ATF fluid interval
Old Dec 19, 2015 | 02:37 PM
Cheesehead20's Avatar
ATF fluid interval
I have heard it suggested to get the atf fluid changed every 30k miles. However I live in the coachella valley where it's over 100 for much of the year. Will the heat have that much effect on it seeing that the fluid gets heated to higher temperatures under use?
Old Dec 19, 2015 | 02:44 PM
truonghthe's Avatar
I would replace every 10-20k miles.
Old Dec 19, 2015 | 03:27 PM
mau108's Avatar
Yes, heat is what kills transmissions. I would change the fluid every 20K miles.
Old Dec 19, 2015 | 03:35 PM
vietxquangstah's Avatar
When i had my TL i did the transmission fluid every 3rd oil change since i was under the car anyways
Old Dec 19, 2015 | 03:46 PM
erdoc48's Avatar
06 Anthracite TL
I did the original 3 X 3 at 50K miles, and since then, I do a 1 X 3 every other oil change, so roughly every 15K miles.
Old Dec 19, 2015 | 04:05 PM
Does sitting in the direct sunlight with an ambient temperature over 110 all day add to the breakdown of the fluid?
Old Dec 19, 2015 | 04:21 PM
erdoc48's Avatar
06 Anthracite TL
Where are you that it gets that hot...Phoenix? Anyway, I wouldn't think that ambient temp would have that much to do with fluid degradation.
Old Dec 19, 2015 | 04:22 PM
Palm desert
Old Dec 19, 2015 | 06:18 PM
truonghthe's Avatar
yes heat does degrade the fluid quicker than normal, at this point I would replace every other oil change.
Old Dec 19, 2015 | 08:03 PM
01acls's Avatar
Yes, heat will increase the service intervals but that depends on how long your trips are and how fast you drive. If you only commute half hour or less it probably not an issue. But if you're in stop in go traffic for an hour, that is severe use and a real concern or doing 100+ mph a lot, then again, severe use. Increase in service intervals is required.
The 30k you're referencing is probably talking about the 3x3 not just a single 1x3.
The 3x3 is roughly about 80% of atf change on paper. The more the mileages accumulate inbetween each 1x3, the lower the percentage.
If your car does not have a trans cooler, you might want to install one.
.02
Old Dec 23, 2015 | 05:34 PM
lilsid112's Avatar
I'd personally do a drain and fill every 15k. That interval worked for me since I replaced my engine oil every 5k.
Old Dec 27, 2015 | 10:20 PM
csmeance's Avatar
Every 15K or every other oil change is what I tell all my friends and family. $300-400 of fluid over 200K miles is better than $3000 for a new trans.
ryan5003
Dec 28, 2015 03:59 AM
Steven Freitas
1G RL (1996-2004)
Dec 27, 2015 09:23 AM
mtiaz
Dec 26, 2015 10:23 AM
jay87lx
Dec 23, 2015 11:23 AM
