The 3G Ramblings & General Discussion Thread (Trois)
Old 07-19-2015, 06:28 PM
  #16321
I hate cars's Avatar
Received 1,812 Likes on 1,283 Posts
Originally Posted by N1h1l1ty
While I still seriously doubt that the RL calipers are going to catastrophically alter the bias (again, I stand by what I said, plenty of people have run them and have been very happy), Ill take into account what IHC has pointed out and likely go the Stoptech touring route instead - I'm sure someone will pick up the calipers off me. My other (bigger?) concern is the potential headache of the 350z rotors not fitting at this point.
Do you know the piston sizes of the RL and stock calipers? If the piston area is the same you're good.
You can get away with a little difference from stock. I don't mean to sound like a few percent will cause you to die in a horrible crash.
The one thing that's not certain is how far the EBFD can adjust. Certainly there's some learning going on. If you go through with the project, I would not add a prop valve. I know the EBFD needs stops that are on the edge of traction but without ABS fully engaging to learn. It might have enough of a range to compensate.
I don't want to ruin your project. If you can get the piston sizes, we can plug them into the calculator along with rotor size. Sometimes an OEM will use the same piston area in all of their calipers from a single to a 4 piston setup, the TL Brembo vs base is a good example of two drastically different calipers having about the same area. I might already have this info, I did the calculations once.
It might be little enough that you can use a less aggressive pad in the rear and more aggressive up front. The penalties aren't as big with ABS equipped cars as with older cars. Plus they're on the rear and not the front so it's not that bad.
I'll never forget going with a super aggressive set of rear shoes on my car so the brakes could hold it back better when power braking. It would lock up and go sideways under completely normal stops. This lasted for 2 days before I pulled them off. At least with the TL the ABS is there to save you.
I hate cars is offline
Old 07-19-2015, 06:32 PM
  #16322
I'd like to see a comparison of your stock brakes and the "upgrades" you're looking to do. An honest, no BS, before and after comparison on stopping distances.
One of those honest before and after comparisons hurt my feelings after upgrading to the Rotora BBK. The car stopped quicker from triple digit speeds but from lower speeds it stopped shorter with the stock brakes. I think the better stopping from triple digit speeds was only because of the greater pedal feel and not wanting to hit full ABS.
The following 2 users liked this post by I hate cars:
rockstar143 (07-20-2015), TacoBello (07-19-2015)
Old 07-19-2015, 06:39 PM
  #16323
Confusing Name Guy
N1h1l1ty's Avatar
It's all good Matt, I know you mean well
I will try and find the piston sizes today and see if I can get something figured out. I actually gave some thought to changing the TL's master cylinder to the RL master cylinder so that the correct line pressure could be applied - the two cars do use the same rear calipers, and I believe the rear rotor sizes are similar, and from what I understand of ABS, it isn't actually tied into the hydraulics of the brake system but rather just senses the wheel speed. I also (obviously) realized after some further reading that a prop valve with ABS / EBFD equipped modern cars is a no no as it won't truly change brake bias the way its supposed to.
When you meant "little enough" in regards to the pads, did you mean it would actually be feasible that an aggressive compound pad in the rear would balance the now larger clamping force in front? I.e, EBC redstuff or similar aggressive pads in the rear and an OEM pad in the front?
As for what I'm trying to achieve with the upgrade, well, decreased brake fade. I'm aware that it won't net me decreased stopping distances. I try to use ABS as little as possible as I find it more detrimental than anything else (also one of the major reasons I drive with VSA and TCS off 100% of the time.)
N1h1l1ty is offline
Old 07-19-2015, 07:31 PM
  #16324
Confusing Name Guy
N1h1l1ty's Avatar
Also disregard what I said in regards to the RL having a similar rear disc, thats prior to the 2nd gen RL, which does in fact have 16 mm thick vented rotors in the rear, which are sizeable (12.2 inches) bigger than the TL.
N1h1l1ty is offline
Old 07-19-2015, 10:13 PM
  #16325
TacoBello's Avatar
Received 4,416 Likes on 3,322 Posts
I'm sorry, but there is just NOT enough salad tossing going on here.
Shiiiet, if I wanted to learn something, I'd go hang out in Problems and Fixes
TacoBello is offline
Old 07-19-2015, 10:30 PM
  #16326
Confusing Name Guy
N1h1l1ty's Avatar
Matt,
The RL master cylinder/brake booster should be interchangeable with the TL one - same bolt pattern etc. (and by bolt pattern I mean the bolts on the booster plate to mounting location on the car)
Both have an integrated prop valves for front and rear brakes. With the valves being pre-set for stock brakes, I'd imagine the RL master cylinder/brake booster would actually send more line pressure to the rear on the RL since it has larger rotors in the back than the TL. The calipers between the two cars look identical (although I can't confirm this with part numbers).
