6MT: what a difference!!
Old Oct 26, 2005 | 12:57 AM
  #41
SodaLuvr's Avatar
Originally Posted by BG74
Michael, I know you're right. I had a '91 Civic Si and a '92 Accord EX and they both required 10W-30 engine oil for the manual trans.
Can you explain what shearing is because I have no idea.
Thanks!
Thinning out.
Mike
Old Oct 26, 2005 | 12:36 PM
  #42
ttliang's Avatar
tTLiang
Originally Posted by Michael Wan
Trial: Dunno for sure but I expect it to.
ttliang: Mobil only makes a 75w-90, which is too thick for a Honda MT. Honda MTF is a 10w-30 like engine oil with EP adds but shears very rapidly. Amsoil MTF and GMSFM are in the 9.5-10cst range which is barely a 30wt.
Mike
10w-30 engine oil with additives was what that tech told me. that i remembered cuz i was shocked by the words "engine oil". come to think of it, i am not even sure if it was mobil. many years back now. vague.. i have to find out what i used to make my MT AFU.
Old Oct 26, 2005 | 07:19 PM
  #43
pettydw's Avatar
I replaced my Honda MTF with the GM stuff (~$12/quart!) at 28K miles and can't say there is much difference in warm weather. However, no more crunching in cold weather which is about half the year here so things better. A 3/8" drive universal joint ($10 at Sears) at the end of extensions will allow fill plug removal without disassembling anything inside the engine compartment. By the way, the Honda and GM MTF look and smell the same (amber color with sulfur smell), so it is unlikely a factory technician would note a difference.
Old Oct 26, 2005 | 09:22 PM
  #44
curafunk's Avatar
[IMG][/IMG]
Old May 2, 2006 | 03:43 PM
  #45
Naidu's Avatar
Sorry to dig up an old thread, but this seemed more appropriate than starting a new one...
Anyway, my '05 6MT TL (purchased in Oct 05) had popped up its A1 service notice a few days ago at about 6000 miles. So I called the dealer to schedule the service. Just for yucks, I asked if they would be willing to change the MT fluid with another brand fluid if I supplied it. The lady taking the request put me on hold to check with somebody and came back with, "No problem, and we'll even discount the cost of Honda/Acura MTF we would normally charge for."
As background, I hadn't experienced any problems with the 3rd gear as noted by others here. In fact, I'd have to say the 2nd-to-3rd and 4th-to-3rd were one of the smoothest shifts in my car. The only problem, albeit occassionally, was with the 5th-to-6th shift. It was almost like I had to shift around a small blockage in the normal 5th-to-6th path about 10% of the time. I had no problems with 6th-to-5th.
So I tracked down a GM dealership with the Synchromesh MTF - Friction Modified elixir we've all come to love, and got me 3 quarts of it.
This morning when it was time to drop off the car at the dealership I was prepared for a long argument with the service scheduler and his manager, etc., etc. But they never blinked an eye about it. Just asked me where my 3 quarts were. And he highlighted the section in the work order which requested the technician to use my MTF instead of the dealership's. Nothing about voided warranties or requiring me to sign a waiver, etc. They treated it as almost routine.
Just picked up the car and drove it back. No big difference in the shifting that I can notice yet. And I had no problems with the 5th-to-6th shift, though it is too early to say that the problem is completely gone.
The technician clearly noted on the work order that he had drained the Acura MTF and replaced it with customer supplied GM MTF Friction Modified. They even left the third bottle in the car with half a quart of unused fluid in it.
So clearly this dealership has dealt with such a request before, and the whole transaction was quite smooth. They are Open Road Acura in E. Brunswick, NJ.
Old May 6, 2006 | 03:37 PM
  #46
s2ktaxi's Avatar
Revisiting this - I've had the occasional problem shifting into 3rd gear since the car was new but have not been able to consistently reproduce it to bring it to the dealer. Does anyone know if Acura is generally aware of this problem?
Old May 6, 2006 | 03:52 PM
  #47
gauravp123's Avatar
RBP > WDP, NBP, SSM etc
guys, my car is 3 weeks and 2 hours old, 1450 miles now and I'm a new stick driver.........
I NOTICE THE HESITATIOn going from 2nd-->3rd...I thought it was just me? IT kind fights back at me, vibrates a lil and sometimes even requires me to go into gear a second time and then it goes in...
I'll have to find this fliud and put it in...THIS FORUM IS AMAZING
Old May 6, 2006 | 07:26 PM
  #48
photopro30's Avatar
Gm syncromesh
Just a note. I also found my 06 TL to be a bit tempermental going into third from the day I bought it with 200 miles on it. The dealer changed the fluid with syncromesh and covered it under warranty! Since the change, the car shifts like it should. Flawlessly and effortlessly.
