Accord Fog Lights with Projector retro
I installed OEM accord fogs a few months back with a HID kit and the amount of glare is unacceptable to even turn on. To make my fogs actually function I will be retro fitting a set of Fog Light projectors inside the accord fogs, specifically the "Blazer" foglight kit. Just wondering if anyone here has done this I know this is a popular mod on some forums.
Here are some examples of the Blazer projectors in the accord housing
Uploaded with ImageShack.us
Alex that's not his house.
Roger I'm looking forward to seeing these done!
CARBON FIBER WDP TL
damn them projectors are nice..i got some from nissam ser mayb ill try to do that...if i knew having hid in the fogs was gonna be a killer i would of looked for this projector b4 installing
Rev High; Drive Happy
I did this with Lexus ES300 fogs.
Well... at least I planned to. I semi-cut one of the eBay Accord Fogs opened then said "screw it".
I then custom mounted the Lexus ES300 fogs on to my Acura instead and used the OEM Accord fog-wiring with mod'd H3 HIDs [switched the pigtails to H11s for the wiring].
I'm now considering doing something totally different... thinking of putting TL projectors down there---so long as if I can find 3" yellow (stained) clear lens.
Land of 10,000 lakes
If you're planning on doing this with OEM 07-08 fog lights I'm pretty sure you'll have to cut the glass cover off. At least this is what Rich had to do with mine. The whole fog light assemble is made out of metal and he just cut a piece of Lexan plexi glass to fit.
Unless, of course, you want to only work at it from behind (it'll be tougher) to keep the OEM glass [or eBay glass/eBay plastic].
those blazers are some great fogs. the blazers are OEM for the C5 corvette and many folks use HID kits in them.
here's some pics of them in my C5.
here's a shot of the blazer cutoff vs a PIAA 1100x.
i also installed them on my trailblazer.
