The 3G Ramblings & General Discussion Thread
Chapter Leader (Midwest Region)
Texas has two seasons.
1.Summer
2.winter
Usually they alternate days within the same week.
Yesterday was 80.
today; 45 degrees.
1.Summer
2.winter
Yesterday was 80.
today; 45 degrees.
Undying Dreams (12-11-2012)
**The Catfish**
im assuming that the cruise button on the steering wheel is pressed before you try to set. Check the crusie control module behind the strut bar on the passenger side firewall and make sure that it is still attached to the strut bar.
**The Catfish**
I remember reading about the switch going bad now that i think about it. Try holding the switch down and see if it engages. if it is the switch, its pretty simple to swap it out and its also fairly inexpensive.
http://www.oemacuraparts.com/oem-par.../36770-sep-a01
I like turtles
yea the switch will not engage whether i press it multiple times or just hold it down, i am going in for an oil change this week so Ill have them tell me the exact problem and see if im able to fix it. (car noob)
Desert Life Sucks!!
I set cruise at 138 one night on way to Alburquerque just to see if it would do it. It did.
Received 6,470 Likes
Yea, I saw where Dallas got some snow....couldn't believe that.
:what:
There are switches on the brake pedal that control the brake lights and cruise. I have seen the rubber pads that the switches contact with disintegrate and have even seen the witches get kicked and knocked out of alignment (cheap plastic). There are usually 2 switches. One for cruise and one for brake. In my Nissan pickup, both switches have to be in working order for the cruise to engage. Check the switches.....never hurts...
One easy way to determine if it is the switches is to firmly lift up on the pedal with your foot to see of the problem goes away.
Received 3,824 Likes
welp, the Texans fuggin Sucked ass. hole
Well.. Schaub made some bad decisions. Everything went wrong for Texans and right for Pats.. I don't think the Pats could Rout the Texans like that again. Texans need to tighten up their coverage if they want to win it this year.
If we wanted to see dumb gifs, we'd go to your tumblr WD.
Hippy.
Hippy.
Same goes for dumb pictures of your stuffed rape cat.
Wacker! Is this you?!
The one and only time Wacker has worn shorts... well.. we assume. Everyone whose seen this is now blind.
Nice shirt Wacker!
:what:
LOL!!! So.....I go away for a bit and this is what you choose to do....NOICE!!!!
Wow....epic posts here today!
Desert Life Sucks!!
All 21 of them. I can't find that thread on rear deck rattle. I would like to attempt to fix that before I put my back seat in. Guess will just have to crank up some music and dig around.
I like turtles
takin care of Business in
Received 4,732 Likes
morning fellas
Morning
