A-122: DIY - 105k Service: Timing Belt, Water Pump, Spark Plugs, Thermostat *PICS*
Old 07-21-2016 | 07:55 PM
  #2081
Atlas_Gen's Avatar
I bought the Aisin Kit from Rock Auto.
Old 07-22-2016 | 10:38 PM
  #2082
nfnsquared's Avatar
For you first timers, here's a good video showing the timing belt with the engine removed. Note that he does not follow the service manual procedure for replacing the belt, but I guess his method seems to work.
He also has a 5-6 part video series on the TB service.
nist7 (07-23-2016)
Old 07-22-2016 | 11:03 PM
  #2083
Majofo's Avatar
I wouldn't pull the crank sprocket out to slip the belt on. I'd also double check the tension on idler pulley and water pump side to make sure it's taught before pulling the pin. He did emphasize but didn't state what happens if you forget the put the key back in..
Which is why I wouldn't pull it out in the first place. We have a member her who can testify to that.
Old 07-22-2016 | 11:51 PM
  #2084
nfnsquared's Avatar
Yeah, I wouldn't pull the crank sprocket either. Both times I've done the TB change, I never had an issue following the service manual procedure for replacing the belt.
Old 07-23-2016 | 08:01 AM
  #2085
rockstar143's Avatar
I've only done it once, and I had no issues either...although I mainly followed the instructions in this thread.
Old 07-23-2016 | 01:38 PM
  #2086
nfnsquared's Avatar
...He also has a 5-6 part video series on the TB service...
This guy seems to know what he's doing, but I ROLF'd at video #4 where he spent 5 hours getting that crank bolt off...I bet all he needed was a $25 Lisle 77080 socket... Good on him for replacing the belt and TB cover at his expense after applying all that heat Can't believe the owner was so cheap as to not fork over an extra ~$150 for a complete TB/WP kit...
Old 07-23-2016 | 10:35 PM
  #2087
Majofo's Avatar
Old 07-24-2016 | 06:41 PM
  #2088
Well, I inspected my oem crank pulley and it looked pretty beat. Felt like since I had a lightweight one laying around I might as well throw it on.
105K service had been done a few years back so it wasn't an untouched crank pulley but MAN that bolt was hard as fuck to get off.
Probably a full 2 solid minutes of hitting it with the gun and then lubing with peanut butter blaster. I was gonna abandon or order the lisle, but got lucky!
Old 07-26-2016 | 08:44 PM
  #2089
freddiemercury1's Avatar
Stuck auto tensioner pin.
Thanks for the awesome write up.
I did fine till replacing the timing belt and when I tried to pull the pin in swift movement (not s o swift I guess) the pin came half way and is stuck. I tried pulling it bit it's very hard.
Any suggestions to resolve this ??
Thanks and appreciate the help.
Old 07-26-2016 | 08:47 PM
  #2090
nfnsquared's Avatar
Get pliers on it, it'll come out. If not, you'll have to pull the tensioner, put it in a vice, and reset the pin.. Not a big deal unless you don't have a vice.
Old 07-26-2016 | 09:20 PM
  #2091
Thanks for the quick response!
I did not want to remove the tensioner so i tried yanking but in the end I just removed the tensioner put the pin back and installed the tensioner back. I will pull the pin tomorrow just to make sure I did not miss anything today :|
Old 07-27-2016 | 08:46 AM
  #2092
94eg!'s Avatar
#1 Super Guy!
I found the pin on the tensioner too soft. It wouldn't pull out (with pliers even) once the tip of the pin popped out of the first hole. The hydraulic pressure bent the pin so much there was no way you could pull it through the next two holes. I tried twice to straighten the pin and have another go, but ended up with the same problem both times. Finally I chucked the pin and replaced it with a drill bit. Plenty stiff and slipped right out with pliers when the time came.
BTW: A simple large C-clamp works great to compress the tensioner. I've used an old rusty one to do this at least 6 times. Just go slow and you won't have any trouble.
Old 08-03-2016 | 03:03 AM
  #2093
VeNoMiZeD's Avatar
My 2008 Type S has 112k miles, is the 105k service supposed to alert me when it's due? I get every other alert for oil changes etc... But still haven't had the 105k service yet. What is the alert code? Thanks!
Old 08-03-2016 | 06:43 AM
  #2094
There is no alert...it's a suggested interval. Many have gone much further without trouble, but it's kinda like going raw on Kim K, you might not get the herp, but do you wanna chance it?
