The 3G Ramblings & General Discussion Thread (Quattro)
Old 02-04-2016, 12:15 PM
  #1241
TacoBello's Avatar
Received 4,416 Likes on 3,322 Posts
Hmmmm.... Got it ...
And yeah turning is important..... Sometimes..
I have some Ichiba 15 and 20 mm spacers sitting in a box waiting to be installed..
And a set of 8.5's waiting to be repaired/refinished have rubber mounted and installed..
Don't plan on lowering too much if at all..
Just trying to figure out my options..
Thanks for the feedback!!
I think you'll have to lower if you want to complete the look. You don't have to slam it, but a little drop goes a long way. I'd do the wheels, tires and spacers first, before Dropping though, just so you know where you're at and see where you want to be.
By the way, those A-Specs along with spacers on will be adding a lot of unsprung weight, and it'll be a lot more mass for the engine to have to turn over. Your acceleration will suffer. Braking might be a bit effected, but not nearly as noticeable. Handling will be different also.
I find it's not generally as noticeable when you put a heavier/bigger wheel on, but if you ever go back down in size for whatever reason, you'll be like "holy fuck. This car feels completely different".
TacoBello is offline
Old 02-04-2016, 12:19 PM
  #1242
Ambitious newbie
Techneecs's Avatar
Looks like Tyler was just barely rubbing. You could likely do a 10mm spacer and be fine. Maybe even 15mm.
The beefy tires look doesn't change the offset of the wheels. So yes, still sunken look, however, slightly less.
You can still lower your car, but Tyler was pretty dang low. You could likely drop your car 1.5" and not have a problem.
Ok cool hearing it said like that made it click..I am finally feeling learning happen as far as offset/wheels/tires goes.
Techneecs is offline
  #1243
Received 8,675 Likes on 6,693 Posts
I'm all about balance function and form.. I bought the spacers a while back at a good price without even thinking if I would ever use them. I'm not dead set on using them if not necessary either.
thoiboi is online now
Old 02-04-2016, 12:27 PM
  #1244
TacoBello's Avatar
Shiiiet, Thoiboi be buyin shit he dun need and spendin money like it's nuttin.
Old 02-04-2016, 12:29 PM
  #1245
Yeah I'm honestly as non as can be.... That's why Maj always called me Connie Chung banana mother fucker..
So endearing... That man did have a way with his words
  #1246
Maybe I should just sell the spacers... Anyone need?
Old 02-04-2016, 12:31 PM
  #1247
TacoBello's Avatar
I'll take one of each size. Gonna start a new trend
Old 02-04-2016, 12:36 PM
  #1248
Ambitious newbie
Techneecs's Avatar
dibs! what size?
Old 02-04-2016, 12:38 PM
  #1249
TacoBello's Avatar
Read, motherfucker. He just posted it!!
Old 02-04-2016, 12:39 PM
  #1250
Ambitious newbie
Techneecs's Avatar
Ok look I am at work and I have to keep an eye out for salty Sergeants so you will forgive me if I miss a post or two or five.
Old 02-04-2016, 12:40 PM
  #1251
  #1252
Excuses... We're all always at work...
Old 02-04-2016, 12:45 PM
  #1253
TacoBello's Avatar
wtf do you do for work?
  #1254
Ambitious newbie
Techneecs's Avatar
Alright so you said I should be good at 15 but will the 20 be ok in the back? I guess I could just adjust it with the coils it catches
Old 02-04-2016, 12:46 PM
  #1255
TacoBello's Avatar
Salty sergeants... That sounds naughty
  #1256
dibs! what size?
But since you're so busy they're 15 and 20mm they're the type two so you don't need extended studs.
I think he's in the
  #1257
Ambitious newbie
Techneecs's Avatar
Honestly not a God damned thing. I'm "training" so you know ...read the forums and look busy
Old 02-04-2016, 12:47 PM
  #1258
15f/20r is what 3ger's typically run.
Old 02-04-2016, 12:49 PM
  #1259
TacoBello's Avatar
It depends on how low you go, how wide of a tire you get, how big the spacer is, etc. there are multitude of combinations that will work.
If you know that the stock tire is 235, if you move up to 255, you're essentially adding 10mm on closing the gap (10mm per side). So measure the gap now, add 10mm to it and see how much of a spacer you can realistically still fit.