Old May 6, 2006 | 07:32 PM
  #49
HEK's Avatar
HEK
Team Nighthawk Mambo King
I changed mine at 12K and now at 18K the shifting is still as smooth as day one...IMHO is one of the best modifications you can do to your car....
Old May 6, 2006 | 08:52 PM
  #50
Spiritman's Avatar
Man of God.....
Somewhat offtopic:
Going to be using Amsoil MTF in BEETROOT's 2002 S2000 soon, will let everyone know of the results. IIRC, the car has >30K on the factory fluid. Will also switch the rear differential to Amsoil Severe Gear 75w-90; its hard to beat $27 shipped for 2 quarts of MTF and 1 quart Severe Gear 75w-90.
As always, at the first sign of any transmission problems, drain and refill the transmission with Honda MTF please.
Mike
Michael, Now I am confused "again"!! I thought you said you liked the RedLine MTF the best? I was going to buy this one over the Amzoil. Could you please help me out. I am sure I got the info incorrect. Somehow....
Which one is "THE BEST"? RedLine or Amzoil?????
Old May 6, 2006 | 08:57 PM
  #51
SodaLuvr's Avatar
Dunno if RootBeer ever used it.
The point is that you can use GM Synchromesh, as it seems to be working for the members around here quite nicely. However, it has absolutely zero endorsement by GM for usage in Honda applications, so if it causes excessive wear to your transmission, you're SOL, meaning analyze the transmission fluid to check the wear pattern of the transmission.
OTOH, Redline MTL and Amsoil MTF have always worked well, in the past, especially Redline, in Honda transmissions. I only know of one person on this forum who is using Amsoil MTF...and I think it did fine for them. The main differences between these two and the GM product is Redline and Amsoil backs the fluid for use in Honda MTF applications.
Old May 6, 2006 | 09:05 PM
  #52
Spiritman's Avatar
Man of God.....
So you wouldn't say Redline is better or Amzoil is better? I just want the best I can get for my Baby. Thats all.
Thank's Michael....
Old May 6, 2006 | 09:08 PM
  #53
SodaLuvr's Avatar
I think Kilroy? has used RL MTL before will good results.
I don't know which one is better, honestly, from an analysis or usage standpoint. All that I know is that Redline MTL has had a proven trackrecord with Honda enthusiasts for years whereas Amsoil's product is very new on the market.
Cost wise is about the same...myoilshop.com sells Redline for a very good price.
Best advice I can give you is to try both and compare...
Old May 7, 2006 | 12:40 PM
  #54
DMZ's Avatar
DMZ
Head a da Family
https://acurazine.com/forums/showthread.php?t=118339
Old May 7, 2006 | 06:04 PM
  #55
Spiritman's Avatar
Man of God.....
What r u saying? That the GM is "THE BEST"???
Old May 7, 2006 | 06:08 PM
  #56
HEK's Avatar
HEK
I think he is saying ..."it works"...and I can back him up from personal experience.....
Old May 7, 2006 | 06:16 PM
  #57
SodaLuvr's Avatar
https://acurazine.com/forums/showpos...0&postcount=10
https://acurazine.com/forums/showpos...6&postcount=14
Redline MTL appears to work too.
Old May 8, 2006 | 10:32 AM
  #58
Houstun TL's Avatar
I'm a little piggy...
Since my Dad has been an AmsOil dealer since what seems like their inception... (I'd guess 20 yrs or so) I went with the Amsoil equivalent to the GM Synchromesh.
In January, I made the switch at the same time I installed my AEM CAI (having the air box out made it really easy) and it made a tremendous difference.
I thought the TL was just a tougher manual to drive until I made the switch. If you haven't done it, do it. You won't regret it!
Old May 15, 2006 | 01:46 PM
  #59
redrum4me's Avatar
I just switched out the GM stuff for redline mtl. As much as GM synchromesh gets raves on this forum, I prefer Redline. The car seems to shift better…. more of a silky feeling than before or a hot knife through butter. I will definitely be sticking with redline in the future. Especially since its up to 5 dollars cheaper per bottle!!!
Recipe7
3G RLX (2013+)
45
Dec 7, 2015 06:43 PM
blacktsxwagon
Oct 27, 2015 10:12 PM
joflewbyu2
Oct 8, 2015 11:16 AM
thegipper
Sep 28, 2015 01:01 PM
eastcoastguy
Sep 23, 2015 06:29 AM
