3G Lower Grille Mod***pics***
Old Oct 7, 2006 | 07:55 PM
jmaikamon's Avatar
OK all...I finally took the plunge and decided to mod my grille. Took me about 3 hours and cost $6.95 for mesh (have 3 pieces leftover), $3.99 for glue, and $2.99 for spray paint. Tell me what you all think.
[IMG][/IMG]
[IMG][/IMG]
Old Oct 7, 2006 | 08:02 PM
ayethetiense's Avatar
.:KCCO:.
eh...
what part did you spray? it may start to chip if ur not careful
Old Oct 7, 2006 | 08:11 PM
jmaikamon's Avatar
Originally Posted by ayethetiense
eh...
I sprayed the grille after I cut the ribs out and sanded it. I used satin black specifically for plastic. If it does chip I'll re-do it.
Old Oct 7, 2006 | 08:13 PM
NC Silver's Avatar
That looks very sharp! Nice job. Is that the same mesh as the other posts (gutter guard from a home improvement store)?
Old Oct 7, 2006 | 08:17 PM
jmaikamon's Avatar
I forgot, I payed $2.99 for the door strip.
Old Oct 7, 2006 | 08:21 PM
jmaikamon's Avatar
Yes it is. I got 5x 3' pieces for $6.95. Its galvenized.
Old Oct 7, 2006 | 08:36 PM
subinf's Avatar
One on the right for me
I like how it looks. Good work.
Old Oct 7, 2006 | 09:12 PM
whatjones911's Avatar
did they have mesh that had bigger holes?
Old Oct 7, 2006 | 09:15 PM
acuintegra's Avatar
wow...I think it looks great!!
Old Oct 7, 2006 | 10:38 PM
pohljm's Avatar
Now that I have the A-spec lip is on it is much more difficult to remove the grilles, so I did the exact mod except I clear coated the galvanized mesh so it would maintain its finish. Not sure what you used the glue for as you do not need to glue the mesh to the frame as the frame sandwiches the mesh securely into the bumper.
As far as larger holes in the mesh go......check out McNichols.com for all your mesh needs. The product that we all used....Gutter Guard works nicely because the dimension that you need to cut it to in order for it to fit happens to fall directly on a full module of the mesh so there are not any sharp legs of metal protruding. I have also cut a piece that fits nicely in the A-spec rear underbodyspoiler but I have been to chicken to cut out the opening for it.
Old Oct 7, 2006 | 11:44 PM
jmaikamon's Avatar
I didin't see any, but then I wasn't looking for that. They had some plastic mesh also but the holes looked the same.
Old Oct 7, 2006 | 11:51 PM
jmaikamon's Avatar
You are right, I didn't think about that. It does sandwich between the grille and bumper. I glue ewelded the mesh to the grille after I emoved the ribs. It makes the grille rigid after cutting out the ribs. Post a picture of yours.
Old Oct 8, 2006 | 12:29 AM
Bootlegged's Avatar
So the plastic frame was spray painted black and the gutter guard was just left as is?
Old Oct 8, 2006 | 12:44 AM
jmaikamon's Avatar
Yes, I spray painted the grille (to cover the sanding after cutting) and left the gutter guard as is. The bumper guard was left as is too.
Old Oct 8, 2006 | 12:54 AM
Bootlegged's Avatar
Another question:
How did u cut the grill and with what tool(s)?
I'd like to do this mod... looks pretty slick
Old Oct 8, 2006 | 02:00 AM
pohljm's Avatar
Another question:
I used tin snips, or aviation shears whatever you wish to call em.
Krylon makes a special paint called "fusion" it is intended to be used on outdoor plastic products. Use some spot putty and some sanding and the satin black finish comes out looking very good.
Old Oct 8, 2006 | 11:20 AM
johnnybn's Avatar
Got any pics of it in the daylight? Did you pull the front bumper or did you just squeeze the grilles out without removing the bumper?
Old Oct 8, 2006 | 12:14 PM
PPLAPW's Avatar
I'm in
Looks good.....
Another gold TL......
Old Oct 9, 2006 | 09:07 AM
jmaikamon's Avatar
Another question:
I used tin snips at first to cut it out. After I put it on the grille I realized I could make it fit perfectly so there were no fitting issues and I used some needle nose wire cutters I had laying around. With this however, you can only cut one at a time. Then I used a tiny 8" hammer I had and tapped around the edges as it layed on the grille and it fit perfectly.