Any thoughts on this? I mean you can buy the entire master cylinder/brake booster assembly for the RL for a mere 80 bucks off ebay. From what I saw with the RSX crowd upgrading to the DC5 (6MT/Type S brembos) they would upgrade their MC/Booster to the RSX-S or even the TL one, so I don't see why the same wouldn't apply here, beyond the rear brakes being off in this case, something I could potentially solve with larger vented rotors.
N1h1l1ty is offline
Old 07-20-2015, 06:36 AM
  #16327
rockstar143's Avatar
Received 20,015 Likes on 14,518 Posts
steet and track dedicated set of pads
stainless lines
high temp performance fluid
goodbye fade, I'm almost certain.
but lesbianas. You're after the bling!
and who can blame you.
Good morning everyone!
Happy Monday!
rockstar143 is offline
Old 07-20-2015, 07:38 AM
  #16328
Received 16,267 Likes on 11,974 Posts
lesbehonest, here...
justnspace is offline
TacoBello (07-20-2015)
Old 07-20-2015, 07:45 AM
  #16329
Confusing Name Guy
N1h1l1ty's Avatar
stainless lines
Happy Monday!
Meh
I've got the calipers and bracket already, might as well see if I can make it work / try it out.
Also fun fact, the 6MT TL and 5AT TL share the same brake master cylinder and booster (checked this last night). What's more, the piston surface area between the TL brembos and 5AT is the same I believe, which is interesting because the brembos use larger rotors, perhaps leading to more front brake bias (obviously not as drastic as the transition to the RL rotors, but again, food for thought)
N1h1l1ty is offline
Old 07-20-2015, 07:55 AM
  #16330
^honda says the automatic brakes stop shorter than the brembos by 1 foot.
I suspect the larger rotors with the brembos act as a heatsink to rid away heat faster, afterall isnt that the whole point of brembos...to prevent brake fade?
Old 07-20-2015, 08:05 AM
  #16331
Confusing Name Guy
N1h1l1ty's Avatar
Oh I fully believe it, in fact I'm starting to suspect the piston area of the 5AT single piston is larger than the Brembos too, I just cant confirm it without pulling off the caliper.
I have 0 doubts that the RL calipers ARE going to be slightly detrimental to stopping distance. Again, not too worried about this. Like Jeremy so aptly put it - as a renown lesbian, I'm after the bling. Oh and reduced brake fade. Yeah, totally
There are definitely additional options here to make the swap more viable as an actual performance mod. I think the master cylinder swap for example is intriguing because it shouldn't affect the ABS / EBFD system seeing as they work off of the wheel sensors themselves to determine when the inline ABS solenoids need to work.
I should say that seeing as sticky tires are the #1 thing needed for reduced braking distances, I've got Conti DWs which I'm extremely happy with, and will probably be getting new winter shoes (open to suggestions, the Yokohamas I bought last season are AWFUL), so I'm sure I've already got reduced braking distance from factory.
N1h1l1ty is offline
Old 07-20-2015, 08:44 AM
  #16332
We're splitting hairs here...
and after all, this is ramblings!
Cawk. Ballz.
Old 07-20-2015, 10:40 AM
  #16333
Flipster23's Avatar
Received 2,334 Likes on 1,962 Posts
Shitter in the shitter
Flipster23 is offline
Old 07-20-2015, 10:41 AM
  #16334
Flipster23's Avatar
I got my tat last night, says lick here on my ass.....
Although, mah dude told me some stories about people getting tats, on their ass.
Old 07-20-2015, 10:49 AM
  #16335
TacoBello's Avatar
Wtf. It was supposed to say "insert here"!!
Old 07-20-2015, 10:50 AM
  #16336
TacoBello's Avatar
How was the weekend, y'all?
Old 07-20-2015, 10:55 AM
  #16337
Flipster23's Avatar
Decent, Hung out with my wife and kids. Did a little shopping and got the tattoo last night.
Old 07-20-2015, 11:00 AM
  #16338
cu2wagon's Avatar
Received 7,772 Likes on 5,045 Posts
I was up late on Saturday studying. So naturally, to unwind a little, I was chugging Monster Energy (lo-carb because mah figure) and vodkas.
Sort of blacked out and when I woke up on Sunday, the bills on all my hats had been ironed flat and there was a Papa Roach CD stuck in the toaster.
