Any warped rotors yet?
I know the '04 is new but maybe someone out there has put on 10K mi or more and is starting to experience the perpetual Honda warped rotor problem?
Warped rotors on my '01 CL and I was hoping after 20+ yrs they would find a fix before I got the '04...
The warped rotor problem can be prevented by making sure the wheel lug nuts are tightened with a torque rench to 80 ft-lbs. Allowing the air gun to stop when it normally can't turn any more overtightenes them.
RB
Originally posted by copter
If these rotors warp, I want the ones from the concept A-SPEC........ 15" vented and cross drilled.... I also wouldn't mind 8 piston Brembos all the way around either..
Originally posted by Rbraud
It's best to torque the wheels in three stages. Start out with 40 ft lbs, then 60 and final 80. Torque lug nuts in a cross pattern. If you use the brakes hard for a long period of time, drive around and let them cool down. JMHO.
RB
RB
Originally posted by Chilli
8 piston rear calipers are unnecessary and probably won't be available. Unfortunately, 8 piston calipers require 4 pads per wheel and double the price of a brake job. Big 4 piston calipers are almost as good! I just bought replacement front pads for my 8 pistoners after only 4000 miles for $300. What a drag.
08_UA7_Gr33k
02-11-2016 02:17 PM
lanechanger
10-13-2015 10:56 AM
08_UA7_Gr33k
09-27-2015 01:56 PM
