badges
Old Mar 17, 2008 | 02:08 PM
08 TLStockton's Avatar
5th Gear
badges
on the trunk if i took off the big acura emblem would there be two lil holes there or is it the double side tape thing
Old Mar 17, 2008 | 03:00 PM
Jesstzn's Avatar
2 holes .. I wish I had seen this post an hour ago I had mine off and could have taken a pix.
The "A" has 2 pins with sleeves over then and they go in the holes. The "A" is leld on by double sided foam tape.
Old Mar 17, 2008 | 03:36 PM
imj0257's Avatar
Q('.')=O
btw I need to take my rear one off (cus its upside down -- don't ask). anyways, what is the best way to take it off and put it back on so it still sticks fine. I hear using a blow dryer to heat up the glue stuff and then just a credit card to take the emblem off will do the trick.. is this right???
any help would be appreciated.
Old Mar 17, 2008 | 03:47 PM
Jesstzn's Avatar
No its not right .. a credit card is going to sratch the piant up pretty good .. Use fishing line or dental floss to saw it off .. then the remaining foam/glue residue warm it with a hair dryer and roll it off with your thumb.
If thereis glue left use Goo-Gone or WD-40.
Wipe the area down with IPA and use new double sided foam 3M tape to stick it back on .. then rewax around the area.
Old Mar 17, 2008 | 04:03 PM
imj0257's Avatar
Q('.')=O
uhh cheapest 3M double sided foam tape i found was $57 a roll. Are u serious?
Old Mar 17, 2008 | 04:54 PM
Jesstzn's Avatar
Any parts store will have it in 1/4" wide for $4 a roll.
Old Mar 19, 2008 | 01:11 PM
5th Gear
so is there gonna b holes behind the Acura emblem i know theres none on the TL TYPE S emblem
Old Mar 19, 2008 | 01:19 PM
blkaspec's Avatar
Full of water...
there are only holes on the big "A" in the center, the "Acura" and "TL" use tape
why are you removing them all?
Old Mar 19, 2008 | 01:56 PM
enigmaos's Avatar
Too Fast TOO FURIOUS
courtesy of ua6spec. two holes behind "A". btw, he is AZ Official vendor and selling the CF lip seen in the pic.
Originally Posted by ua6spec
Old Mar 19, 2008 | 02:09 PM
VIP-A-SPEC's Avatar
REDONDO RED
I use a strong dental floss or fishing string to slide it behind. The process is MUCH easier with a heat gun or a hair dryer to heat up the tape and it is also easier to pull the remaining peices of the tape off after the emblem is gone.
Old Mar 19, 2008 | 02:44 PM
Fulani has a TL's Avatar
When I took the A off I had to break those tabs, so dont know if you will be able to use it again. But then again you may be gentler than me.
I recommend using fishing tape or kite string, cuz the dental floss just kept shredding and breaking on me
Old Mar 19, 2008 | 02:50 PM
imj0257's Avatar
Q('.')=O
Ya I used dental floss and it came off easily with no paint chip/scratching whatsoever. Then I cleaned off the remaining gunk/goo from the body with water and then rubbing alcohol to get it super clean. Then used 3m double sided foam sticky tape to reattach it (right side up ) to the car. Worked like a charm.
AJRozsa
Oct 5, 2015 07:50 PM
HOWELLiNC
3G TL Photograph Gallery
Sep 17, 2015 10:04 PM
Dunnik
Sep 15, 2015 11:52 PM
