3G TL Spark Plug Replacement DIY?
There is a lot of great info in the 3G Service Dept: https://acurazine.com/forums/3g-tl-2004-2008-93/3g-tl-service-department-aka-garage-questions-answers-check-here-first-553557/
Here you go: https://acurazine.com/forums/3g-tl-2004-2008-93/122-diy-105k-service-timing-belt-water-pump-spark-plugs-thermostat-%2Apics%2A-784622/
There is a lot of great info in the 3G Service Dept: https://acurazine.com/forums/showthread.php?t=553557
Here you go: https://acurazine.com/forums/showthread.php?t=784622
Couple suggestion, blow out the plug cavity before removing the plugs and use a piece of rubber hose attached to the plug to start in the threads to avoid crossthreading that can easily be done if you don't have a touch with a socket.
Great thread and link. Did my plugs last week. Improved my idle instantly. I also used some Deep Creep to clean out the throttle body area. The valve had some build up. I do this every time change plugs. Thanks for the info here! Helps us noobs out.
cycdaniel
Dec 17, 2019 10:58 AM