Old Oct 9, 2006 | 09:14 AM
jmaikamon's Avatar
I out of town till next weekend but I can take some pictures then. No, I didn't pull the front bumper off. It was surprisingly easy to take off through the front bumper. You can reach all the holding clips except for the last two with your hands. When you release the other clips, those two aren't a problem and it comes right out with a little jiggling. I also tried a long thin flatheat srewdriver on the other side and it works as well.
Old Oct 10, 2006 | 12:50 AM
rockyfeller's Avatar
King of NYC
looks about 4000x times better. I am a big fan of this mod, waiting till spring to clear the headlights, mesh the lower and main grill all at once.
Old Oct 10, 2006 | 12:57 AM
SlimTL's Avatar
I plan on doing this to my TL as well. Do you all think this combo (silver mesh with chrome molding) would look good on the nighthawk black (NBP) TL or should I stick with black mesh with chrome molding?
Old Oct 10, 2006 | 01:32 AM
pohljm's Avatar
SlimTL, On my RRP I am not a fan of the galvanized mesh with the chrome center strip. I initially started with blacked out mesh but it looked pretty much like stock to the untrained eye. I wanted more contrast so I went to the galvanized mesh and just the black framework. I wasnt feeling the chrome in front of the galvinized finish. The trim around the center grille is not chrome, so I think the galvanized mesh matches up with that better and the chrome was somewhat of a distraction. It looks fine on the black mesh.
Old Oct 10, 2006 | 01:35 AM
jmaikamon's Avatar
I think the chrome on black would make the lower grill the center of attention and draw attention away from everything else. I would have to see it to be sure though.
Old Oct 10, 2006 | 10:05 AM
AcurasGhost's Avatar
Tint The Windshield
Looks good man... i think it looks best on the silver cars.
Old Oct 10, 2006 | 10:12 AM
Ryee's Avatar
RIP Dime...
Oh man, nice work! That looks really sharp.
Old Oct 10, 2006 | 12:28 PM
nan08's Avatar
nice job. can't wait for some more daylight pics.
Old Oct 10, 2006 | 07:54 PM
neuronbob's Avatar
Looks sharp, man. Excellent job for virtually no money.
I give the official neuronbob™ .
Old Oct 10, 2006 | 10:03 PM
pohljm's Avatar
Here are couple daylight shots of my RRP with the clear coated galvanized mesh.
This mesh is just sandwiched in, there is no epoxy used.
Old Oct 10, 2006 | 10:23 PM
CleanCL's Avatar
where did you guys purchase the mesh?
Old Oct 11, 2006 | 12:23 AM
pohljm's Avatar
lowes or home depot will have it in the rain gutter section as "gutter guard"
Old Oct 11, 2006 | 01:36 PM
King of NYC
If you have NBP, I'd say paint the mesh black. I've seen it done both ways and black definitely looks hot, unless you have some kind of black/silver theme on the exterior going on.
Old Oct 11, 2006 | 01:38 PM
King of NYC
Old Oct 11, 2006 | 04:47 PM
Bootlegged's Avatar
Yeah, I just completed this mod on my NBP and painted the mesh black. I'm really pleased with the outcome. I think the silver would have stood out too much and clashed...
Old Oct 11, 2006 | 06:37 PM
SlimTL's Avatar
Great. I'll try with just the black mesh first. I'll also do a sample with the silver just to see how it looks. I liked the silver mesh because I thought it would fit good with the silver color stock wheels and the centerpiece Acura aluminum grill.
Anyone else have pictures of the whole front end with this mod?
Old Oct 11, 2006 | 06:44 PM
SlimTL's Avatar
Well the car is black, but the only other colors on the exterior are the aluminum wheels and grill, silver muffler tips, gray insert in rear body kit, rear aluminum trim, and the red tailights (which will be replaced by the '07 type-S lights).
So the theme is kinda black and silver. Just wonder if the silver mesh would blend in with the car's theme or just use black mesh with silver strip trim. Wish there were more pics out there.
Old Oct 11, 2006 | 06:45 PM
SlimTL's Avatar
Can you zoom out and post a pic of the whole front?
Old Oct 11, 2006 | 08:13 PM
jmaikamon's Avatar
Got mine at Lowes. Think it was $6.75
Old Oct 11, 2006 | 08:17 PM
jmaikamon's Avatar
I actually thing its inexpensive enough for you to try both. Since you don't have to glue it (enless you want to) you can try em both and see which one works for you.
Old Oct 11, 2006 | 08:19 PM
jmaikamon's Avatar
Pohljm, I gotta tell you that your mod was spot on. Looks like you took your time. Well done!
