3G TL body kit question?
Does the 3G TL A-Spec body kit protect the side of the car from dirt and rocks kicked up by the tires as much as the mudflaps do? So those of you that installed the kit, is the car dirtier with the kit installed and the mudflaps gone?? Your thoughts on this?? Thanks.
Ryan Christopher
Originally Posted by Black_05_TL_6SP
That would be negative!! The side skirts are not designed to protect the side of the car, and the A-spec ones do not come out much more then the base ones.
Originally Posted by stillhere153
How could they... the correct question might be can you install the sideskirts and the mudguards at the same time?
![Tongue](https://acurazine.com/forums/images/smilies/tongue.gif)
Kaa - Ching !!!
Location: Rhode Island.....Self-Proclaimed Chromed Cousin of Brettallica
I've never seen anyone use both the MF & Aspec skirts mainly because you would need to seriously cut/modify the flaps to fit over the new skirts.
No I am just curious that if I remove my mudflaps and put on the A-Spec body kit. Will the sides of the car then show more of the dirt and mud kicked up by the tires that the mudflaps would have deflected? Thanks.
![Yes](https://acurazine.com/forums/images/smilies/yes.gif)
Overall, the look of the A-Spec body kit outweighs the small amount of dirt that can be easily cleaned off.
P.S. It will require a lot of modification to get the mudflaps to attach with the A-Spec body kit. Its either or; you can't have both.
I live in the Northeast and we get lots of snow. The road crews throw down chemicals to melt the snow so your car is covered in this white chemical residue. So you need to wash it off but when the temperatures are in the 10 degree range for days it is hard to wash the car. So my mudflaps perform a needed function probably more than most. So I just want to make sure the body kit can fill in for the mudflaps.
94 DC4 RS LSV/Turbo
Oooops guess I misinterpreted you, but I don't think the sidekirts do the same job as the mudflaps... I to get those snow days where salt mixture with some other stuff is thrown down and makes the cars look like a nuclear fallout...
But um I think when I do decide to add the A-Spec kit I am going to cut the mudflaps to fit with the sideskirts... No matter how difficult it is
Zonian22
11-14-2015 01:20 PM
09-04-2015 08:03 AM
Zonian22
09-02-2015 08:19 AM
