2006 TL rockauto motor mount and trans #
Old 05-16-2014, 01:34 AM
9th Gear
barewire001's Avatar
Talking 2006 TL rockauto motor mount and trans #
Hello all...
This is the part number from rockauto..
#DEA A4544 Transmission mount
# 104-1895 Transmission mount
DEA A4599HY MOTOR MOUNT
DEA A4526HY MOTOR MOUNT
I order these in 11/2013 but it was too cold to install... Im having someone do this next week
Rockauto does not sell the motor mount near the firewall... I could not find it
But i wanted to contribute to the fourm
Old 05-16-2014, 02:15 AM
paperboy42190's Avatar
Received 1,162 Likes on 847 Posts
hmm...hard to see how useful this info is...but okay
DeathMetal (05-16-2014)
Old 05-16-2014, 09:47 AM
vietxquangstah's Avatar
I would stick to oem for front and rear motor mounts. Factory ones have vacuum lines running to them. They change stiffness according to vacuum.
tihomirbg (05-16-2014)
Old 05-16-2014, 10:07 AM
guitarplayer16's Avatar
Received 2,316 Likes on 1,690 Posts
Would you guys use the aftermarket brands for the transmission mounts?
I need to replace my transmission mounts, not sure if it's worth going OEM.
Old 05-16-2014, 10:12 AM
tihomirbg's Avatar
How about the side engine mount by the TB? Stock or Rockauto?
Old 05-16-2014, 10:14 AM
I would get OEM.
They're cheap enough to get OEM.
Front and rears cost a lot more, which is why some people explore aftermarket options.
Old 05-16-2014, 10:39 AM
The side mount your talking about near the throttle body isn't a engine mount. That's a transmission mount.
The side engine mount for the TL is on the passenger side near the power steering and washer fluid reservoir. You'll have to remove plastic cover to reveal it.
As for oem or aftermarket for the transmission mount I couldn't tell you.
I paid $150 for oem cv axle instead of $70-$80 for aftermarket. I don't mind paying extra
Old 05-16-2014, 11:44 AM
Due_Diligence's Avatar
My opinion...I don't think it matters as much for the side motor mount as it does for the front and rear.
Old 05-16-2014, 12:06 PM
I assumed he was referring to the Timing Belt lol
Old 05-16-2014, 01:34 PM
tihomirbg's Avatar
^yup, buy the power steering reservoir
Old 05-29-2014, 12:51 PM
thornton102's Avatar
I have an '04 TL w/ 118K that a Honda and an Acura dealership both said had all bad engine- and transmission mounts. The Honda place wants $935+4 hours labor to replace them, including programming the mounts. I can tell you now that this will NOT go over well with the Minister of Finance. So, I have some questions. If I can afford them, I'll use OEM parts.
1. How many of the mounts have vacuum lines to them?
2. WTH is "programming" the mounts? Calibrating them? Wouldn't you just hook up the vacuum lines to the mount after installing them?
3. I plan in replacing them myself. Would a dealership program them after I install them?
4. Any sage advice?
5. Are the mounts a problem with these models?
Old 05-30-2014, 04:11 AM
1. 2, front and rear
2. It's BS, there's no such thing. There is however, neutralizing the motor mounts, which is a simple extra step during the installations
3. No such thing as programming a motor mount
4. Not really, since you aren't doing it yourself so it wouldn't matter what advice I give.
5. They wear quick, but it's not really a "problem"
thornton102 (05-30-2014)
TypeS860
09-03-2021 06:42 PM
wilztlxs
12-01-2015 09:16 AM
joflewbyu2
10-08-2015 11:16 AM
STL TL-S
09-23-2015 08:52 PM
ROSSARONIE
09-22-2015 11:46 AM
Quick Reply: 2006 TL rockauto motor mount and trans #
