best climate control setting for heat
To get Auto Heat, without having the air conditioning come on, is the best setting to push the auto button, and then push the AC button so the display reads "A/C off"? If I do that is it still in the auto mode?
'05 Acura RL - CGP/Ebony
Cold Racketeer
Auto is just that, auto... the minute you fool around with any other settings you have ruined the whole thing. I keep mine set to 76 or so and forget it.
wow that seems warm.... 68-70 here usually'
However, if you don't need moisture removal or cooling, you can hit auto and then the A/C button (to turn off A/C) and you'll still have the system control fan speed, air outlet location, and temperature (as best it can without A/C) but A/C won't be running. So, for me, unless I need cooling or moisture removal, I run the system in auto but without the A/C on. That way, I get better mileage and more power for driving the car -- and I still get the temperature and fan speed controlled. If I really need cooling or moisture removal, I make it full auto.
2005TL(6MT)
Originally Posted by lflorack
Ruined is a bit strong. Auto is, as you say, auto. It controls both heat and A/C -- which means cooling and removal of moisture from the air. If I actually need cooling or removal of moisture form the air, auto is the way to go.
and I'm on my why home the fan on auto goes pretty high. It won't really cool down the
Cold Racketeer
Firstly, you have to let the engine warm up first to get decent heat in the car... I think the heating function of the climate control gets it's heat from the engine or the heater is tied to the engine being warmer.
If I need to get some heat right away (such as entering a car that has been out in the cold the whole night, I wait for the engine to warm up a little then just set the temp to about 15-20 degrees higher than the outside temp...
Since the car is trying to keep the inside at the temp you set... it reacts against the temp setting that is displayed on the climate control (like your home thermostat) so if it's 80 and you want immediate cooling, set your temp to 65 or 63 and the AC comes on with med-high to high fan... likewise for heating... if it's 55 and you want immediate heating... set your temp to 75 or 78 and the fan will blow harder and bring heat.
This way, I only change 1 setting (temp) instead of messing with fan speed, mode, etc.
Hope this works for you if you want to try it... All I can say is it works for me.
I leave mine in Auto all the time unless it's extremely dry outside. That way, the AC comes on to remove moisture and keep the windows free of fog even in the winter. I don't see any difference in gas mileage with the AC on or off. There might be a slight difference but it doesn't show on the computer.
i doubt it's still in "auto" - even if you change to recirc the auto sign comes off, so if you take of a/c you prob switch out of auto as well.
although - does anyone know if the car still regulates fan + temp even if the auto indicator is off?
Received 2,329 Likes
75 to 77 depending on the time of day.
Team Anthracite Member
Just set your temp and leave it in 'Auto'.... Just my
68 on Auto during the summer and 74 with A/C OFF for the fall and winter months. For some strange reason, 72 feels too cold in the car if it is 50 degrees or lower outside. Maybe it's me.
dsc888
dsc888
Cold Racketeer
actually i posted 76 before, but the past few night i've just been jacking it up to the 80s and that is better. seats on full blast heat mode, climate set to 85 and i am ready to go. all i need is a remote starter to get that thing like an oven before i even step foot inside.
haha
haha
rockyboy
08-04-2024 10:35 AM
cycdaniel
12-17-2019 10:58 AM
braveheart
09-07-2015 08:12 AM