Old 08-03-2016 | 08:34 AM
  #2095
B14
Old 08-03-2016 | 09:55 AM
  #2096
nfnsquared's Avatar
More correctly, the MID will indicate a "4" for the TB change. It will also be accompanied with "A" or "B" and may also include another number. All of this is covered in your owner's manual.
Old 08-03-2016 | 10:42 AM
  #2097
Majofo's Avatar
LOL.. get a vice!
Not a ninny one either.. for reasons.
Old 08-03-2016 | 12:03 PM
  #2098
t-rd's Avatar
George Melnik specializes in European cars and the procedure he illustrated isn't exactly correct, even though he put on the belt tight. The correct procedure to follow is that used by Eric O from the the Honda Pilot video. I would not remove the crank pulley sprocket, but you can loosen the idler pulley on the right, slip the belt on, then retighten the idler pulley. The bolt for the idler pulley allows that pulley to self center back to the right position once you tighten it. The back side of that bolt has a cone shape that centers back the pulley.
I watched his other video where he used a 1" impact gun to get the pulley. People, just get the Lisle socket or that new fancy one from Ingersoll. I got it off with an 1/2" OLD electric impact within 5 seconds.
Old 08-04-2016 | 05:07 PM
  #2099
DMZ's Avatar
DMZ
Head a da Family
Originally Posted by Majofo
LOL.. get a vice!
Oh, I'm a clown. I make you laugh? I amuse you. I'm funny? How funny? WTF is so funny about me?
Old 08-04-2016 | 05:45 PM
  #2100
Majofo's Avatar
Old 08-09-2016 | 04:27 PM
  #2101
rkpatt's Avatar
Oil leak after timing belt change
I just did another timing belt change for a friend on an A-122 . This my 5th Acura V6 timing belt project. Never had any problems before.. This one show an oil leak immediately after completing the job There were no signs of leaks be before job. Crank and cam seals showred no signes of leaks when I had the covers off hwen I preformed the job and I left them in palce. The dipstick tube o-ring was replaced as part of the job and was a checked after I the leak was apparent (I was fine). is really difficult for me to believed that the crank seal coincidentally failed ?. Where else could be coming from (any bolts actually go in to the crank case) ? The TB t looks dry - I removed upper right cover and saw that the belt is dry ? This there anyway I can further inspect this situation short of a very time consuming effort of all the the timing covers (eg cut inspection holes lower cover with a dremel etc ) ? Advice/recommendations on what to do next are appreciated.
Old 08-09-2016 | 05:05 PM
  #2102
nfnsquared's Avatar
Are you sure it's coming from the crank seal?
Old 08-09-2016 | 05:48 PM
  #2103
rkpatt's Avatar
No, am not sure and want to locate the source of the oil leak without tearing it all apart again if possible. ( cut inspection hole in lower timing cover? Add UV dye to oil ? etc)
Old 08-09-2016 | 06:37 PM
  #2104
Check the vtec solenoid gasket too...
easier to get to and "kinda" unrelated!
Old 08-10-2016 | 01:30 PM
  #2105
rkpatt's Avatar
Yes, it seems in related but worth a look. I will wash everything off and take a closer look there too.
Old 08-15-2016 | 11:05 AM
  #2106
Majofo's Avatar
I'm not sure why you replaced dipstick o-ring, but that would be my first guess. I'd double check that. Also check PCV valve.
Regarding crank seal.. there's some theory that breaking the cp bolt / re-torquing it, applying PB, or applying heat to it might somehow disturb the sleeping giant.. and subsequently cause a leak.
I wouldn't rule it out, but I'd be a bit surprised if it was significant.
Vtec solenoid gasket is definitely a common source for oil leaks. Replace the solenoid o-ring as well.
A good way to check for leaks is clean everything up.. put it up on stands, and spray the suspect areas with athlete's foot spray (powder residue). Turn car on and watch.
Old 08-15-2016 | 11:07 AM
  #2107
Majofo's Avatar
Remote possibility.. spark plug seal. You should check the valley and see. Remember the leak appears at the lowest point, the source can be anywhere.
  #2108
^^^kinky...
I used peanut butter
Old 08-15-2016 | 11:08 AM
  #2109
Majofo's Avatar
These aren't your nuts, and we ain't your dogs
Old 08-15-2016 | 11:13 AM
  #2110
Old 08-16-2016 | 07:36 AM
  #2111
ChrisJ's Avatar
Originally Posted by musiclevelz5
@ maharajamd - FYI
Why are you going to NJ to get the timing belt kit installed? I live in North Dayton (probably an hour away from you) and do these jobs all the time in my garage. I have been a full service self employed Honda/Acura tech for 5 years.