Keep in mind, if you corner hard, etc, some body lean will occur, so you still need to maintain a bit of a gap, for functional purposes.
Old 02-04-2016, 12:51 PM
  #1260
Ambitious newbie
Techneecs's Avatar
Cool I'll do that and let you know thoi
Old 02-04-2016, 12:52 PM
  #1261
TacoBello's Avatar
Ok, but you're at the base? Any their are sergeants peering into your anus?
Just curious to know what kind of circumstances you work in. Not trying to creep on you or find out your true identity, or whatever the fuck. Not my style.
Old 02-04-2016, 12:55 PM
  #1262
Ambitious newbie
Techneecs's Avatar
I'm off site ..I work in an office full of cubicles and shoulder surfers so I'm constantly switching screens.
Don't think too many Sgts would take too kindly to half naked dudes on skates on my screen..
Old 02-04-2016, 01:00 PM
  #1263
Don't ask don't tell
  #1264
Oh also shipping should be fairly cheap if I bring them with me to Raleigh and we meet halfway or I just ship them from here or whatever.. let me know!
Old 02-04-2016, 01:13 PM
  #1265
CLtotheTL32's Avatar
Received 9,502 Likes on 6,173 Posts
Barely rubbing? Chunks of tire were left in my driveway The inner lip of my front fender was pulled out by the tire and I had to grind it down with a Dremel to clear. That was with 235s with my coilovers.
I had 15/20mm spacers. Even with rolled rear fenders and TEIN S-Tech springs, I rubbed in the back with 245s. I had no issues with 235s running -1.5 camber all around.
CLtotheTL32 is offline
Old 02-04-2016, 01:16 PM
  #1266
Ambitious newbie
Techneecs's Avatar
I will ..I got my ruler ready to go and wverything..I feel like I should be good since I'm on 245s already
Old 02-04-2016, 01:17 PM
  #1267
Ambitious newbie
Techneecs's Avatar
Damnit
Old 02-04-2016, 01:18 PM
  #1268
Flipster23's Avatar
Received 2,334 Likes on 1,962 Posts
Reported..... to Ron A.......
Please post all for sale items in the Black Market.....
Reported to Obama, because Acurazine is racist calling it the black market.
Flipster23 is offline
Old 02-04-2016, 01:24 PM
  #1269
It's just a feeler.
I.e. Trying to feel him up
Old 02-04-2016, 01:27 PM
  #1270
Ambitious newbie
Techneecs's Avatar
It's just a feeler.
Old 02-04-2016, 01:28 PM
  #1271
Ahhhh Tom & Jerry... One of my old favorites as a child....
#throwbackthursday
Old 02-04-2016, 01:30 PM
  #1272
Ambitious newbie
Techneecs's Avatar
One of my favorites still. I bought Bommerang just so I could watch tom and jerry, flintstones etc
Old 02-04-2016, 01:44 PM
  #1273
Ambitious newbie
Techneecs's Avatar
So I measured it and it looks like I have 17 mm in the front and like 19mm in the back
Old 02-04-2016, 01:55 PM
  #1274
Oh you have much more than that in the front.... I can tell you that from all the way over here
Old 02-04-2016, 02:01 PM
  #1275
Yumcha's Avatar
Received 22,777 Likes on 13,968 Posts
Another busy day so far...
But, at least I was able to get in a workout. No gymming for next week as I'm off on some vacation (more to do some home design stuff for the place we're building and to take Little Cha for some medical checkups)...
Yumcha is online now
Old 02-04-2016, 02:07 PM
  #1276
Ambitious newbie
Techneecs's Avatar
Maybe I measured with the wrong method then..
Yamcha
Old 02-04-2016, 02:08 PM
  #1277
TacoBello's Avatar
Thoiboi just wants to see your dick.
Old 02-04-2016, 02:12 PM
  #1278
Yumcha's Avatar
I want to see your Omega Supremes.
Old 02-04-2016, 02:14 PM
  #1279
Sounds like my vacations last year ...
Get some real time off, you know you're not a real robot right...?
Old 02-04-2016, 02:17 PM
  #1280
TacoBello's Avatar
Here is the architectural rendering of Yumcha's new house.
Quick Reply: The 3G Ramblings & General Discussion Thread (Quattro)