Sunday was hot and humid AF but spent time at the park and went to the pool with the fams. I think I cooked my brain and my eyes burn today.
cu2wagon is offline
The following 2 users liked this post by cu2wagon:
rockstar143 (07-20-2015), TacoBello (07-20-2015)
Old 07-20-2015, 11:04 AM
  #16339
TacoBello's Avatar
Originally Posted by usdmJON
According to CarID, the only thing us tuners want are bright blue lights, black cars, and the same wheel choices for all of them.
Apparently putting 'authentic' wheels and lowering springs on your car makes Jon a tuner now.
Why do I have a sneaking suspicion Jon has never even opened up any tuning software before in his life?
F&F has made the term "tuner" apply to errrbody
Old 07-20-2015, 11:06 AM
  #16340
TacoBello's Avatar
I didn't do much this weekend. Had brunch with fam yesterday. Went to the dog park also for a few hours to tire the pupster out.
Weekend was slow due to Wifey putting her back out. Fuck, who knew she couldn't lift that fridge into the basement all by herself. It was definitely lighter than when I made her lug that 6.2L V8 around.
Old 07-20-2015, 11:12 AM
  #16341
Yumcha's Avatar
Received 22,947 Likes on 14,061 Posts
Morning all.
Yumcha is online now
Old 07-20-2015, 11:23 AM
  #16342
Flipster23's Avatar
Henry.
Old 07-20-2015, 11:26 AM
  #16343
TacoBello's Avatar
Cu2, uh, I mean, Earnest, your responses in the RLX section are priceless
Like this gem: https://acurazine.com/forums/third-g...-proof-933814/
cu2wagon (07-20-2015)
Old 07-20-2015, 11:31 AM
  #16344
Majofo's Avatar
Received 11,843 Likes on 8,574 Posts
I love cock.
Just my own though.
Only you could love and appreciate something so small..
Okay.. just catching up on some bullshit.. Please go back to your build thread. K, thanks.
Matt,
FFS...
Next time you pull up to the bumper and see Majofo's name tattooed on that ass.. know that I have ruined it for all thereafter. Continue your journey in anether region.
Majofo is offline
Old 07-20-2015, 11:49 AM
  #16345
It's above average!
  #16346
average is 2 inches, right?
Old 07-20-2015, 11:50 AM
  #16347
Majofo's Avatar
You wish you had 2 inches
Majofo is offline
Old 07-20-2015, 12:06 PM
  #16348
Majofo's Avatar
washed the V yesterday.. she's such a dirty bitch. I also put her on ramps for the first time. I think I'll build custom ramps for her. It was a little hairy.. like landing strip hairy, except the patch of hair was super dense, coarse, and unwieldy.
Majofo is offline
Old 07-20-2015, 12:09 PM
  #16349
Majofo's Avatar
I ususally take the car to a touchless wash for a rinse and dry before a fine wash at home (try to knock off most of the bird shit and road dust). This will be the first and last time I do that with the V.. I heard the roof buckle under the hair dryers.. luckily it flexed back on it's own.
Majofo is offline
Old 07-20-2015, 12:16 PM
  #16350
GM's cost cutting at its finest.
Old 07-20-2015, 12:18 PM
  #16351
Majofo's Avatar
butt buttt I haz real carbon fiber in the interior!!!
Majofo is offline
Old 07-20-2015, 12:20 PM
  #16352
That's the universe telling you you need a convertible.
Clean V, huh? You put plastidip the grill and throw them (D's) 22's on it yet?
Old 07-20-2015, 12:22 PM
  #16353
Majofo's Avatar
Dem choppas mang!
Majofo is offline
  #16354
Mom stopped by...she's like, "can you just spray the dirt off the back of the car please". I'm was like... you mean wash your fkng car for you? I was like, you can't play me cause I know you're doing it...
Ma dukes...did the whole thing, wax, exhaust polish...interior. She was happy...she's like, well no honey, not what I meant but THANKS!
Old 07-20-2015, 12:23 PM
  #16355
choppas...that's right. Donk a V...immediate death!
  #16356
Although that's one of the few cars with enough factory power to handle the 100 pound chrome on each corner.
Old 07-20-2015, 12:25 PM
  #16357
Majofo's Avatar
Dey see me rollin'' dey hattin''
Majofo is offline
The following 2 users liked this post by Majofo:
justnspace (07-20-2015), rockstar143 (07-20-2015)
Old 07-20-2015, 12:30 PM
  #16358
Paul to the Wall!
Old 07-20-2015, 12:31 PM
  #16359
Majofo's Avatar
I got deezzz elbowwss mang!!!
Majofo is offline
Old 07-20-2015, 12:32 PM
  #16360
shit, dont play.
i'll take them off your hands, homie hook up price.
Quick Reply: The 3G Ramblings & General Discussion Thread (Trois)
