15% off orders from V-LEDS.com
#122
RPF1+RS3 FTW
Also anyone not willing to spend $50 on reverse lights you can get the 27 LED ones here:
http://www.v-leds.com/Shop/Control/P...id/0/SFV/32481
My friend (ifirahse) and I did a comparison of the 36 vs the old 27s and the difference was negligable. Seriously we had 1 of each installed and could barely tell the difference. Anyways hopefully the high power 14s are a more noticable improvement.
#123
RPF1+RS3 FTW
I was over at my buddy ifirahse's house tonight and we checked the 27 vs 36 vs the new 14 high powers. Difference is slight but the 14 is definately the brightest. I would say it is not bright enough to justify upgrading from the 36, maybe from the 27. They are nice though I am happy with them.
#126
Definitely gotta get in on this coupon code
#127
RPF1+RS3 FTW
I am planning on going to the So Cal Surf Cruise though on April 18th
https://acurazine.com/forums/acurazine-clubs-meets-15/so-cal-surf-cruise-%7Eapril-18-2009%7E-711767/
#131
Would these be good for fogs on a 2006 TL.
2 V-LEDS HID WHITE 68 M-SMT DRL/FOG BULBS HB4 9006 6K
V-LEDS Part ID: 9006_68_W
# In Package 1 Pair
$59.99
Are these what I need when I clear my headlights? Will they fit OK?
V-LEDS DUAL COLOR CHANGING HID WHITE/AMBER 48 M-SMT PARKING/TURN SIGNAL BULBS 7443 7443NA
V-LEDS Part ID: 7443_48_SMT_WA
# In Package 1 Pair
$49.99
# In Package 1 Pair
$59.99
# In Package 1 Pair
$49.99
#134
RPF1+RS3 FTW
# In Package 1 Pair
$59.99
# In Package 1 Pair
$49.99
# In Package 1 Pair
$59.99
# In Package 1 Pair
$49.99
#136
Where Did My Garage Go?!!
these are the reverse lights right?
V-LEDS HID WHITE 14 M-SMT 5W HIGH POWER BULBS
http://www.v-leds.com/Shop/Control/P...36235248245248
#137
^The description you have is correct, the link is wrong.
http://www.v-leds.com/Exterior-LED/P...82764-1-2.html
#138
http://www.v-leds.com/Exterior-LED/P...-p5682764.html
V-LEDS HID WHITE 14 M-SMT 5W HIGH POWER BULBS 917 918 920 921 922 923
These are now back in stock. I placed my order tonight. I also saved 15% with the CLUBLEXUS code. Thanks again, AZ!!!
#140
I don't mean to argue, but I saved $7.50 on a $50 order. Unless my math is wrong, that equals 15%. I guess if you are looking for LEDs, place your order and input the code. Your mileage may vary!
#147
#149
NTMD8
How are the license plate LEDs holding up from these guys? I had purchased a set of the regular 4LED bulbs from them and they burnt out after 2 months ( ppl said ti was due to the opening/closing of trunk). I was going to upgrade to CCF but I'm lazy... so if someone can confirm that the LP LEDs are holding up for a lOOoooOong time... i'll get those.
#150
el bolo loco
Here is my current LED setup:
3 x HID WHITE 30 M-SMT BULBS 194 (2 Vanity, 1 Trunk) - $16.99 each
http://www.v-leds.com/Shop/Control/f...35250249246247?
2 x HID WHITE 6 LED FLANKS 194 (2 Front Domes) - $10.99 pair
no longer available
2 x HID WHITE 6 LED LIGHT BULBS 194 (2 Rear Domes) - $7.99 pair
2 x HID WHITE HPT 5 LED LIGHT BULBS 194 (Doors) - $12.99 pair
2 x HID WHITE HIGH POWER LICENSE PLATE LED BULBS (License Plate) - $9.99 pair
http://www.v-leds.com/Shop/Control/f...39238249244251?
2 x HID WHITE 14 M-SMT 5W HIGH POWER BULBS 921 (Reverse Lights) - $49.99 pair
http://www.v-leds.com/Shop/Control/P...45248243244239
2 x DUAL COLOR CHANGING HID WHITE/AMBER 48 M-SMT PARKING/TURN SIGNAL BULBS 7443 (Front Turn Signals) - $49.99 pair
http://www.v-leds.com/Shop/Control/f...35240239246251?
2 x 6 OHM 50W 2 BULB LED LOAD RESISTORS TURN SIGNAL BLINKER FIX 7443 (Resistors for Switchbacks) - $9.99 pair
http://www.v-leds.com/Shop/Control/P...35240239246251
Other Info
How to install resistors:
https://acurazine.com/forums/3g-tl-2004-2008-93/how-install-led-resistors-lots-pictures-3g-garage-g-079-a-637923/
Also my sidemarkers are custom made switchbacks, see these threads for more info:
https://acurazine.com/forums/3g-tl-2004-2008-93/g-043-blinking-sidemarker-diy-guide-suitable-3g-garage-703668/
https://acurazine.com/forums/3g-tl-2004-2008-93/switchback-side-markers-704533/
Hope that helps.
no longer available
Other Info
Hope that helps.
#152
# In Package 1 Pair
$59.99
# In Package 1 Pair
$49.99
# In Package 1 Pair
$59.99
# In Package 1 Pair
$49.99
MY TL is an 06. ^^^^Are these correct for an 06 TL?
I read the 07-08 are diff from 06 ?
I need to order soon, headlights are getting cleared this week.
Thanks, I feel silly asking.
#154
RPF1+RS3 FTW
I spend 2 much time here
my experience with LEDS has been pretty bad so far. they always burnout faster than standard bulbs. i'm not sure if it is the brands i have gone with but i really am having a tough time believing in this technology.
anyone else had simliar experience?
#159
^^^^ Unfortunately, my experience with LEDs is limited---check back in abt 6mos for an update.
My issue is I went for 12LED domes in blue and I'm still not quite sure as to the "riciness" of blue LEDs. Regardless, I did order the LED backup lights from V-LED, since I can't see anything with the stock bulbs.
I also have heard about reliability issues in the trunk lights and I am considering white CCFLs for that area. Again, the stock light just doesn't cut it as far as brightness. I figure mounting the CCFLs off of the lid (under where the rear windshield meets the car) will eliminate the trunk "slamming" problem.
