2000 mile round trip report
We just recently took the TL for a trip from Houston to Ashville NC. I just thought I would post my impressions Good and Bad.
Good:
Mileage - 29 going east, 28 going west (could be a speed thing, we were going faster west bound than east )
Power to pass - excellent
Comfort - good for the driver, no complaints from the passengers. (wife and 2 teenagers) Right arm rest postion could be a little higher and further forward to facilitate right hand postion on the wheel. ( that would be a personal thing I am sure, everyone is different)
Satelite radio is a necessity (kept me awake between news, comedy and music channels) Dvd-A is nice but lack of titles puts me back to listening to CDs for the most part. Still great audio though...
Best cruise control I have driven. Even if the steering wheel buttons are different from what I am used to. It maintains speed on hills without the all of the downshifting that our Grand Cherokee did.
Bad:
Road noise and ride over concrete roads. Harsh is the only word I can think of. The expansion joints really suck on parts of I10 in TX and LA. No problems on asphalt. This aspect affects the audio performance. Why have a nice audio system if the background noise smothers it?
Handling - Squirrely behavior from rear of the car fully loaded over the expansion joints and rough road. you hit a bump and the rear of the car seemed to kick right or left depending which tire hit the bump. Kinda unnerving. Never experienced it before this trip, but I never had the car fully loaded with passengers and luggage.
Tire wear - significant wear of rear tires... Can't give you an specific numbers but the tires started out equal at the beginning of the trip and now the rears have about half the tread of the fronts. (yes they are OEM tires EL42s)
Thats about it. Got lots of looks from other drivers. DGP freshly washed and waxed does look nice. It almost made 15 hours in the car at stretch enjoyable... Almost
Good:
Bad:
If you wore out 1/2 the tread on a 2000 mile trip I would have the 4 wheel alignment looked at .. something is really out of whack to do that. Even if the passengers and luggage weighed the rear down it might have shifted the camber but that usually wears the inside of the tire.
This also makes me suspect ----> Handling - Squirrely behavior from rear of the car fully loaded.
Usually if anything the complaint on a fully loaded car is the front end gets lightened and the steering mushy..etc.
Also did you add air for the extra weight?
Thanks for the observations.
Were you referring to the arm rest did you know it can be adjusted? The console armrest adjusts fore and aft, but not height.
I would agree with your observations on road noise. The TL can be silent on asphalt roads, but loud on concrete or coquina. Much depends on the roads surfaces in your region and and the tire behavior with different road surfaces.
I have the tires rotated about every 5000mi and I just had them rotated a week before the trip. No signs of strange tire wear. But having said that I will be taking the vehicle to have it's alignment checked, and corrected if need be... Air pressure was 32 all the way around. I actually stopped, and checked the air pressure because I thought I might have tire going flat. Not the case.
I tried running the arm rest forward, but without the ability to increase the height, it wasn't much help.
Jesstzn hit all the good points. we had some good threads about alignment and tire wear in the tire section. do a search and you'll see. people have corrected their excessive tire wear problem by getting the alignment re-done. i had an acura bad alignment QC theory IMO. if you don't want to spend $60 for the alignment, u can take it back to the dealer. of course you have to deal with their usual crap. if they tell you it's normal for your new car to wear 1/2 the rear tires on a 2000 mile trip (EL-42/loaded or not), please let us know their name.
You mentioned squirrley handling, was that when you were on a concrete road that had peralel lines cut into the road? I have noticed that my car slides back and fourth while going above 60 mph on those type of roads.
Keep Right Except to Pass
Thanks on the mileage. It's interesting to compare what people get at different speeds. I averaged 30 mpg for a 241-mile drive at an average speed of 71 mph on Sunday, which is what prompted my query.
So is it normal that my car slides back and fourth while drivin on the grooves?
It sounds like you may want to get your alignment checked to ensure that all is within specification. Look closely at rear toe-in and make sure it sits at least towards the middle of the range at 0.08 deg.
One of the advertised features of the TL is an increase in rear toe-in as the suspension is compressed. Basically, the front of the rear wheels will point slightly more at each other as the car goes over bumps, is compressed in a turn (outside wheel), is loaded with passengers, or even while travelling at highway speeds due to aerodynamic downforce. The increased toe-in may be what makes the rear of the car feel squirrelly over grooves.
I found the rear skittishness on one particular stretch of undulating highway unnerving enough that I changed to the aspec sport suspension and a Comptech RSB. This improved the issue by 90% or so. On the other hand, while handling was greatly improved, I'm left with a suspension that is not aligned to within Acura specs.
Head a da Family
Thanks for the opinions, NoRespect. I've taken my TL all over the country and agree that it's a great cruiser. I haven't had any trouble with excess tire wear except when the alignment was off.
I also have difficulty on grooved roads undergoing repair even when I'm the only one in the car. I think it's a function of the relatively low-profile tires? Instead of the car itself? Not sure.
Originally Posted by Juronimo
How are you guys getting such fuel economy? During my recent road trip I got at best 24mpg and the other times I filled up the mpg was 22mpg.
If I am driving around town my mileage is only 18-19 best. Highways with just myself at 80 mph I can get as high as 31. Cruise control helps alot, and yea that pure highway driving.
UPDATE:The tire wear issue was resolved by Dealership and Acura Factory Rep. Two new tires and reset the tow to 0. They are doing the alignment for free, and I am buying 2 new tires to go with the free ones on back. Unfortunately they are only going to put the Bridgestones on... At least that gets 1/2 priced tires...
mada51589
05-03-2022 08:54 PM
