Auto feature not working properly on front passenger window...
Well I was leaving college and saw one of my friend and went towards him and rolled down the front passenger window, and then when I tried rolling up with auto feature it wouldn't roll up, I had to hold the button up to roll up the window. I tried like 20 times, rolling up and down with auto feature and didn't work. Then I tried rolling up and down from the passenger side button/switch (whatever u wanna call it) and same problem. After like 20 times, I called dealer and made an appointment with them for ASAP and Tuesday was the day I got the appointment. Well now I just got @ work and I tried again and it worked fine... :wtf:
Did any one else had this problem? I haven't seen any one mention here but who knows
Same Thing
The same thing happend to me one time right when I got the TL - My wife rolled down the passenger window and it wouldn't go up. I restarted the car it worked fine. It is totally random and one of those things that will never, ever, be replicated at the dealer...
Originally Posted by sharabi75
Are you sure there isn't some sort of time limit on how long after you turn the car off you can use the auto roll up feature.
M
M
It has happened to me. The dealer ordered me a new window regulator after inspecting it. I still have to go in to get it replaced.
It initially only happened in auto mode, but then it happened in manual. Eventually the only way I could close the front passenger window was by using my key and holding it in the lock position.
Originally Posted by AcuraTLjatt559
now u guys
me more... what time limit r u talking about?Trending Topics
Originally Posted by A-TLvic882
The same thing happend to me when my battery died second time. The dealer reprogram somthjng after replacing battery.
This is probably the reset feature he talked about.
But if the battery didn't die, as jatt said, sounds like a trip to the dealer, as he also said.
now u guys
Good luck wit ur window issue !!!
Oakes
Wash & Wax
Oct 12, 2015 11:17 AM
Ny1718
Sep 11, 2015 09:21 AM
asahrts
Sep 4, 2015 05:55 PM
