Any tranny problem with the 04TL?
Old Apr 16, 2004 | 08:20 PM
Rafiksao's Avatar
04 TL NBP-B NAVI
I was on a G35 forum and everytime a G35 owner is complaining about problems he has with his G35 (I can tell you there's a lot of them) there's always someone that writes :
hey what you have with your G35 is only a minor problem ... bla bla ... consider yourself lucky that you don't have an Acura TL with all the tranny problems !!!
What is this ? is this true ?
Has anyone with 04TL had any problem with their tranny up to now ?
Old Apr 16, 2004 | 08:23 PM
caball88's Avatar
so far no, no one on this board has had a problem with their tranny. there was a few concerns and scares but nothing developed from it.
Old Apr 16, 2004 | 08:25 PM
neuronbob's Avatar
I believe they are referring to the 2G TLs (1999-2003), which did have a transmission issue. The 2004s have no known transmission issues.
Old Apr 16, 2004 | 08:44 PM
jyg tl 3's Avatar
Unhappy tranny problems
none so far with auto. but are problems with hard shifts and grinding on 6mts
Old Apr 16, 2004 | 09:41 PM
rets's Avatar
Moderator Alumnus
Yah... that's the old sin from the past TLs... not this 04TL, at least not yet...
Old Apr 17, 2004 | 01:32 PM
DivinDude's Avatar
not yet the key phrase .. the recalls of the mdx's is not a good sign .. and well, honda has never been known for good automatic trannies .. that's what my research has concluded .. engines==bullet proof .. trannies=crap
Old Apr 17, 2004 | 03:00 PM
neuronbob's Avatar
Maybe Honda should make the trannies out of the same stuff as the engines.
Old Apr 17, 2004 | 07:58 PM
TL Montreal's Avatar
8th Gear
I've noticed that when i start my car in the morning, the first shift of the tranny is followed by a faint crunching sound. By the way i have a 5 speed auto. Does anybody else have this problem?
Old Apr 17, 2004 | 09:11 PM
rets's Avatar
Moderator Alumnus
Sound happens between P and R? Does it only occur once? Or it takes place each time you shift to R?
Could you detail it?
Old Apr 18, 2004 | 03:39 AM
5Zigen's Avatar
I have that slight clunking sound when I shift from P to D and start pulling away. At first I thought it was the automatic door locks but its not because I have it programmed to lock when I shift from P to D not when I'm pulling away. I posted a thread on this issue little while ago and a few have said they have that sound too.
Hopefully its nothing wrong.
Old Apr 18, 2004 | 09:57 AM
SilverBulletCLS's Avatar
True, but there isn't any major problems with the G35. The CL and TL and now the Odysee and MDX, Pilot all have serious tranny problems. I had CL-S and went almost through 2 trannys. I got rid of the car before the 2nd one went dead.
The 04 TL is already showing signs of the problems. Per a Acura Master Tech I know, he said they are already getting some in.
Old Apr 18, 2004 | 01:44 PM
rets's Avatar
Moderator Alumnus
Exclamation
I still believe in 5AT that sound will take place while you shift through R gear. It's normal for FWD, especially for Honda/Acura.
Old May 14, 2004 | 09:45 AM
roglab's Avatar
no i dont have that problem... i here if you race your TL in the streets of LAVAL your bound to run in to problems!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Old May 31, 2004 | 01:44 PM
klevy's Avatar
I noticed the same exact thing, usually when the engine is cold. Would like to know if this is a common phenomena.
Old May 31, 2004 | 03:35 PM
NighthawkUA662's Avatar
I'm pretty sure it's the ABS system performing a self-diagnostic. My TSX 6MT did it. So does my TL 5AT.
Old May 31, 2004 | 04:10 PM
geminis2's Avatar
So far no problems yet. at 4200 miles.
Old May 31, 2004 | 06:55 PM
6mtV6's Avatar
I6
Your right NighthawkUA662, it is the ABS system performing a self-diagnostic. My 2003 Accord coupe 6mt did it and my 04 TL does it also.
Old May 31, 2004 | 07:08 PM
Teh Jatt's Avatar
The Oracle of Acurazine!
no guys that ABS noise is different, thats when you put it to D and drive off. I think other ppl are talkin about is that when u shift from P to R or D, and it makes click noise, which is normal by acura/honda. I think this has been discussed before.
Old May 31, 2004 | 09:27 PM
rets's Avatar
Moderator Alumnus
Right. TL Montreal never comes back to reconfirm his question, but he did indicate the noise while shifting between gears instead of the noise while driving away. :o
But, IMO, whatever noise between these two, they're all Normal.
Pham Alvan
May 18, 2021 06:48 AM
SidhuSaaB
May 30, 2020 12:40 AM
Pham Alvan
Mar 16, 2016 09:17 AM
12vancover
Oct 16, 2015 12:04 PM
Matthew Purpura
Sep 25, 2015 06:10 PM