Not trying to sell work as I already have a full time job in another profession as well and do not need more work but I love to help people out close to me as driving 8+ hours one way seems pointless.
Wish I could find someone like you in Louisville, Kentucky area. I am in need of this 105k mile service myself in the next 1k or so. Really trying to stay way from the dealer markup on the service.
Old 08-17-2016 | 09:46 PM
  #2112
Aussum's Avatar
Hi,
My name is James. I'm 43, father of 5, and i live in Dallas. I've been reading these forums a lot lately and came across this 105k DIY service thread. I bought a 2004 TL about 18 months ago and it has been my wife's car, up until we found a 97 Integra LS sedan with 60k original miles on it for $1000. Since the TL had 190k on it, the Integra felt like a new car to her, so she claimed it. I fell in love with the TL after driving it more and learning more about it from this forum. I have since started a new business venture that requires me to use the car as a delivery method and i really need to get it restored. I just got the car back from the shop today after doing a complete suspension refresh to it. The shop (who i completely trust) let me know that it is in dire need of the timing belt service as the tensioner can be heard rattling when you start the car. I just dropped $1300 on the undercarriage of the car, and with starting a new business, there is no way i can drop another $1500 for the 105k service plus the oil pump seals. I'm worried that if i don't get the service done soon that the tensioner might fail causing the motor to be damaged. So here it is..... I was wondering if i might be able to bribe someone with booze, pizza, and a little cash to help me get this service done on my car? I would attempt it myself but all my tools were stolen in a home burglary last year, and i'm not sure i trust myself to try something this important anyhow.
I feel like a real dick imposing on someone like this. I just have to try for the sake of my business and my TL.
I know this is a crazy request.
Thank you for taking your time to read this.
​-James-
Old 08-17-2016 | 10:16 PM
  #2113
nfnsquared's Avatar
You might have better luck posting in the regional forum, dunno.
As far as their claim that they can hear the tensioner rattle.... I'd be a bit skeptical of that. It could be an exhaust shield, it could be the serpentine belt tensioner....
Was the first TB change done at 105K?
Old 08-17-2016 | 10:18 PM
  #2114
Aussum's Avatar
I dont know for sure. As far as carfax is concerned, no. The car came from NY. I'm sure it could have been done at an indi shop and not reported.
Old 08-17-2016 | 10:21 PM
  #2115
Aussum's Avatar
I have nothing but trust for this shop. They could have took me for a lot more on the car and they didn't. They did stuff like replace tie rod end boots rather that replace the tie rod end itself. They come highly recommended by the entire honda/acura community locally.
The Hondew Shop.
i also have heard the noise, and agree that it sounds like its coming from behind the TB cover.
Old 08-18-2016 | 06:13 AM
  #2116
A simple timing belt/tensioner and wp service at Honda normally runs about $600 including parts, maybe a tad more. That's down here in SoFla too, which normally has inflated rates.
Give it a shot.
Old 08-18-2016 | 09:27 PM
  #2117
Aussum's Avatar
The noise seems to come and go. I don't doubt that the TB service needs to be done, but it might not be as bad as i was thinking. I'm just going to baby the car until i can come up with enough money to resupply myself with some tools. After all, what kind of man doesn't work on his own car?.... right?
thanks for listening to my sob story, all.
Old 08-18-2016 | 09:47 PM
  #2118
nfnsquared's Avatar
Try removing the drive belt (serpentine belt) and then starting the car.... Does the sound go away?
And FYI, you should be able to get most of the required tools free via an auto parts store loaner program....
Old 08-18-2016 | 10:19 PM
  #2119
Aussum's Avatar
I will. I'm doing the a/c field coil and clutch replacement tomorrow, so i will have the belt off. I will check it then.
Thanks for the advise.
Old 08-19-2016 | 06:21 AM
  #2120
if you have the serpentine belt off anyway, you might as well do the timing belt job
I can't think of any specialty tools necessary...go to a local shop and pay them $10 to crack your crank pulley bolt...
drive to Sears and buy a beginner's socket wrench set for $100 and get at it!
The belt portion of this job isn't really too bad...the part that sucked the most ass for me was doing the valve adjustment at the same time because it made the overall job feel daunting.
Quick Reply: A-122: DIY - 105k Service: Timing Belt, Water Pump, Spark Plugs, Thermostat *PICS*
