2007 Base TL Conversion
Old Feb 12, 2010 | 02:09 PM
Kartel2383's Avatar
I searched but could not find clear answers. Does anyone know what exterior parts are needed to make a 2004 Base TL convert to a 2007 Base TL?
Old Feb 12, 2010 | 03:10 PM
gotkilled's Avatar
NBP is a pain...
afaik, 07-08base wheels, 07-08 side mirrors with turn blinkers, 07-08 taillight and 07-08 front and rear bumper.
Old Feb 12, 2010 | 03:55 PM
cjTL's Avatar
I'm Craig
Yup. Along with lower fogs and different headlights that feature DRLs. Some wiring will be required for the conversion.
Old Feb 12, 2010 | 04:02 PM
csmeance's Avatar
New Front bumper including grille pieces and fog-lights.
New Headlights
2007 Base TL split 5 spoke rims
2007 Base TL Blinking side mirrors
2007 Base TL Badges, it's straight on ours italicized on 07+
2007 Base TL Bumper
If you want to be a bit more critical
2007 glass (says acura, ours say honda)
Old Feb 12, 2010 | 04:23 PM
Kartel2383's Avatar
OK only part I'm confused on is the grille. I know that I need a new chrome one but the grille behind that one can I leave it or do I need a new one?
Also for fogs and Drl do you guys thing I should have an independent button installed for fogs and make the fog light switch for our yr become DRL? or other way around?
Old Feb 12, 2010 | 05:16 PM
Dan1629's Avatar
Registered Member
grill is different, You have to change the whole bumper and grill. The chrome trim piece will be ok, but yea you also have to do headlights, tailights, markers, mirrors, chrome decklid trim, carbon fiber look licence plate trim, I think that is about it but other members will probably have more input or disagree.
Old Feb 12, 2010 | 05:48 PM
gotkilled's Avatar
NBP is a pain...
wow..i never knew the badges on the 07-08 were italicized.
Old Feb 12, 2010 | 06:15 PM
melvin2816's Avatar
05 TL NBP 6spd S front
Two similar threads on the same day
https://acurazine.com/forums/3g-tl-2004-2008-93/will-08-front-bumper-foglights-fit-my-04-need-help-soon-763527/
Old Feb 12, 2010 | 09:16 PM
csmeance's Avatar
The base TL does not have a chrome grille. it has a satin finished one just like on your TL. The new bumper will come with the Satin pieces if you buy the whole package. If not, the satin pieces are easy to get and will go onto the new bumper without a problem.
Yup, if you look at them, the look italicized versus the ones on the 04-06 TL. This was probably done to have the Type-S badge flow better on the TL-S's.
Old Feb 12, 2010 | 11:02 PM
Red Voodoo's Avatar
Area on my XM
I guess the OP has a method to his madness. It's cheaper to convert to a UA7 exterior than to just buy one outright.
4drviper
Apr 23, 2025 07:13 PM
mlody
Dec 4, 2019 02:11 PM
08KBP_VA
Oct 22, 2019 01:55 PM
MetalGearTypeS
Aug 29, 2016 08:28 PM
jubikej
1G RDX Problems & Fixes
Sep 30, 2015 01:13 PM
