried some Windex to no avail. I considered some isopropyl alcohol, but that seems a bit drastic.
What is the best way to get this fog off the insides of the windows?
Old Jul 30, 2005 | 01:39 AM
Dr.Murdock's Avatar
i have that crap too. blocks my vision at night from the headlights of oncoming traffic.
Old Jul 30, 2005 | 05:28 AM
BigTinVA's Avatar
lomaniac
Try some Eagle One 20/20 glass cleaner.
Old Jul 30, 2005 | 05:42 AM
cliff's Avatar
Team NightHawk VP
do you guys mean streaks and stuff? you can try stoner invisble glass. works wonders.
if that doesnt work, try newspaper, that works well too
Old Jul 30, 2005 | 07:26 AM
JetJock's Avatar
I use Stoner Invisible Glass....it's the best of the window cleaners I've found so far.
Old Jul 30, 2005 | 07:49 AM
JohnDoe2's Avatar
I find it helps to park facing the setting sun before cleaning. Then every little tiny smudge becomes visible.
Old Jul 30, 2005 | 11:57 AM
Yakuza70's Avatar
Ditto on Stoners Invisible Glass - best glass cleaner out there IMHO. I use a microfiber towel with the cleaner and get no streaks.
Old Jul 30, 2005 | 12:47 PM
SouthernBoy's Avatar
Registered Member
I, too, recommend Stoner's Invisible Glass.. particularly for the inside surfaces of your glass. The outside can be cleaned with luke warm water and a little vinegar.
I find that Stoner's does a VERY good job with minimum applications. This is the one you want to use.
Old Jul 30, 2005 | 01:08 PM
ndx2's Avatar
6MT & LSD
One quick question; is this safe to use on tinted windows? Or is it ammonia-based, thus not tint-safe? I was just told to use a damp cloth or the cleaner they gave me (which supposedly prevents scratching as well).
Old Jul 30, 2005 | 03:31 PM
Yakuza70's Avatar
I don't have tint on my car but I'm pretty sure Stoner's Invisible Glass cleaner is ok to use on tint since it contains no ammonia. Anyone else know for sure?
Old Jul 30, 2005 | 03:35 PM
scrb09's Avatar
Where do u guys get stoners from?
Road Rage's Avatar
Not a Blowhole
One of the best, and certainly the cheapest, glass and surface cleaners is one part white vinegar to 10 parts distilled water. Use non-clor newspaper as the remover. The print in newspaper actually works as an effective mild abrasive.
Safe, antibacterial, environementally friendly, and cuts through stuff well - otherwise, I use Stoner's glass cleaner, and Stoner's Xenit on really tought glass crud like stickers and things.
Old Jul 30, 2005 | 04:09 PM
Yakuza70's Avatar
I've found Stoners at many different auto parts stores: Autozone, Kragens, etc. I've even seen it at Wal-mart so it should be pretty easy to find locally.
Old Jul 30, 2005 | 06:02 PM
Registered Member
Hey Road Rage. I've tried white vinegar and water and found it worked well, but someone told me that it could cause a problem with tinted glass, such as our TLs and virtually any other car on the road today.
Does this have a basis in fact?
Old Jul 30, 2005 | 07:30 PM
HEK's Avatar
HEK
Team Nighthawk Mambo King
Ditto, and I've also tried Windex in aerosol can / foam, the key is to do it in a cool day and not with the glass hot or sunny day....
Old Jul 30, 2005 | 09:32 PM
scrb09's Avatar
Old Aug 1, 2005 | 12:58 PM
bluenoise's Avatar
I went to a local hardware store looking for Invisible Glass, but they didn't carry it. The clerk recommended this stuff:
I sprayed it onto a clean terry towel and then wiped off the film with no effort. I followed up with a clean, dry microfiber towel, but that was unnecessary. In other words, it worked great! I like the retro packaging, too.
The only downside is the smell of the stuff reminds me of whatever they use to clean hotel rooms. My son (four years old) said it smelled like a restaurant's bathroom. Luckily, the smell dissipated right away.
Old Aug 1, 2005 | 01:12 PM
ShO n TL's Avatar
I use Windex and Newspaper....The newspaper leaves no streaks
Old Aug 1, 2005 | 01:21 PM
Xpditor's Avatar
This thread belongs in Wash & Wax.
Old Aug 1, 2005 | 01:47 PM
1995hoo's Avatar
Keep Right Except to Pass
In terms of a quick fix that I use if the window has annoying streaks and I'm about to drive it (as opposed to a detailed cleaning when the car is parked), I have something called a "No-Fog Mitt" that I picked up somewhere several years back, probably at Trak Auto (which is no longer in business). The purpose of the thing is to wipe the glass to remove fog and to prevent the fog from coming back, but it works well at removing streaks in the short term too. Only thing is that it sometimes leaves streaks of its own, so for cleaning purposes it's really only good when you HAVE to wipe the windshield and you are about to drive or are stopped a light or some such.
Old Aug 1, 2005 | 02:41 PM
rbf351's Avatar
Registered User
my parents used to use that in the house on the mirrors they have, it works great, kinda of looks like foam what you spray it
Old Aug 1, 2005 | 03:41 PM
w1n78's Avatar
100k miles club
i use stoner's invisible glass as well. if you have tinted windows only use water. the bottle is black with a yellow cap. to reduce streaks use a newspaper as Sho N TL mentioned. i use micro fiber towels myself. nothing but micro fiber towels touch my baby
if you're gonna clean your inside, front windshield, spray it on the towel, then wipe. don't spray it on the window or some will land on your dashboard
walmart has a 6 pack of the small ones for like $5 or go to Costco or Sams Club. you should be able to find the 20 pack for about $14. also got 2 beach towel size
Old Aug 1, 2005 | 09:40 PM
redintegrity's Avatar
8th Gear
Try this
Try using quality glass cleaner (as mentioned in previous replies), but wipe it off with newspaper. I know, doesn't sound like it does the job, but it cleans pretty well.
Old Aug 3, 2005 | 04:02 PM
BASISON's Avatar
I am an avid user of Stoner's Invisible Glass and it can be used in tinted windows safely. I discovered this stuff a few years back and it's by far the best I've ever used.
Old Aug 3, 2005 | 05:37 PM
Phil B's Avatar
I use the Sprayway as well
This stuff does the best job on mirrors and glass. Benn using it for years. They sell it at our local hardware store. I don't know if the big boxes carry it though.
Old Aug 4, 2005 | 02:09 PM
tfe691's Avatar
What you need is something with a equalized ph level. Use 5 drops of tearless baby soap to 24oz of water. Trust me works great and won't staing dash or door panels in long term use and it will last ya for a long while.
uzzmaan
Aug 4, 2025 08:29 AM
BoricuaTL
Apr 8, 2016 01:08 PM
handsom-hustla
Nov 13, 2015 05:04 PM
ahsm
Sep 9, 2015 08:35 AM
asahrts
Sep 4, 2015 05:55 PM
